My BLDC motor encoder outputs+5V, A, B, and GND, without Z. If A and B are connected to GPO15 and GPO14 of TMC9660 respectively, how to set this encoder in TMCL-IDE?
TMC9660
Recommended for New Designs
The TMC9660 is a highly integrated monolithic gate driver and motor controller IC with buck converter.
It includes a smart gate driver, a high-performance...
Datasheet
TMC9660 on Analog.com
Hi zhejiang,
I think you've used the wrong GPIOs (e.g. GPIO14 can only be used as the optional Z for ABN1)...
See inside the TOML file, there are some commented GPIO numbers that are supported for the ABN1 and AB2 encoders:
Hope this helps.
Paul
