Guidance on Porting FMCDAQ3 Application from No-OS to FreeRTOS
The user seeks guidance on porting the FMCDAQ3 reference design from No-OS to FreeRTOS, specifically asking about required modifications to driver files, FreeRTOS-specific adaptations, and available reference materials. The final answer indicates the inquiry will be forwarded to the Microcontroller No-OS Drivers forum for further support. No specific technical solutions or resources are provided in the thread.
Product Number: AD9152
Hi Team,
I have successfully implemented the FMCDAQ3 reference design on the ZCU102 platform using the No-OS driver files provided in your GitHub repository.
One of my existing applications is currently running on FreeRTOS. To maintain consistency across my projects, I am planning to port the FMCDAQ3 application from No-OS to FreeRTOS.
I would appreciate your guidance on the following points:
  1. Which driver source files and header files typically require modification when migrating from No-OS to FreeRTOS?
  2. Are there any FreeRTOS-specific adaptations needed for platform abstraction, interrupt handling, timing, or SPI/UART drivers?
  3. Do you have any reference source files, examples, or application notes that demonstrate FMCDAQ3 or similar platforms running on FreeRTOS?
Any guidance or shared resources would be greatly appreciated and would help accelerate the integration on my end.
Thank you for your support.
Aravind
Thread Notes
