I'm using the DAC part - AD5423BCPZ-RL7 in unipolar mode.
What should be the connection for the pins, LDAC, Fault & CHart if I'm not usnig these for any functionality.
Can someone please help ASAP.
Nanjunda M
AD5423
Recommended for New Designs
The AD5423 is a single-channel, voltage and current output digital-to-analog converter (DAC) that operates with a power supply range from −33 V minimum...
Datasheet
AD5423 on Analog.com
Nanjunda M
dendalisay - Moved from Precision DACs to Precision Microcontrollers. Post date updated from Monday, October 28, 2024 12:43 PM UTC to Tuesday, October 29, 2024 6:57 AM UTC to reflect the move.
I’ve worked with the AD5423 before, so here’s what I’d suggest for unipolar mode:
Does that clear things up?
Thanks for the inputs, Simon.
Hope this will be correct. Please correct me if anything wrong.
Nanjunda M
