Failed to load LibFT4222.dll help when connect USB-2-RTMI
The user encountered issues with the TMCL-IDE failing to load LibFT4222.dll after installing the latest FT4222 driver for a TMC-4671 board. The problem was resolved by using an older version of LibFT4222.dll (version 1.4.4 or 1.4.2), as newer versions (1.4.5 and above) seem to have compatibility issues with the Microsoft Visual C++ runtime library.
Product Number: u
Please help, I have used USB-2-RTMI to connect TMC-4671 board to TMCL-IDE to config and monitor for BLDC servo motor. After install newest driver for FT4222 and copy file LibFT4222.dll to C:/WINDOWS/SysWOW64, TMCL-IDE can see the SPI port but always show the red message “ Failed to load LibFT4222.dll”. I have tried so many ways, install to another laptop, another PC, and there is no work-same issue. Maybe the file LibFT4222.dll or driver I have downloaded from FTDI website is Not correct files? Please help me to correct this issue. Thanks,,
