Hi all,
This is the firmware-side counterpart to my battery-EIS setup (CN0510 analog front-end on an ADuCM355; hardware in a separate post).
Main question: Is integrating CN0510 with the ADuCM355 a viable / worthwhile approach to measure batteries in a SERIES STRING and inside a live UPS — or is this architecture fundamentally suited only to isolated-cell bench measurement? Before I invest more, I want to know if I'm on the right path at all, or if a different ADI solution is needed for in-string / UPS conditions.
What the firmware is based on: the ADuCM355 M355_4WireZ (4-wire impedance / AppBAT…) example, running on the ADuCM355's on-chip Cortex-M3. I changed GPIO assignments and some config values for my board, but the measurement engine (sequencer + DFT + ratiometric calc) is the example's. I run single-frequency EIS (SweepEn = false) at ~347 Hz–1 kHz.
What the firmware does (measurement flow):
AD5940PlatformCfg()— clock, FIFO, interrupt controller, GPIO (including the relay-select pin and the ADG636 mux pin).AD5940BATStructInit()— excitationACVoltPP ≈ 800 mV,DCVolt ≈ 1.2 V,RcalVal = 50 mΩ,DftNum, SINC2/SINC3 OSR, Hanning on.AppBATInit()→ builds the init + measurement sequences;AppBATCheckFreq()selects the filter path by frequency (SINC2NOTCH for <450 Hz, SINC3 for ≥450 Hz).- Per battery: select the cell via a relay GPIO → settle →
AppBATCtrl(BATCTRL_MRCAL)to warm up and latch the RCAL reference →AppBATCtrl(BATCTRL_START)(mux → SENSE, wait out the AC-coupling cap, discard initial DFT results) → collect N DFT results → computeZ = Rcal × Vbat/Vrcal→ moving average → print. - Two batteries: measure battery 1, then toggle the relay GPIO to connect battery 2 and repeat (front-end shared, one cell connected at a time).
Things I added to stabilize readings: a hardware/discard settle delay after switching the ADG636 mux (AC-coupling caps take time to recharge between RCAL and battery), a longer RCAL warm-up (discard many DFT results before latching RcalVolt), and an N-point moving average on the output.
My firmware questions:
- Is the
M355_4WireZ/AppBATexample intended for battery impedance as-is, or are there recommended config changes for batteries (excitation amplitude,DftNum,DftSrc, SINC2/SINC3 OSR, Hanning)? - For ~1 kHz battery EIS, what
DftSrc+ OSR +DftNumcombination maximizes noise rejection (narrow DFT bin) at a reasonable measurement time? IsDFTSRC_SINC3orDFTSRC_SINC2NOTCHpreferred at 1 kHz, and why? - After switching the mux (RREF
SENSE), the AC-coupling cap re-settles. Is there a recommended settle time / number of discarded DFT results, or a status flag to confirm the result is settled before latching RCAL or trusting a reading?
- What software noise-rejection techniques does ADI recommend for noisy environments — vector (complex) averaging of DFT results, longer integration, or mains-synchronous acquisition? Any example code?
- Is there an ADI firmware example for in-situ / ripple-based (passive) EIS (measuring a cell's response to existing ripple instead of injecting), vs the active inject-and-measure in
M355_4WireZ? - For the ratiometric calibration, is it valid to latch RCAL once and reuse it, or should RCAL be re-measured per reading / per battery channel? Any guidance on RCAL stability/validation in firmware?
- With two batteries multiplexed via relays (one connected at a time), is there a recommended re-init / re-settle / re-RCAL sequence after toggling the relay before the next measurement?
I can share my UART logs and the relevant firmware sections if helpful.
RAKESH
