ADuCM355.icf, Question about Linker File (ADuCM355)
Dear member,
Thank for your support.
Now, I review EVM AduCM355 with reference code example + my own application.
But, application size over... having linker error.
49'406 bytes of readonly code memory
17'216 bytes of readonly data memory (+ 11 absolute)
14'386 bytes of readwrite data memory (+ 320 absolute)
How do I have to change .icf files.. for use 120KB all flash memory for user application ?
this is my current .icf
==> start of .icf
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0x400;
define symbol __ICFEDIT_size_heap__ = 0x200;
/**** End of ICF editor section. ###ICF###*/
define memory mem with size = 4G;
// symbols
define symbol USE_PARITY = 1;
define symbol FLASH = 0x00000000; // flash address
define symbol FLASH_SIZE = 128K; // 128k flash size
define symbol FLASH_PAGE_SIZE = 2K; // 2k flash page size
define symbol PAGE0_ROM_START = 0x1A0;
define symbol SIZE_OF_INTVEC = 384;
define symbol START_OF_READ_PROTECT_KEY_HASH = FLASH+SIZE_OF_INTVEC;
define symbol SIZE_OF_READ_PROTECT_KEY_HASH = 16;
define symbol START_OF_CRC_READ_PROTECT_KEY_HASH = FLASH+SIZE_OF_INTVEC+SIZE_OF_READ_PROTECT_KEY_HASH;
define symbol SIZE_OF_CRC_READ_PROTECT_KEY_HASH = 4;
define symbol START_OF_NUM_CRC_PAGES = FLASH+SIZE_OF_INTVEC+SIZE_OF_READ_PROTECT_KEY_HASH+SIZE_OF_CRC_READ_PROTECT_KEY_HASH;
define symbol NUM_OF_CRC_PAGES = 4;
// user-selectable SRAM mode
// SRAM Banks 1 & 2 are dynamically configurable for hibernation retention at runtime
// referred to here as "xRAM_bank#_retained_region", where x = i (instruction) or d (data) and # = 1 or 2
define symbol USER_SRAM_MODE = 0;
// RAM bank sizes sizes are invariant... locations vary by RAM Mode#
define symbol RAM_BANK0_SIZE = 8K;
define symbol RAM_BANK1_SIZE = 8K;
define symbol RAM_BANK2_SIZE = 16K;
define symbol RAM_BANK3_SIZE = 16K;
define symbol RAM_BANK4_SIZE = 12K;
define symbol RAM_BANK5_SIZE = 4K;
//MODE0 0kB CACHE 32kB ISRAM 32kB DSRAM
if(USER_SRAM_MODE == 0)
define symbol RAM_BANK0 = 0x20000000; // Always Retained
define symbol RAM_BANK1 = 0x20002000; // Retained during Hibernate if SRAMRET.BANK1EN=1
define symbol RAM_BANK2 = 0x10000000; // Retained during Hibernate if SRAMRET.BANK2EN=1
define symbol RAM_BANK3 = 0x20040000; // Not retained
define symbol RAM_BANK4 = 0x10004000; // Not retained
define region iRAM_bank2_retained_region = mem:[from RAM_BANK2 size RAM_BANK2_SIZE];
define region iRAM_never_retained_region = mem:[from RAM_BANK4 size (RAM_BANK4_SIZE + RAM_BANK5_SIZE)];
define region dRAM_always_retained_region = mem:[from RAM_BANK0 size RAM_BANK0_SIZE];
define region dRAM_bank1_retained_region = mem:[from RAM_BANK1 size RAM_BANK1_SIZE];
define region dRAM_never_retained_region = mem:[from RAM_BANK3 size RAM_BANK3_SIZE];
//MODE1 4kB CACHE 28kB ISRAM 32kB DSRAM
else if(USER_SRAM_MODE == 1)
define region iRAM_never_retained_region = mem:[from RAM_BANK4 size RAM_BANK4_SIZE];
//MODE2 0kB CACHE 0kB ISRAM 64kB DSRAM
else if(USER_SRAM_MODE == 2)
define symbol RAM_BANK2 = 0x20004000; // Retained during Hibernate if SRAMRET.BANK2EN=1
define region dRAM_bank2_retained_region = mem:[from RAM_BANK2 size RAM_BANK2_SIZE];
define region dRAM_never_retained_region = mem:[from RAM_BANK3 size (RAM_BANK3_SIZE + RAM_BANK4_SIZE + RAM_BANK5_SIZE)];
//MODE3 4kB CACHE 0kB ISRAM 60kB DSRAM
else if(USER_SRAM_MODE == 3)
define region dRAM_never_retained_region = mem:[from RAM_BANK3 size (RAM_BANK3_SIZE + RAM_BANK4_SIZE)];
// ROM regions
define region ROM_PAGE0_INTVEC = mem:[from FLASH size SIZE_OF_INTVEC];
define region START_OF_PAGE0_REGION = mem:[from (PAGE0_ROM_START) size (FLASH_PAGE_SIZE - PAGE0_ROM_START)];
define region ROM_REGION = mem:[from (FLASH + FLASH_PAGE_SIZE) size (FLASH_SIZE - FLASH_PAGE_SIZE)];
define region SRAM_CODE = mem:[from (RAM_BANK2) size (RAM_BANK2_SIZE)];
place at address mem: START_OF_READ_PROTECT_KEY_HASH { readonly section ReadProtectedKeyHash };
place at address mem: START_OF_CRC_READ_PROTECT_KEY_HASH { readonly section CRC_ReadProtectedKeyHash };
place at address mem: START_OF_NUM_CRC_PAGES { readonly section NumCRCPages };
// C-Runtime blocks
define block CSTACK with alignment = 8, size = __ICFEDIT_size_cstack__ { };
define block HEAP with alignment = 8, size = __ICFEDIT_size_heap__ { };
// Flash Page0 contains an optional checksum block, as verified by the boot kernel at startup.
// If generating a checksum ("Checksum" linker dialogue box) during the build, it is also
// required to add "--keep __checksum" to the linker "Extra Options" dialogue to preserve the
// linker-generated "__checksum" symbol.
define block CHECKSUM with alignment = 4, size = 4 { ro section .checksum };
// force manditory placement of the CHECKSUM block within Page0
place at address 0x000007FC { block CHECKSUM };
// KEEP these blocks, avoiding linker elimination...
keep {
block CHECKSUM,
// initializations...
do not initialize { section .noinit };
// expand encoded initialized data variables from flash image into RAM during C-Runtime Startup
initialize by copy { rw };
//initialize by copy with packing = none { section __DLIB_PERTHREAD }; // Required in a multi-threaded application
// ROM: place IVT at start of flash, page zero (ahead of the "meta-data")
place at start of ROM_PAGE0_INTVEC { ro section .intvec };
place in START_OF_PAGE0_REGION { ro section Page0_region };
// ROM: place remaining read-only code/data in flash, starting at flash page1
place in ROM_REGION { ro };
// Create as large a gap as possible between the stack and the heap to avoid collision...
// RAM: place stack @ end (high-address) of always-retained dRAM because stack "grows" towards low addresses
place at end of dRAM_always_retained_region { block CSTACK };
// RAM: place heap, etc., into low-address, always-retained dRAM
place in dRAM_always_retained_region { rw, block HEAP };
// ISRAM section for placing code in SRAM
place in SRAM_CODE {section ISRAM_REGION};
initialize by copy {section ISRAM_REGION };
// NOTE: To direct data to reside in specifically named memory regions
// (suce as into specific banks or non-hibernation-retained memory),
// use either of the IAR directives:
// '#pragma location="named_region"' directive prefix, or the
// '@ "named_region"' suffix with the data declarations.
// place data declared as bank1-hibernation-retained
place in dRAM_bank1_retained_region { rw section bank1_retained_ram };
// place data declared as bank2-hibernation-retained (RAM modes 2 or 3 only)
//place in dRAM_bank2_retained_region { rw section bank2_retained_ram };
// RAM: place volatile RAM data (never retained during hibernation) into select
// named volatile regions, depending on SRAM Mode# and SRAMRET.BANK#EN bits
// place unterained sections
place in dRAM_never_retained_region { rw section never_retained_ram };
