ADuCM4050
Recommended for New Designs
The ADuCM4050 microcontroller unit (MCU) is an ultra low power integrated microcontroller system with integrated power management for processing, control...
Datasheet
ADuCM4050 on Analog.com
Press and hold the on-board RST and BOOT button simultaneously then release RST button and finally release BOOT button.
Then, try to erase flash with 115200 baud rate. The error: Failed to connect to CPU should not appear again after successfully erasing the flash.
Bryan
