I'm designing a controller for a motion Platform, which uses 4 TMC5130 drivers to drive the motors. I'm using the ramp generator to save on processing power but I keep running in the problem that the motors sometimes move when enabled but at idle, also when I try to change the speed while in movement the motors jerk unpredictable.
I tuned the motors as described in trinamics application note 001 and used mostly default values, for the configuration (spreadcycle, no stallguard, conservative acceleration/top speed)
Has someone experienced simmilar problems?
