Eval-ADuCM355 Interrupts in sample code are never executing
Product Number: ADuCM355
Software Version: aducm355-examples
Hey,
i'm trying to test the functionalities of the aducm355 with the code examples. I haven't modified the code in any way.
I tried the following code examples:
- Temperatur
- Impedance (for this sample i connected some resistors on the interface)
An interrupt should occur and data should be printed out, but as soon as the function "AD5940_GetMCUIntFlag()" get called the return value stays 0 all the time. So i guess the interrupt never occurs?
Is this behaviour intended?  Do i have to modifiy the example code so the interrupt get executed?
Thanks for any help
Shaheen
Thread Notes
    The examples work properly in our ADuCM355QSPZ boards.
    Kindly check if interrupt lines are correctly configured so the microcontroller receives the interrupt properly.
  • The example works straight from GitHub in my setup.
    It might be that they are missing the CHIPSEL_M355 definition in IAR’s Options > Runtime Checking > C/C++ Compiler > Preprocessor > Defined Symbols
    If CHIPSEL_M355 is not defined, the code will not execute lines below that shift the register address to the correct location.
    #ifdef CHIPSEL_M355
    static void AD5940_D2DWriteReg(uint16_t RegAddr, uint32_t RegData)
      if(((RegAddr>=0x1000)&&(RegAddr<=0x3014)))  /* 32bit register */
        *(volatile uint32_t *)(RegAddr+0x400c0000) = RegData;
      else                                        /* 16bit register */
        *(volatile uint16_t *)(RegAddr+0x400c0000) = RegData;
    static uint32_t AD5940_D2DReadReg(uint16_t RegAddr)
        return *(volatile uint32_t *)(RegAddr+0x400c0000);
        return *(volatile uint16_t *)(RegAddr+0x400c0000);
    regards,
    Mark
