TMCM-6110 Initiating IRQ using DI
Product Number: TMCM-6110
Hi,      I'm trying to initiate an IRQ using Vect 40 instruction but cant get it to respond.
The Timer interrupt sample code (below) in the TMCM-6110 firmware manual works fine but there is no guidance on using DI apart from a Vect number.
VECT 0, Timer0Irq
SGP 0, 3, 5000 //configure the interrupt: set its period to 5000ms
EI 0
EI 255
Loop:
MVP ABS, 0, -2900
WAIT POS, 0 ,0
MVP ABS, 0, -290
WAIT POS, 0 ,0
JA Loop
Timer0Irq:
SIO 0, 2, 1
WAIT TICKS, 0 ,200
RETI
The manual indicates to use Vect 40 for Input 1
39 Input 0
40 Input 1
41 Input 2
42 Input 3
My code below which does not work....
VECT 40, DigitalInput1       // 40 = input 1
EI 40
EI 255
Loop:
MVP ABS, 0, -2900
WAIT POS, 0 ,0
MVP ABS, 0, -290
WAIT POS, 0 ,0
JA Loop
DigitalInput1:
MVP ABS, 0, -1900
WAIT POS, 0 ,0
RETI
Any help will be appreciated, thank you.
Parents Reply Children
No Data
