I am working on HDL and NO-OS project. I have successfully built the project in two different environments: Vivado/SDK 2019.1 and Vivado/Vitis 2022.2.
The Problem:
Upon launching the code on the hardware, the initialization sequence appears successful. The Vitis/SDK serial terminal shows the expected prints and initialization logs. However, when monitoring the output via a Signal Analyzer at the desired carrier frequency, there is no signal detected (only LO leakage is seen at the carrier frequency).
Hardware Setup:
Carrier Board: [ZCU102]
RF Transceiver: [ADRV9002]
Observations:
Software: The No-OS state machine completes without returning error codes.
RF Output: No signal at the SMA connectors. I have verified the cables and the signal analyzer settings.
I have attached the headlessmain.cfiles for both versions and the corresponding Vitis terminal logs. I am concerned that I may be missing a critical function call required to transition the signal from the 'Ready' state to Transmitting. Kindly look into it.
/***************************************************************************//** * @file headless.c * @brief adrv9002 main project file. * @author Darius Berghe (darius.berghe@analog.com) ******************************************************************************** * Copyright 2020(c) Analog Devices, Inc. * * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions are met: * - Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * - Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in * the documentation and/or other materials provided with the * distribution. * - Neither the name of Analog Devices, Inc. nor the names of its * contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * - The use of this software may or may not infringe the patent rights * of one or more patent holders. This license does not release you * from the requirement that you obtain separate licenses from these * patent holders to use this software. * - Use of the software either in source or binary form, must be run * on or directly connected to an Analog Devices Inc. component. * * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT, * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT, * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *******************************************************************************/ #include <stdio.h> #include <stdlib.h> #include <string.h> #include "xil_cache.h" #include "error.h" #include "util.h" #include "spi.h" #include "axi_adc_core.h" #include "axi_dac_core.h" #include "axi_dmac.h" #include "parameters.h" #ifdef IIO_SUPPORT #include "app_iio.h" #include "xil_cache.h" #endif #include "adrv9002.h" #include "adi_adrv9001.h" #include "adi_adrv9001_arm.h" #include "adi_adrv9001_radio.h" #include "adi_adrv9001_tx.h" int get_sampling_frequency(struct axi_adc *dev, uint32_t chan, uint64_t *sampling_freq_hz) { if (!dev || !sampling_freq_hz) return -EINVAL; *sampling_freq_hz = adrv9002_init_get()->rx.rxChannelCfg[chan].profile.rxOutputRate_Hz; return SUCCESS; } int main(void) { int ret; struct adi_common_ApiVersion api_version; struct adi_adrv9001_ArmVersion arm_version; struct adi_adrv9001_SiliconVersion silicon_version; struct adrv9002_rf_phy phy; struct axi_adc_init rx1_adc_init = { "axi-adrv9002-rx-lpc", RX1_ADC_BASEADDR, #ifndef ADRV9002_RX2TX2 ADRV9001_NUM_SUBCHANNELS, #else ADRV9001_NUM_CHANNELS, #endif }; struct axi_dac_channel tx1_dac_channels[2]; tx1_dac_channels[0].sel = AXI_DAC_DATA_SEL_DMA; tx1_dac_channels[1].sel = AXI_DAC_DATA_SEL_DMA; struct axi_dac_init tx1_dac_init = { "axi-adrv9002-tx-lpc", TX1_DAC_BASEADDR, #ifndef ADRV9002_RX2TX2 ADRV9001_NUM_SUBCHANNELS, #else ADRV9001_NUM_CHANNELS, #endif tx1_dac_channels, }; #ifndef ADRV9002_RX2TX2 struct axi_adc_init rx2_adc_init = { "axi-adrv9002-rx2-lpc", RX2_ADC_BASEADDR, ADRV9001_NUM_SUBCHANNELS, }; struct axi_dac_channel tx2_dac_channels[2]; tx2_dac_channels[0].sel = AXI_DAC_DATA_SEL_DMA; tx2_dac_channels[1].sel = AXI_DAC_DATA_SEL_DMA; struct axi_dac_init tx2_dac_init = { "axi-adrv9002-tx2-lpc", TX2_DAC_BASEADDR, ADRV9001_NUM_SUBCHANNELS, tx2_dac_channels, }; #endif struct axi_dmac_init rx1_dmac_init = { "rx_dmac", RX1_DMA_BASEADDR, DMA_DEV_TO_MEM, 0 }; struct axi_dmac_init tx1_dmac_init = { "tx_dmac", TX1_DMA_BASEADDR, DMA_MEM_TO_DEV, DMA_CYCLIC, }; #ifndef ADRV9002_RX2TX2 struct axi_dmac_init rx2_dmac_init = { "rx_dmac", RX2_DMA_BASEADDR, DMA_DEV_TO_MEM, 0 }; struct axi_dmac_init tx2_dmac_init = { "tx_dmac", TX2_DMA_BASEADDR, DMA_MEM_TO_DEV, DMA_CYCLIC, }; #endif Xil_ICacheEnable(); Xil_DCacheEnable(); printf("Hello\n"); memset(&phy, 0, sizeof(struct adrv9002_rf_phy)); #if defined(ADRV9002_RX2TX2) phy.rx2tx2 = true; #endif ret = adrv9002_setup(&phy, adrv9002_init_get()); if (ret) return ret; adi_adrv9001_ApiVersion_Get(phy.adrv9001, &api_version); adi_adrv9001_arm_Version(phy.adrv9001, &arm_version); adi_adrv9001_SiliconVersion_Get(phy.adrv9001, &silicon_version); printf("%s Rev %d.%d, Firmware %u.%u.%u.%u API version: %u.%u.%u successfully initialized\n", "ADRV9002", silicon_version.major, silicon_version.minor, arm_version.majorVer, arm_version.minorVer, arm_version.maintVer, arm_version.rcVer, api_version.major, api_version.minor, api_version.patch); /* Initialize the ADC/DAC cores */ ret = axi_adc_init(&phy.rx1_adc, &rx1_adc_init); if (ret) { printf("axi_adc_init() failed with status %d\n", ret); goto error; } ret = axi_dac_init(&phy.tx1_dac, &tx1_dac_init); if (ret) { printf("axi_dac_init() failed with status %d\n", ret); goto error; } phy.tx1_dac->clock_hz = adrv9002_init_get()->tx.txProfile[0].txInputRate_Hz; #ifndef ADRV9002_RX2TX2 ret = axi_adc_init(&phy.rx2_adc, &rx2_adc_init); if (ret) { printf("axi_adc_init() failed with status %d\n", ret); goto error; } ret = axi_dac_init(&phy.tx2_dac, &tx2_dac_init); if (ret) { printf("axi_dac_init() failed with status %d\n", ret); goto error; } phy.tx2_dac->clock_hz = adrv9002_init_get()->tx.txProfile[1].txInputRate_Hz; #endif /* Post AXI DAC/ADC setup, digital interface tuning */ ret = adrv9002_post_setup(&phy); if (ret) { printf("adrv9002_post_setup() failed with status %d\n", ret); goto error; } /* TODO: Remove this when it gets fixed in the API. */ adi_adrv9001_Radio_Channel_ToState(phy.adrv9001, ADI_RX, ADI_CHANNEL_1, ADI_ADRV9001_CHANNEL_PRIMED); adi_adrv9001_Radio_Channel_ToState(phy.adrv9001, ADI_RX, ADI_CHANNEL_1, ADI_ADRV9001_CHANNEL_RF_ENABLED); adi_adrv9001_Radio_Channel_ToState(phy.adrv9001, ADI_RX, ADI_CHANNEL_2, ADI_ADRV9001_CHANNEL_PRIMED); adi_adrv9001_Radio_Channel_ToState(phy.adrv9001, ADI_RX, ADI_CHANNEL_2, ADI_ADRV9001_CHANNEL_RF_ENABLED); /* Initialize the AXI DMA Controller cores */ ret = axi_dmac_init(&phy.tx1_dmac, &tx1_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } ret = axi_dmac_init(&phy.rx1_dmac, &rx1_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } #ifndef ADRV9002_RX2TX2 ret = axi_dmac_init(&phy.tx2_dmac, &tx2_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } ret = axi_dmac_init(&phy.rx2_dmac, &rx2_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } #endif //adi_adrv9001_Radio_Channel_ToRfEnabled(&phy.adrv9001, 1, 0x2); //adi_adrv9001_Tx_AttenuationMode_Set(&phy.adrv9001,0x1, 1); //adi_adrv9001_Tx_Attenuation_Set(&phy.adrv9001, 0x1, 20000 ); #ifdef DAC_DMA_EXAMPLE axi_dac_load_custom_data(phy.tx1_dac, sine_lut_iq, ARRAY_SIZE(sine_lut_iq), DAC1_DDR_BASEADDR); #ifndef ADRV9002_RX2TX2 axi_dac_load_custom_data(phy.tx2_dac, sine_lut_iq, ARRAY_SIZE(sine_lut_iq), DAC2_DDR_BASEADDR); #endif Xil_DCacheFlush(); axi_dmac_transfer(phy.tx1_dmac, DAC1_DDR_BASEADDR, sizeof(sine_lut_iq)); #ifndef ADRV9002_RX2TX2 axi_dmac_transfer(phy.tx2_dmac, DAC2_DDR_BASEADDR, sizeof(sine_lut_iq)); #endif mdelay(1000); /* Transfer 16384 samples from ADC to MEM */ axi_dmac_transfer(phy.rx1_dmac, ADC1_DDR_BASEADDR, 16384 * /* nr of samples */ #ifndef ADRV9002_RX2TX2 ADRV9001_NUM_SUBCHANNELS * /* rx1 i/q */ #else ADRV9001_NUM_CHANNELS * /* rx1 i/q, rx2 i/q*/ #endif 2 /* bytes per sample */); Xil_DCacheInvalidateRange(ADC1_DDR_BASEADDR, 16384 * /* nr of samples */ #ifndef ADRV9002_RX2TX2 ADRV9001_NUM_SUBCHANNELS * /* rx1 i/q */ #else ADRV9001_NUM_CHANNELS * /* rx1 i/q, rx2 i/q*/ #endif 2 /* bytes per sample */); #ifndef ADRV9002_RX2TX2 axi_dmac_transfer(phy.rx2_dmac, ADC2_DDR_BASEADDR, 16384 * /* nr of samples */ ADRV9001_NUM_SUBCHANNELS * /* nr of channels */ 2 /* bytes per sample */); Xil_DCacheInvalidateRange(ADC2_DDR_BASEADDR, 16384 * /* nr of samples */ ADRV9001_NUM_SUBCHANNELS * /* nr of channels */ 2 /* bytes per sample */); #endif #endif #ifdef IIO_SUPPORT printf("The board accepts libiio clients connections through the serial backend.\n"); struct iio_axi_adc_init_param iio_axi_adc1_init_par = { .rx_adc = phy.rx1_adc, .rx_dmac = phy.rx1_dmac, .dcache_invalidate_range = (void (*)(uint32_t, uint32_t))Xil_DCacheInvalidateRange, .get_sampling_frequency = get_sampling_frequency, }; struct iio_axi_dac_init_param iio_axi_dac1_init_par = { .tx_dac = phy.tx1_dac, .tx_dmac = phy.tx1_dmac, .dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange, }; #ifndef ADRV9002_RX2TX2 struct iio_axi_adc_init_param iio_axi_adc2_init_par = { .rx_adc = phy.rx2_adc, .rx_dmac = phy.rx2_dmac, .dcache_invalidate_range = (void (*)(uint32_t, uint32_t))Xil_DCacheInvalidateRange, .get_sampling_frequency = get_sampling_frequency, }; struct iio_axi_dac_init_param iio_axi_dac2_init_par = { .tx_dac = phy.tx2_dac, .tx_dmac = phy.tx2_dmac, .dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange, }; ret = iio_server_init(&iio_axi_adc1_init_par, &iio_axi_adc2_init_par, &iio_axi_dac1_init_par, &iio_axi_dac2_init_par); #else ret = iio_server_init(&iio_axi_adc1_init_par, NULL, &iio_axi_dac1_init_par, NULL); #endif #endif printf("Bye\n"); error: adi_adrv9001_HwClose(phy.adrv9001); axi_adc_remove(phy.rx1_adc); axi_dac_remove(phy.tx1_dac); axi_adc_remove(phy.rx2_adc); axi_dac_remove(phy.tx2_dac); axi_dmac_remove(phy.rx1_dmac); axi_dmac_remove(phy.tx1_dmac); axi_dmac_remove(phy.rx2_dmac); axi_dmac_remove(phy.tx2_dmac); return ret; }
/***************************************************************************//** * @file headless.c * @brief adrv9002 main project file. * @author Darius Berghe (darius.berghe@analog.com) ******************************************************************************** * Copyright 2020(c) Analog Devices, Inc. * * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions are met: * - Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * - Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in * the documentation and/or other materials provided with the * distribution. * - Neither the name of Analog Devices, Inc. nor the names of its * contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * - The use of this software may or may not infringe the patent rights * of one or more patent holders. This license does not release you * from the requirement that you obtain separate licenses from these * patent holders to use this software. * - Use of the software either in source or binary form, must be run * on or directly connected to an Analog Devices Inc. component. * * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT, * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT, * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *******************************************************************************/ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <inttypes.h> #include <stdint.h> #ifdef XILINX_PLATFORM #include "xil_cache.h" #endif /* XILINX_PLATFORM */ #include "no_os_error.h" #include "no_os_util.h" #include "no_os_spi.h" #include "axi_adc_core.h" #include "axi_dac_core.h" #include "axi_dmac.h" #include "parameters.h" #ifdef IIO_SUPPORT #include "iio_app.h" #include "iio_axi_adc.h" #include "iio_axi_dac.h" #include "xilinx_uart.h" #endif #include "adrv9002.h" #include "adi_adrv9001.h" #include "adi_adrv9001_arm.h" #include "adi_adrv9001_radio.h" #include "adi_adrv9001_profileutil.h" //#include "Navassa_CMOS_profile.h" #include "Navassa_LVDS_profile.h" /* ADC/DAC Buffers */ #if defined(DMA_EXAMPLE) || defined(IIO_SUPPORT) static uint32_t dac_buffers[IIO_DEV_COUNT][DAC_BUFFER_SAMPLES] __attribute__((aligned)); static uint16_t adc_buffers[IIO_DEV_COUNT][ADC_BUFFER_SAMPLES] __attribute__((aligned)); #endif uint64_t sampling_freq; int get_sampling_frequency(struct axi_adc *dev, uint32_t chan, uint64_t *sampling_freq_hz) { if (!dev || !sampling_freq_hz) return -EINVAL; *sampling_freq_hz = sampling_freq; return 0; } static struct adi_adrv9001_SpiSettings spiSettings = { .msbFirst = 1, .enSpiStreaming = 0, .autoIncAddrUp = 1, .fourWireMode = 1, .cmosPadDrvStrength = ADI_ADRV9001_CMOSPAD_DRV_STRONG, }; struct adi_adrv9001_SpiSettings *adrv9002_spi_settings_get(void) { return &spiSettings; } enum adi_adrv9001_SsiType adrv9002_ssi_type_detect(struct adrv9002_rf_phy *phy) { enum adi_adrv9001_SsiType ssi, ssi2; char *ssi_str[3] = { "[SSI Disabled]", "CMOS", "LVDS" }; ssi = adrv9002_axi_ssi_type_get(phy); ssi2 = phy->curr_profile->rx.rxChannelCfg[0].profile.rxSsiConfig.ssiType; if (ssi != ssi2) { printf("SSI mismatch: detected %s in HDL and %s in profile.\n", ssi_str[ssi], ssi_str[ssi2]); return ADI_ADRV9001_SSI_TYPE_DISABLE; } return ssi; } static struct adi_adrv9001_GainControlCfg agc_defaults = { .peakWaitTime = 4, .maxGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MAX, .minGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MIN, .gainUpdateCounter = 11520, .attackDelay_us = 10, .lowThreshPreventGainInc = false, .slowLoopSettlingDelay = 16, .changeGainIfThreshHigh = 3, .agcMode = 1, .resetOnRxon = false, .resetOnRxonGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MAX, .enableSyncPulseForGainCounter = false, .enableFastRecoveryLoop = false, .power = { .powerEnableMeasurement = true, .underRangeHighPowerThresh = 10, .underRangeLowPowerThresh = 4, .underRangeHighPowerGainStepRecovery = 2, .underRangeLowPowerGainStepRecovery = 4, .powerMeasurementDuration = 10, .powerMeasurementDelay = 2, .rxTddPowerMeasDuration = 0, .rxTddPowerMeasDelay = 0, .overRangeHighPowerThresh = 0, .overRangeLowPowerThresh = 7, .overRangeHighPowerGainStepAttack = 4, .overRangeLowPowerGainStepAttack = 4, .feedback_inner_high_inner_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED, .feedback_apd_high_apd_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED, }, .peak = { .agcUnderRangeLowInterval = 50, .agcUnderRangeMidInterval = 2, .agcUnderRangeHighInterval = 4, .apdHighThresh = 21, .apdLowThresh = 12, .apdUpperThreshPeakExceededCount = 6, .apdLowerThreshPeakExceededCount = 3, .apdGainStepAttack = 2, .apdGainStepRecovery = 0, .enableHbOverload = true, .hbOverloadDurationCount = 1, .hbOverloadThreshCount = 1, .hbHighThresh = 13044, .hbUnderRangeLowThresh = 5826, .hbUnderRangeMidThresh = 8230, .hbUnderRangeHighThresh = 7335, .hbUpperThreshPeakExceededCount = 6, .hbUnderRangeHighThreshExceededCount = 3, .hbGainStepHighRecovery = 2, .hbGainStepLowRecovery = 6, .hbGainStepMidRecovery = 4, .hbGainStepAttack = 2, .hbOverloadPowerMode = 0, .hbUnderRangeMidThreshExceededCount = 3, .hbUnderRangeLowThreshExceededCount = 3, .feedback_apd_low_hb_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED, .feedback_apd_high_hb_high = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED, }, }; #ifdef IIO_SUPPORT static int32_t iio_run(struct iio_axi_adc_init_param *adc_pars, struct iio_axi_dac_init_param *dac_pars) { struct iio_axi_adc_desc *adcs[IIO_DEV_COUNT]; struct iio_axi_dac_desc *dacs[IIO_DEV_COUNT]; struct iio_data_buffer iio_dac_buffers[IIO_DEV_COUNT]; struct iio_data_buffer iio_adc_buffers[IIO_DEV_COUNT]; struct iio_device *iio_descs[IIO_DEV_COUNT * 2]; struct iio_app_device app_devices[IIO_DEV_COUNT * 2] = {0}; struct xil_uart_init_param platform_uart_init_par = { .type = UART_PS, .irq_id = UART_IRQ_ID }; struct no_os_uart_init_param iio_uart_ip = { .device_id = UART_DEVICE_ID, .irq_id = UART_IRQ_ID, .baud_rate = UART_BAUDRATE, .size = NO_OS_UART_CS_8, .parity = NO_OS_UART_PAR_NO, .stop = NO_OS_UART_STOP_1_BIT, .extra = &platform_uart_init_par, .platform_ops = &xil_uart_ops }; struct iio_app_desc *app; struct iio_app_init_param app_init_param = { 0 }; int32_t i, ret; int32_t a; // linear iterator for iio_descs and app_devices flat arrays for (i = 0; i < IIO_DEV_COUNT; i++) { /* ADC setup */ iio_adc_buffers[i].buff = adc_buffers[i]; iio_adc_buffers[i].size = sizeof(adc_buffers[i]); ret = iio_axi_adc_init(&adcs[i], &adc_pars[i]); if (ret < 0) return ret; a = 2 * i; iio_axi_adc_get_dev_descriptor(adcs[i], &iio_descs[a]); app_devices[a].name = adc_pars[i].rx_adc->name; app_devices[a].dev = adcs[i]; app_devices[a].dev_descriptor = iio_descs[a]; app_devices[a].read_buff = &iio_adc_buffers[i]; /* DAC setup */ iio_dac_buffers[i].buff = dac_buffers[i]; iio_dac_buffers[i].size = sizeof(dac_buffers[i]); ret = iio_axi_dac_init(&dacs[i], &dac_pars[i]); if (ret < 0) return ret; a = 2 * i + 1; iio_axi_dac_get_dev_descriptor(dacs[i], &iio_descs[a]); app_devices[a].name = dac_pars[i].tx_dac->name; app_devices[a].dev = dacs[i]; app_devices[a].dev_descriptor = iio_descs[a]; app_devices[a].write_buff = &iio_dac_buffers[i]; } app_init_param.devices = app_devices; app_init_param.nb_devices = NO_OS_ARRAY_SIZE(app_devices); app_init_param.uart_init_params = iio_uart_ip; ret = iio_app_init(&app, app_init_param); if (ret) return ret; return iio_app_run(app); } #endif int main(void) { int ret; struct adi_common_ApiVersion api_version; struct adi_adrv9001_ArmVersion arm_version; struct adi_adrv9001_SiliconVersion silicon_version; struct adi_adrv9001_Device adrv9001_device = {0}; struct adrv9002_chip_info chip = {0}; struct adrv9002_rf_phy phy = {0}; unsigned int c; struct axi_adc_init rx1_adc_init = { .name = "axi-adrv9002-rx-lpc", .base = RX1_ADC_BASEADDR, .num_channels = ADRV9001_I_Q_CHANNELS, }; struct axi_dac_channel tx1_dac_channels[2]; tx1_dac_channels[0].sel = AXI_DAC_DATA_SEL_DDS ;// AXI_DAC_DATA_SEL_DMA; tx1_dac_channels[1].sel = AXI_DAC_DATA_SEL_DDS; struct axi_dac_init tx1_dac_init = { .name = "axi-adrv9002-tx-lpc", .base = TX1_DAC_BASEADDR, .num_channels = ADRV9001_I_Q_CHANNELS, .channels = tx1_dac_channels, .rate = 3 }; #ifndef ADRV9002_RX2TX2 struct axi_adc_init rx2_adc_init = { .name = "axi-adrv9002-rx2-lpc", .base = RX2_ADC_BASEADDR, .num_channels = ADRV9001_I_Q_CHANNELS, }; struct axi_dac_channel tx2_dac_channels[2]; tx2_dac_channels[0].sel = AXI_DAC_DATA_SEL_DMA; tx2_dac_channels[1].sel = AXI_DAC_DATA_SEL_DMA; struct axi_dac_init tx2_dac_init = { .name = "axi-adrv9002-tx2-lpc", .base = TX2_DAC_BASEADDR, .num_channels = ADRV9001_I_Q_CHANNELS, .channels = tx2_dac_channels, .rate = 3 }; #endif struct axi_dmac_init rx1_dmac_init = { "rx_dmac", RX1_DMA_BASEADDR, IRQ_DISABLED }; struct axi_dmac_init tx1_dmac_init = { "tx_dmac", TX1_DMA_BASEADDR, IRQ_DISABLED }; #ifndef ADRV9002_RX2TX2 struct axi_dmac_init rx2_dmac_init = { "rx_dmac", RX2_DMA_BASEADDR, IRQ_DISABLED }; struct axi_dmac_init tx2_dmac_init = { "tx_dmac", TX2_DMA_BASEADDR, IRQ_DISABLED }; #endif #ifdef XILINX_PLATFORM Xil_ICacheEnable(); Xil_DCacheEnable(); #endif /* XILINX_PLATFORM */ printf("Hello\n"); #if defined(ADRV9002_RX2TX2) phy.rx2tx2 = true; #endif phy.adrv9001 = &adrv9001_device; /* ADRV9002 */ chip.cmos_profile = "Navassa_CMOS_profile.json"; chip.lvd_profile = "Navassa_LVDS_profile.json"; chip.name = "adrv9002-phy"; chip.n_tx = ADRV9002_CHANN_MAX; phy.chip = &chip; ret = adi_adrv9001_profileutil_Parse(phy.adrv9001, &phy.profile, (char *)json_profile, strlen(json_profile)); if (ret) goto error; phy.curr_profile = &phy.profile; sampling_freq = phy.curr_profile->rx.rxChannelCfg[0].profile.rxOutputRate_Hz; printf("%" PRIu64 "\n", sampling_freq); /* Initialize the ADC/DAC cores */ ret = axi_adc_init_begin(&phy.rx1_adc, &rx1_adc_init); if (ret) { printf("axi_adc_init_begin() failed with status %d\n", ret); goto error; } ret = axi_dac_init_begin(&phy.tx1_dac, &tx1_dac_init); if (ret) { printf("axi_dac_init_begin() failed with status %d\n", ret); goto error; } #ifndef ADRV9002_RX2TX2 ret = axi_adc_init_begin(&phy.rx2_adc, &rx2_adc_init); if (ret) { printf("axi_adc_init_begin() failed with status %d\n", ret); goto error; } ret = axi_dac_init_begin(&phy.tx2_dac, &tx2_dac_init); if (ret) { printf("axi_dac_init_begin() failed with status %d\n", ret); goto error; } #endif phy.ssi_type = adrv9002_ssi_type_detect(&phy); if (phy.ssi_type == ADI_ADRV9001_SSI_TYPE_DISABLE) goto error; /* Initialize AGC */ for (c = 0; c < ADRV9002_CHANN_MAX; c++) { phy.rx_channels[c].agc = agc_defaults; } ret = adrv9002_setup(&phy); if (ret) return ret; adi_adrv9001_ApiVersion_Get(phy.adrv9001, &api_version); adi_adrv9001_arm_Version(phy.adrv9001, &arm_version); adi_adrv9001_SiliconVersion_Get(phy.adrv9001, &silicon_version); printf("%s Rev %d.%d, Firmware %u.%u.%u.%u API version: %u.%u.%u successfully initialized\n", "ADRV9002", silicon_version.major, silicon_version.minor, arm_version.majorVer, arm_version.minorVer, arm_version.maintVer, arm_version.rcVer, api_version.major, api_version.minor, api_version.patch); /* Post AXI DAC/ADC setup, digital interface tuning */ ret = adrv9002_post_setup(&phy); if (ret) { printf("adrv9002_post_setup() failed with status %d\n", ret); goto error; } /* Finalize the ADC/DAC cores initialization */ ret = axi_adc_init_finish(phy.rx1_adc); if (ret) { printf("axi_adc_init_finish() failed with status %d\n", ret); goto error; } ret = axi_dac_init_finish(phy.tx1_dac); if (ret) { printf("axi_dac_init_finish() failed with status %d\n", ret); goto error; } phy.tx1_dac->clock_hz = phy.curr_profile->tx.txProfile[0].txInputRate_Hz; #ifndef ADRV9002_RX2TX2 ret = axi_adc_init_finish(phy.rx2_adc); if (ret) { printf("axi_adc_init_finish() failed with status %d\n", ret); goto error; } ret = axi_dac_init_finish(phy.tx2_dac); if (ret) { printf("axi_dac_init_finish() failed with status %d\n", ret); goto error; } phy.tx2_dac->clock_hz = phy.curr_profile->tx.txProfile[1].txInputRate_Hz; #endif /* Initialize the AXI DMA Controller cores */ ret = axi_dmac_init(&phy.tx1_dmac, &tx1_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } ret = axi_dmac_init(&phy.rx1_dmac, &rx1_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } #ifndef ADRV9002_RX2TX2 ret = axi_dmac_init(&phy.tx2_dmac, &tx2_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } ret = axi_dmac_init(&phy.rx2_dmac, &rx2_dmac_init); if (ret) { printf("axi_dmac_init() failed with status %d\n", ret); goto error; } #endif #ifdef DMA_EXAMPLE axi_dac_load_custom_data(phy.tx1_dac, sine_lut_iq, NO_OS_ARRAY_SIZE(sine_lut_iq), (uintptr_t)dac_buffers[0]); #ifndef ADRV9002_RX2TX2 axi_dac_load_custom_data(phy.tx2_dac, sine_lut_iq, NO_OS_ARRAY_SIZE(sine_lut_iq), (uintptr_t)dac_buffers[1]); #endif #ifdef XILINX_PLATFORM Xil_DCacheFlush(); #endif /* XILINX_PLATFORM */ struct axi_dma_transfer transfer1 = { // Number of bytes to write/read .size = sizeof(sine_lut_iq), // Transfer done flag .transfer_done = 0, // Signal transfer mode .cyclic = CYCLIC, // Address of data source .src_addr = (uintptr_t)dac_buffers[0], // Address of data destination .dest_addr = 0 }; axi_dmac_transfer_start(phy.tx1_dmac, &transfer1); #ifndef ADRV9002_RX2TX2 struct axi_dma_transfer transfer2 = { // Number of bytes to write/read .size = sizeof(sine_lut_iq), // Transfer done flag .transfer_done = 0, // Signal transfer mode .cyclic = CYCLIC, // Address of data source .src_addr = (uintptr_t)dac_buffers[1], // Address of data destination .dest_addr = 0 }; axi_dmac_transfer_start(phy.tx2_dmac, &transfer2); #endif #ifdef XILINX_PLATFORM Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[0], sizeof(sine_lut_iq)); #ifndef ADRV9002_RX2TX2 Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[1], sizeof(sine_lut_iq)); #endif #endif /* XILINX_PLATFORM */ no_os_mdelay(1000); struct axi_dma_transfer read_transfer1 = { // Number of bytes to write/read .size = ADC_BUFFER_SAMPLES * ADRV9001_I_Q_CHANNELS * 2, /* nr of samples * rx1 i/q, rx2 i/q * bytes per sample */ // Transfer done flag .transfer_done = 0, // Signal transfer mode .cyclic = NO, // Address of data source .src_addr = 0, // Address of data destination .dest_addr = (uintptr_t)adc_buffers[0] }; /* Transfer ADC_BUFFER_SAMPLES samples from ADC to MEM */ #ifdef ADRV9002_RX2TX2 axi_adc_update_active_channels(phy.rx1_adc, 0xf); #else axi_adc_update_active_channels(phy.rx1_adc, 0x3); #endif axi_dmac_transfer_start(phy.rx1_dmac, &read_transfer1); ret = axi_dmac_transfer_wait_completion(phy.rx1_dmac, 500); if(ret) return ret; #ifdef XILINX_PLATFORM Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[0], ADC_BUFFER_SAMPLES * /* nr of samples */ ADRV9001_I_Q_CHANNELS * /* rx1 i/q, rx2 i/q*/ 2 /* bytes per sample */); #endif /* XILINX_PLATFORM */ #ifndef ADRV9002_RX2TX2 struct axi_dma_transfer read_transfer2 = { // Number of bytes to write/read .size = ADC_BUFFER_SAMPLES * ADRV9001_I_Q_CHANNELS * 2, /* nr of samples * rx1 i/q, rx2 i/q * bytes per sample */ // Transfer done flag .transfer_done = 0, // Signal transfer mode .cyclic = NO, // Address of data source .src_addr = 0, // Address of data destination .dest_addr = (uintptr_t)adc_buffers[1] }; axi_adc_update_active_channels(phy.rx2_adc, 0x3); axi_dmac_transfer_start(phy.rx2_dmac,&read_transfer2); ret = axi_dmac_transfer_wait_completion(phy.rx2_dmac, 500); if(ret) return ret; #ifdef XILINX_PLATFORM Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[1], ADC_BUFFER_SAMPLES * /* nr of samples */ ADRV9001_I_Q_CHANNELS * /* nr of channels */ 2 /* bytes per sample */); #endif /* XILINX_PLATFORM */ printf("DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n", (uintptr_t)adc_buffers[1], ADC_BUFFER_SAMPLES * rx2_adc_init.num_channels, rx2_adc_init.num_channels, 8 * sizeof(adc_buffers[1][0])); #endif printf("DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n", (uintptr_t)adc_buffers[0], ADC_BUFFER_SAMPLES * rx1_adc_init.num_channels, rx1_adc_init.num_channels, 8 * sizeof(adc_buffers[0][0])); #endif #ifdef IIO_SUPPORT struct iio_axi_adc_init_param iio_axi_adcs_init_par[] = {{ .rx_adc = phy.rx1_adc, .rx_dmac = phy.rx1_dmac, #ifdef XILINX_PLATFORM .dcache_invalidate_range = (void (*)(uint32_t, uint32_t))Xil_DCacheInvalidateRange, #endif /* XILINX_PLATFORM */ .get_sampling_frequency = get_sampling_frequency, }, #ifndef ADRV9002_RX2TX2 { .rx_adc = phy.rx2_adc, .rx_dmac = phy.rx2_dmac, #ifdef XILINX_PLATFORM .dcache_invalidate_range = (void (*)(uint32_t, uint32_t))Xil_DCacheInvalidateRange, #endif /* XILINX_PLATFORM */ .get_sampling_frequency = get_sampling_frequency, } #endif }; struct iio_axi_dac_init_param iio_axi_dacs_init_par[] = {{ .tx_dac = phy.tx1_dac, .tx_dmac = phy.tx1_dmac, #ifdef XILINX_PLATFORM .dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange, #endif /* XILINX_PLATFORM */ }, #ifndef ADRV9002_RX2TX2 { .tx_dac = phy.tx2_dac, .tx_dmac = phy.tx2_dmac, #ifdef XILINX_PLATFORM .dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange, #endif /* XILINX_PLATFORM */ } #endif }; ret = iio_run(iio_axi_adcs_init_par, iio_axi_dacs_init_par); if (ret < 0) { printf("iio_run() failed with status %d\n", ret); goto error; } #endif printf("Bye\n"); error: adi_adrv9001_HwClose(phy.adrv9001); axi_adc_remove(phy.rx1_adc); axi_dac_remove(phy.tx1_dac); axi_adc_remove(phy.rx2_adc); axi_dac_remove(phy.tx2_dac); axi_dmac_remove(phy.rx1_dmac); axi_dmac_remove(phy.tx1_dmac); axi_dmac_remove(phy.rx2_dmac); axi_dmac_remove(phy.tx2_dmac); return ret; }
