ADICUP3029 : example code 'blinky_example' have problem in CCES. with error massage 'extern const __zero_table_t __zero_table_end__;'
Product Number: ADICUP3029
Software Version: CCES 2.6
I am a first-time user of the ADICUP3029 product, and I have followed the instructions on the official website to install CCES and other necessary components correctly.
However, I am currently experiencing an error similar to the one shown in the attached image when I try to run the blinky_example code. This issue occurs not only with the blinky_example code but also with new projects that I create, specifically during the build debugging process.
I have tried searching the internet for a solution, but I couldn't find the answer I was looking for. Since I am using the provided example code, I don't think there is an issue with the code itself. Can you please provide me with specific guidance on how to resolve this problem?
Thank you.
Thank you for letting us know.
In case you are looking for some pre-built files that you can drag and drop into the ADICUP3029 (some require additional hardware) those can be found here (Releases · analogdevicesinc/EVAL-ADICUP3029 (github.com) and here (Releases · analogdevicesinc/no-OS (github.com) depending on the project.
