Issues in building NO-OS driver.
The user encountered build errors for the no-OS project on a ZCU102 board with the ADRV9001 transceiver due to Windows compatibility issues. The solution involved removing the --transform 's/^(\.\/|\.)//' option from two tar commands in xilinx.mk. After this change, the project built successfully.
While building no-os project for zcu102 with adrv9001 transceiver,  i'm getting below error msgs. I am also attaching the ss of the error. Kindly look into it.
Error msgs:
[00:00:00] [CC] no_os_util.c
[00:00:00] [LD] no_os_gpio.o no_os_spi.o axi_adc_core.o axi_dac_core.o axi_dmac.o xilinx_axi_io.o xilinx_delay.o xilinx_gpio.o xilinx_spi.o adrv9002.o adrv9002_conv.o adi_common_error.o adi_common_hal_wrapper.o adi_common_log.o adrv9001_arm.o adrv9001_bf_hal.o adrv9001_crc32.o adrv9001_gpio.o adrv9001_init.o adrv9001_rx.o adrv9001_validators.o adi_adrv9001.o adi_adrv9001_arm.o adi_adrv9001_auxadc.o adi_adrv9001_auxdac.o adi_adrv9001_bbdc.o adi_adrv9001_cals.o adi_adrv9001_common.o adi_adrv9001_dpd.o adi_adrv9001_fh.o adi_adrv9001_gpio.o adi_adrv9001_mcs.o adi_adrv9001_orx.o adi_adrv9001_powermanagement.o adi_adrv9001_powersavingandmonitormode.o adi_adrv9001_profileutil.o adi_adrv9001_radio.o adi_adrv9001_rx.o adi_adrv9001_rx_gaincontrol.o adi_adrv9001_spi.o adi_adrv9001_ssi.o adi_adrv9001_stream.o adi_adrv9001_tx.o adi_adrv9001_utilities.o jsmn.o headless.o no_os_platform.o no_os_alloc.o no_os_clk.o no_os_mutex.o no_os_util.o
make[2]: Nothing to be done for 'post_build'.
[00:00:00] Creating BOOT.BIN and archive with files
'\.\)' is not recognized as an internal or external command,
operable program or batch file.
make[1]: *** [D:/Vivado-proj/no-OS/tools/scripts/xilinx.mk:243: create_boot_bin] Error 255
make: *** [../../tools/scripts/generic.mk:334: all] Error 2
regards,
Anurag
  • Hello,
    It looks like you are trying to build from Windows, while no-OS build system assumes a Linux environment, so we can see some compatibility issues.
    What you can try is to remove the --transform 's/^\(\.\/\|\.\)//' option from two tar commands in xilinx.mk: line 323 and 330, should look something like this:
    	$(call copy_file,$(HARDWARE),$(BOOT_BIN_DIR)) $(HIDE)
    	$(call copy_file,$(FSBL_PATH),$(BOOT_BIN_DIR)) $(HIDE)
    	$(call copy_file,$(BINARY),$(BOOT_BIN_DIR)) $(HIDE)
    	tar -czvf $(BUILD_DIR)/bootgen_sysfiles.tar.gz --force-local --exclude 'BOOT.BIN' -C $(BOOT_BIN_DIR) . $(HIDE)
    else
    	$(call print,Creating archive with files)
    	$(call remove_dir,$(BUILD_DIR)/boot_files) $(HIDE)
    	$(call mk_dir,$(BUILD_DIR)/boot_files) $(HIDE)
    	$(call copy_file,$(HARDWARE),$(BUILD_DIR)/boot_files) $(HIDE)
    	$(call copy_file,$(BINARY),$(BUILD_DIR)/boot_files) $(HIDE)
    	tar -czvf $(BUILD_DIR)/bootgen_sysfiles.tar.gz --force-local -C $(BUILD_DIR)/boot_files . $(HIDE)
    endif
    I think the  --transform 's/^\(\.\/\|\.\)//' is purely cosmetic. If it works, for you, I will provide a permanent fix.
  • Hi
    I removed the --transform 's/^\(\.\/\|\.\)//' options from two tar commands in xilinx.mk. After doing this the project got build correctly. Now can i proceed further ? or else you would provide a permanent fix?
    regards,
    Anurag
  • Please proceed. I will provide a fix, but needs to get through the internal review first and it might take a couple of days until it is approved and merged on the mainline.
  • Hi
    I have successfully built the HDL and NO-OS project in two different environments: Vivado/SDK 2019.1 and Vivado/Vitis 2022.2.
    The Problem:
    Upon launching the code on the hardware, the initialization sequence appears successful. The Vitis/SDK serial terminal shows the expected prints and initialization logs. However, when monitoring the output via a Signal Analyzer at the desired carrier frequency, there is no signal detected (only LO leakage is seen at the carrier frequency).
    Hardware Setup:
    • Carrier Board: [ZCU102]
    • RF Transceiver: [ADRV9002]
    Observations:
    1. Software: The No-OS state machine completes without returning error codes.
    2. RF Output: No signal at the SMA connectors. I have verified the cables and the signal analyzer settings.
      I have attached the headless main.c files for both versions and the corresponding Vitis terminal logs. I am concerned that I may be missing a critical function call required to transition the signal from the 'Ready' state to Transmitting. Kindly look into it.
      Headless_2019:
       *   @file   headless.c
       *   @brief  adrv9002 main project file.
       *   @author Darius Berghe (darius.berghe@analog.com)
       * Copyright 2020(c) Analog Devices, Inc.
       * All rights reserved.
       * Redistribution and use in source and binary forms, with or without
       * modification, are permitted provided that the following conditions are met:
       *  - Redistributions of source code must retain the above copyright
       *    notice, this list of conditions and the following disclaimer.
       *  - Redistributions in binary form must reproduce the above copyright
       *    notice, this list of conditions and the following disclaimer in
       *    the documentation and/or other materials provided with the
       *    distribution.
       *  - Neither the name of Analog Devices, Inc. nor the names of its
       *    contributors may be used to endorse or promote products derived
       *    from this software without specific prior written permission.
       *  - The use of this software may or may not infringe the patent rights
       *    of one or more patent holders.  This license does not release you
       *    from the requirement that you obtain separate licenses from these
       *    patent holders to use this software.
       *  - Use of the software either in source or binary form, must be run
       *    on or directly connected to an Analog Devices Inc. component.
       * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
       * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
       * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
       * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
       * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
       * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
       * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
       * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
       * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
       * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
      #include <stdio.h>
      #include <stdlib.h>
      #include <string.h>
      #include "xil_cache.h"
      #include "error.h"
      #include "util.h"
      #include "spi.h"
      #include "axi_adc_core.h"
      #include "axi_dac_core.h"
      #include "axi_dmac.h"
      #include "parameters.h"
      #ifdef IIO_SUPPORT
      #include "app_iio.h"
      #endif
      #include "adrv9002.h"
      #include "adi_adrv9001.h"
      #include "adi_adrv9001_arm.h"
      #include "adi_adrv9001_radio.h"
      #include "adi_adrv9001_tx.h"
      int get_sampling_frequency(struct axi_adc *dev, uint32_t chan,
      			   uint64_t *sampling_freq_hz)
      	if (!dev || !sampling_freq_hz)
      		return -EINVAL;
      	*sampling_freq_hz =
      		adrv9002_init_get()->rx.rxChannelCfg[chan].profile.rxOutputRate_Hz;
      	return SUCCESS;
      int main(void)
      	int ret;
      	struct adi_common_ApiVersion api_version;
      	struct adi_adrv9001_ArmVersion arm_version;
      	struct adi_adrv9001_SiliconVersion silicon_version;
      	struct adrv9002_rf_phy phy;
      	struct axi_adc_init rx1_adc_init = {
      		"axi-adrv9002-rx-lpc",
      		RX1_ADC_BASEADDR,
      #ifndef ADRV9002_RX2TX2
      		ADRV9001_NUM_SUBCHANNELS,
      #else
      		ADRV9001_NUM_CHANNELS,
      #endif
      	struct axi_dac_channel  tx1_dac_channels[2];
      	tx1_dac_channels[0].sel = AXI_DAC_DATA_SEL_DMA;
      	tx1_dac_channels[1].sel = AXI_DAC_DATA_SEL_DMA;
      	struct axi_dac_init tx1_dac_init = {
      		"axi-adrv9002-tx-lpc",
      		TX1_DAC_BASEADDR,
      #else
      #endif
      		tx1_dac_channels,
      	struct axi_adc_init rx2_adc_init = {
      		"axi-adrv9002-rx2-lpc",
      		RX2_ADC_BASEADDR,
      	struct axi_dac_channel  tx2_dac_channels[2];
      	tx2_dac_channels[0].sel = AXI_DAC_DATA_SEL_DMA;
      	tx2_dac_channels[1].sel = AXI_DAC_DATA_SEL_DMA;
      	struct axi_dac_init tx2_dac_init = {
      		"axi-adrv9002-tx2-lpc",
      		TX2_DAC_BASEADDR,
      		tx2_dac_channels,
      #endif
      	struct axi_dmac_init rx1_dmac_init = {
      		"rx_dmac",
      		RX1_DMA_BASEADDR,
      		DMA_DEV_TO_MEM,
      		0
      	struct axi_dmac_init tx1_dmac_init = {
      		"tx_dmac",
      		TX1_DMA_BASEADDR,
      		DMA_MEM_TO_DEV,
      		DMA_CYCLIC,
      	struct axi_dmac_init rx2_dmac_init = {
      		"rx_dmac",
      		RX2_DMA_BASEADDR,
      		DMA_DEV_TO_MEM,
      		0
      	struct axi_dmac_init tx2_dmac_init = {
      		"tx_dmac",
      		TX2_DMA_BASEADDR,
      		DMA_MEM_TO_DEV,
      		DMA_CYCLIC,
      #endif
      	Xil_ICacheEnable();
      	Xil_DCacheEnable();
      	printf("Hello\n");
      	memset(&phy, 0, sizeof(struct adrv9002_rf_phy));
      #if defined(ADRV9002_RX2TX2)
      	phy.rx2tx2 = true;
      #endif
      	ret = adrv9002_setup(&phy, adrv9002_init_get());
      	if (ret)
      		return ret;
      	adi_adrv9001_ApiVersion_Get(phy.adrv9001, &api_version);
      	adi_adrv9001_arm_Version(phy.adrv9001, &arm_version);
      	adi_adrv9001_SiliconVersion_Get(phy.adrv9001, &silicon_version);
      	printf("%s Rev %d.%d, Firmware %u.%u.%u.%u API version: %u.%u.%u successfully initialized\n",
      	       "ADRV9002", silicon_version.major, silicon_version.minor,
      	       arm_version.majorVer, arm_version.minorVer,
      	       arm_version.maintVer, arm_version.rcVer, api_version.major,
      	       api_version.minor, api_version.patch);
      	/* Initialize the ADC/DAC cores */
      	ret = axi_adc_init(&phy.rx1_adc, &rx1_adc_init);
      	if (ret) {
      		printf("axi_adc_init() failed with status %d\n", ret);
      		goto error;
      	ret = axi_dac_init(&phy.tx1_dac, &tx1_dac_init);
      	if (ret) {
      		printf("axi_dac_init() failed with status %d\n", ret);
      		goto error;
      	phy.tx1_dac->clock_hz = adrv9002_init_get()->tx.txProfile[0].txInputRate_Hz;
      	ret = axi_adc_init(&phy.rx2_adc, &rx2_adc_init);
      	if (ret) {
      		goto error;
      	ret = axi_dac_init(&phy.tx2_dac, &tx2_dac_init);
      	if (ret) {
      		goto error;
      	phy.tx2_dac->clock_hz = adrv9002_init_get()->tx.txProfile[1].txInputRate_Hz;
      #endif
      	/* Post AXI DAC/ADC setup, digital interface tuning */
      	ret = adrv9002_post_setup(&phy);
      	if (ret) {
      		printf("adrv9002_post_setup() failed with status %d\n", ret);
      		goto error;
      	/* TODO: Remove this when it gets fixed in the API. */
      	adi_adrv9001_Radio_Channel_ToState(phy.adrv9001, ADI_RX,
      					   ADI_CHANNEL_1, ADI_ADRV9001_CHANNEL_PRIMED);
      					   ADI_CHANNEL_1, ADI_ADRV9001_CHANNEL_RF_ENABLED);
      					   ADI_CHANNEL_2, ADI_ADRV9001_CHANNEL_PRIMED);
      					   ADI_CHANNEL_2, ADI_ADRV9001_CHANNEL_RF_ENABLED);
      	/* Initialize the AXI DMA Controller cores */
      	ret = axi_dmac_init(&phy.tx1_dmac, &tx1_dmac_init);
      	if (ret) {
      		printf("axi_dmac_init() failed with status %d\n", ret);
      		goto error;
      	ret = axi_dmac_init(&phy.rx1_dmac, &rx1_dmac_init);
      	if (ret) {
      		goto error;
      	ret = axi_dmac_init(&phy.tx2_dmac, &tx2_dmac_init);
      	if (ret) {
      		goto error;
      	ret = axi_dmac_init(&phy.rx2_dmac, &rx2_dmac_init);
      	if (ret) {
      		goto error;
      #endif
      	//adi_adrv9001_Radio_Channel_ToRfEnabled(&phy.adrv9001, 1, 0x2);
      	//adi_adrv9001_Tx_AttenuationMode_Set(&phy.adrv9001,0x1, 1);
      	//adi_adrv9001_Tx_Attenuation_Set(&phy.adrv9001, 0x1, 20000 );
      #ifdef DAC_DMA_EXAMPLE
      	axi_dac_load_custom_data(phy.tx1_dac, sine_lut_iq,
      				 ARRAY_SIZE(sine_lut_iq),
      				 DAC1_DDR_BASEADDR);
      	axi_dac_load_custom_data(phy.tx2_dac, sine_lut_iq,
      				 DAC2_DDR_BASEADDR);
      #endif
      	Xil_DCacheFlush();
      	axi_dmac_transfer(phy.tx1_dmac, DAC1_DDR_BASEADDR, sizeof(sine_lut_iq));
      	axi_dmac_transfer(phy.tx2_dmac, DAC2_DDR_BASEADDR, sizeof(sine_lut_iq));
      #endif
      	mdelay(1000);
      	/* Transfer 16384 samples from ADC to MEM */
      	axi_dmac_transfer(phy.rx1_dmac,
      			  ADC1_DDR_BASEADDR,
      			  16384 * /* nr of samples */
      			  ADRV9001_NUM_SUBCHANNELS * /* rx1 i/q */
      #else
      			  ADRV9001_NUM_CHANNELS * /* rx1 i/q, rx2 i/q*/
      #endif
      			  2 /* bytes per sample */);
      	Xil_DCacheInvalidateRange(ADC1_DDR_BASEADDR,
      #else
      #endif
      	axi_dmac_transfer(phy.rx2_dmac,
      			  ADC2_DDR_BASEADDR,
      			  ADRV9001_NUM_SUBCHANNELS * /* nr of channels */
      	Xil_DCacheInvalidateRange(ADC2_DDR_BASEADDR,
      #endif
      #endif
      #ifdef IIO_SUPPORT
      	printf("The board accepts libiio clients connections through the serial backend.\n");
      	struct iio_axi_adc_init_param iio_axi_adc1_init_par = {
      		.rx_adc = phy.rx1_adc,
      		.rx_dmac = phy.rx1_dmac,
      		.dcache_invalidate_range = (void (*)(uint32_t, uint32_t))Xil_DCacheInvalidateRange,
      		.get_sampling_frequency = get_sampling_frequency,
      	struct iio_axi_dac_init_param iio_axi_dac1_init_par = {
      		.tx_dac = phy.tx1_dac,
      		.tx_dmac = phy.tx1_dmac,
      		.dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange,
      	struct iio_axi_adc_init_param iio_axi_adc2_init_par = {
      		.rx_adc = phy.rx2_adc,
      		.rx_dmac = phy.rx2_dmac,
      	struct iio_axi_dac_init_param iio_axi_dac2_init_par = {
      		.tx_dac = phy.tx2_dac,
      		.tx_dmac = phy.tx2_dmac,
      	ret = iio_server_init(&iio_axi_adc1_init_par,
      			      &iio_axi_adc2_init_par,
      			      &iio_axi_dac1_init_par,
      			      &iio_axi_dac2_init_par);
      #else
      			      NULL,
      			      NULL);
      #endif
      #endif
      	printf("Bye\n");
      error:
      	adi_adrv9001_HwClose(phy.adrv9001);
      	axi_adc_remove(phy.rx1_adc);
      	axi_dac_remove(phy.tx1_dac);
      	axi_adc_remove(phy.rx2_adc);
      	axi_dac_remove(phy.tx2_dac);
      	axi_dmac_remove(phy.rx1_dmac);
      	axi_dmac_remove(phy.tx1_dmac);
      	axi_dmac_remove(phy.rx2_dmac);
      	axi_dmac_remove(phy.tx2_dmac);
      	return ret;
      Headless_2022:
       *   @file   headless.c
       *    distribution.
      #include <stdio.h>
      #include <stdlib.h>
      #include <string.h>
      #include <inttypes.h>
      #include <stdint.h>
      #ifdef XILINX_PLATFORM
      #endif /* XILINX_PLATFORM */
      #include "no_os_error.h"
      #include "no_os_util.h"
      #include "no_os_spi.h"
      #ifdef IIO_SUPPORT
      #include "iio_app.h"
      #include "iio_axi_adc.h"
      #include "iio_axi_dac.h"
      #include "xilinx_uart.h"
      #endif
      #include "adi_adrv9001_profileutil.h"
      //#include "Navassa_CMOS_profile.h"
      #include "Navassa_LVDS_profile.h"
      /* ADC/DAC Buffers */
      #if defined(DMA_EXAMPLE) || defined(IIO_SUPPORT)
      static uint32_t dac_buffers[IIO_DEV_COUNT][DAC_BUFFER_SAMPLES]
      __attribute__((aligned));
      static uint16_t adc_buffers[IIO_DEV_COUNT][ADC_BUFFER_SAMPLES]
      #endif
      uint64_t sampling_freq;
      		return -EINVAL;
      	*sampling_freq_hz = sampling_freq;
      	return 0;
      static struct adi_adrv9001_SpiSettings spiSettings = {
      	.msbFirst = 1,
      	.enSpiStreaming = 0,
      	.autoIncAddrUp = 1,
      	.fourWireMode = 1,
      	.cmosPadDrvStrength = ADI_ADRV9001_CMOSPAD_DRV_STRONG,
      struct adi_adrv9001_SpiSettings *adrv9002_spi_settings_get(void)
      	return &spiSettings;
      enum adi_adrv9001_SsiType adrv9002_ssi_type_detect(struct adrv9002_rf_phy *phy)
      	enum adi_adrv9001_SsiType ssi, ssi2;
      	char *ssi_str[3] = {
      		"[SSI Disabled]",
      		"CMOS",
      		"LVDS"
      	ssi = adrv9002_axi_ssi_type_get(phy);
      	ssi2 = phy->curr_profile->rx.rxChannelCfg[0].profile.rxSsiConfig.ssiType;
      	if (ssi != ssi2) {
      		printf("SSI mismatch: detected %s in HDL and %s in profile.\n", ssi_str[ssi],
      		       ssi_str[ssi2]);
      		return ADI_ADRV9001_SSI_TYPE_DISABLE;
      	return ssi;
      static struct adi_adrv9001_GainControlCfg agc_defaults = {
      	.peakWaitTime = 4,
      	.maxGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MAX,
      	.minGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MIN,
      	.gainUpdateCounter = 11520,
      	.attackDelay_us = 10,
      	.lowThreshPreventGainInc = false,
      	.slowLoopSettlingDelay = 16,
      	.changeGainIfThreshHigh = 3,
      	.agcMode = 1,
      	.resetOnRxon = false,
      	.resetOnRxonGainIndex = ADI_ADRV9001_RX_GAIN_INDEX_MAX,
      	.enableSyncPulseForGainCounter = false,
      	.enableFastRecoveryLoop = false,
      	.power = {
      		.powerEnableMeasurement = true,
      		.underRangeHighPowerThresh = 10,
      		.underRangeLowPowerThresh = 4,
      		.underRangeHighPowerGainStepRecovery = 2,
      		.underRangeLowPowerGainStepRecovery = 4,
      		.powerMeasurementDuration = 10,
      		.powerMeasurementDelay = 2,
      		.rxTddPowerMeasDuration = 0,
      		.rxTddPowerMeasDelay = 0,
      		.overRangeHighPowerThresh = 0,
      		.overRangeLowPowerThresh = 7,
      		.overRangeHighPowerGainStepAttack = 4,
      		.overRangeLowPowerGainStepAttack = 4,
      		.feedback_inner_high_inner_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED,
      		.feedback_apd_high_apd_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED,
      	.peak = {
      		.agcUnderRangeLowInterval = 50,
      		.agcUnderRangeMidInterval = 2,
      		.agcUnderRangeHighInterval = 4,
      		.apdHighThresh = 21,
      		.apdLowThresh = 12,
      		.apdUpperThreshPeakExceededCount = 6,
      		.apdLowerThreshPeakExceededCount = 3,
      		.apdGainStepAttack = 2,
      		.apdGainStepRecovery = 0,
      		.enableHbOverload = true,
      		.hbOverloadDurationCount = 1,
      		.hbOverloadThreshCount = 1,
      		.hbHighThresh = 13044,
      		.hbUnderRangeLowThresh = 5826,
      		.hbUnderRangeMidThresh = 8230,
      		.hbUnderRangeHighThresh = 7335,
      		.hbUpperThreshPeakExceededCount = 6,
      		.hbUnderRangeHighThreshExceededCount = 3,
      		.hbGainStepHighRecovery = 2,
      		.hbGainStepLowRecovery = 6,
      		.hbGainStepMidRecovery = 4,
      		.hbGainStepAttack = 2,
      		.hbOverloadPowerMode = 0,
      		.hbUnderRangeMidThreshExceededCount = 3,
      		.hbUnderRangeLowThreshExceededCount = 3,
      		.feedback_apd_low_hb_low = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED,
      		.feedback_apd_high_hb_high = ADI_ADRV9001_GPIO_PIN_CRUMB_UNASSIGNED,
      #ifdef IIO_SUPPORT
      static int32_t iio_run(struct iio_axi_adc_init_param *adc_pars,
      		       struct iio_axi_dac_init_param *dac_pars)
      	struct iio_axi_adc_desc *adcs[IIO_DEV_COUNT];
      	struct iio_axi_dac_desc *dacs[IIO_DEV_COUNT];
      	struct iio_data_buffer iio_dac_buffers[IIO_DEV_COUNT];
      	struct iio_data_buffer iio_adc_buffers[IIO_DEV_COUNT];
      	struct iio_device *iio_descs[IIO_DEV_COUNT * 2];
      	struct iio_app_device app_devices[IIO_DEV_COUNT * 2] = {0};
      	struct xil_uart_init_param platform_uart_init_par = {
      		.type = UART_PS,
      		.irq_id = UART_IRQ_ID
      	struct no_os_uart_init_param iio_uart_ip = {
      		.device_id = UART_DEVICE_ID,
      		.irq_id = UART_IRQ_ID,
      		.baud_rate = UART_BAUDRATE,
      		.size = NO_OS_UART_CS_8,
      		.parity = NO_OS_UART_PAR_NO,
      		.stop = NO_OS_UART_STOP_1_BIT,
      		.extra = &platform_uart_init_par,
      		.platform_ops = &xil_uart_ops
      	struct iio_app_desc *app;
      	struct iio_app_init_param app_init_param = { 0 };
      	int32_t i, ret;
      	int32_t a; // linear iterator for iio_descs and app_devices flat arrays
      	for (i = 0; i < IIO_DEV_COUNT; i++) {
      		/* ADC setup */
      		iio_adc_buffers[i].buff = adc_buffers[i];
      		iio_adc_buffers[i].size = sizeof(adc_buffers[i]);
      		ret = iio_axi_adc_init(&adcs[i], &adc_pars[i]);
      		if (ret < 0)
      			return ret;
      		a = 2 * i;
      		iio_axi_adc_get_dev_descriptor(adcs[i], &iio_descs[a]);
      		app_devices[a].name = adc_pars[i].rx_adc->name;
      		app_devices[a].dev = adcs[i];
      		app_devices[a].dev_descriptor = iio_descs[a];
      		app_devices[a].read_buff = &iio_adc_buffers[i];
      		/* DAC setup */
      		iio_dac_buffers[i].buff = dac_buffers[i];
      		iio_dac_buffers[i].size = sizeof(dac_buffers[i]);
      		ret = iio_axi_dac_init(&dacs[i], &dac_pars[i]);
      		if (ret < 0)
      			return ret;
      		a = 2 * i + 1;
      		iio_axi_dac_get_dev_descriptor(dacs[i], &iio_descs[a]);
      		app_devices[a].name = dac_pars[i].tx_dac->name;
      		app_devices[a].dev = dacs[i];
      		app_devices[a].write_buff = &iio_dac_buffers[i];
      	app_init_param.devices = app_devices;
      	app_init_param.nb_devices = NO_OS_ARRAY_SIZE(app_devices);
      	app_init_param.uart_init_params = iio_uart_ip;
      	ret = iio_app_init(&app, app_init_param);
      	if (ret)
      		return ret;
      	return iio_app_run(app);
      #endif
      int main(void)
      	int ret;
      	struct adi_adrv9001_Device adrv9001_device = {0};
      	struct adrv9002_chip_info chip = {0};
      	struct adrv9002_rf_phy phy = {0};
      	unsigned int c;
      		.name = "axi-adrv9002-rx-lpc",
      		.base = RX1_ADC_BASEADDR,
      		.num_channels = ADRV9001_I_Q_CHANNELS,
      	tx1_dac_channels[0].sel = AXI_DAC_DATA_SEL_DDS ;// AXI_DAC_DATA_SEL_DMA;
      	tx1_dac_channels[1].sel = AXI_DAC_DATA_SEL_DDS;
      		.name = "axi-adrv9002-tx-lpc",
      		.base = TX1_DAC_BASEADDR,
      		.channels = tx1_dac_channels,
      		.rate = 3
      		.name = "axi-adrv9002-rx2-lpc",
      		.base = RX2_ADC_BASEADDR,
      		.name = "axi-adrv9002-tx2-lpc",
      		.base = TX2_DAC_BASEADDR,
      		.channels = tx2_dac_channels,
      		.rate = 3
      #endif
      		"rx_dmac",
      		RX1_DMA_BASEADDR,
      		IRQ_DISABLED
      		"tx_dmac",
      		TX1_DMA_BASEADDR,
      		IRQ_DISABLED
      		"rx_dmac",
      		RX2_DMA_BASEADDR,
      		IRQ_DISABLED
      		"tx_dmac",
      		TX2_DMA_BASEADDR,
      		IRQ_DISABLED
      #endif
      	Xil_ICacheEnable();
      	Xil_DCacheEnable();
      	printf("Hello\n");
      	phy.rx2tx2 = true;
      #endif
      	phy.adrv9001 = &adrv9001_device;
      	/* ADRV9002 */
      	chip.cmos_profile = "Navassa_CMOS_profile.json";
      	chip.lvd_profile = "Navassa_LVDS_profile.json";
      	chip.name = "adrv9002-phy";
      	chip.n_tx = ADRV9002_CHANN_MAX;
      	phy.chip = &chip;
      	ret = adi_adrv9001_profileutil_Parse(phy.adrv9001, &phy.profile,
      					     (char *)json_profile, strlen(json_profile));
      	if (ret)
      		goto error;
      	phy.curr_profile = &phy.profile;
      	sampling_freq = phy.curr_profile->rx.rxChannelCfg[0].profile.rxOutputRate_Hz;
      	printf("%" PRIu64 "\n", sampling_freq);
      	ret = axi_adc_init_begin(&phy.rx1_adc, &rx1_adc_init);
      	if (ret) {
      		printf("axi_adc_init_begin() failed with status %d\n", ret);
      		goto error;
      	ret = axi_dac_init_begin(&phy.tx1_dac, &tx1_dac_init);
      	if (ret) {
      		printf("axi_dac_init_begin() failed with status %d\n", ret);
      		goto error;
      	ret = axi_adc_init_begin(&phy.rx2_adc, &rx2_adc_init);
      	if (ret) {
      		goto error;
      	ret = axi_dac_init_begin(&phy.tx2_dac, &tx2_dac_init);
      	if (ret) {
      		goto error;
      #endif
      	phy.ssi_type = adrv9002_ssi_type_detect(&phy);
      	if (phy.ssi_type == ADI_ADRV9001_SSI_TYPE_DISABLE)
      		goto error;
      	/* Initialize AGC */
      	for (c = 0; c < ADRV9002_CHANN_MAX; c++) {
      		phy.rx_channels[c].agc = agc_defaults;
      	ret = adrv9002_setup(&phy);
      	if (ret)
      		return ret;
      	if (ret) {
      		goto error;
      	/* Finalize the ADC/DAC cores initialization */
      	ret = axi_adc_init_finish(phy.rx1_adc);
      	if (ret) {
      		printf("axi_adc_init_finish() failed with status %d\n", ret);
      		goto error;
      	ret = axi_dac_init_finish(phy.tx1_dac);
      	if (ret) {
      		printf("axi_dac_init_finish() failed with status %d\n", ret);
      		goto error;
      	phy.tx1_dac->clock_hz = phy.curr_profile->tx.txProfile[0].txInputRate_Hz;
      	ret = axi_adc_init_finish(phy.rx2_adc);
      	if (ret) {
      		goto error;
      	ret = axi_dac_init_finish(phy.tx2_dac);
      	if (ret) {
      		goto error;
      	phy.tx2_dac->clock_hz = phy.curr_profile->tx.txProfile[1].txInputRate_Hz;
      #endif
      	if (ret) {
      		goto error;
      	if (ret) {
      		goto error;
      	if (ret) {
      		goto error;
      	if (ret) {
      		goto error;
      #endif
      #ifdef DMA_EXAMPLE
      				 NO_OS_ARRAY_SIZE(sine_lut_iq),
      				 (uintptr_t)dac_buffers[0]);
      				 (uintptr_t)dac_buffers[1]);
      #endif
      	Xil_DCacheFlush();
      	struct axi_dma_transfer transfer1 = {
      		// Number of bytes to write/read
      		.size = sizeof(sine_lut_iq),
      		// Transfer done flag
      		.transfer_done = 0,
      		// Signal transfer mode
      		.cyclic = CYCLIC,
      		// Address of data source
      		.src_addr = (uintptr_t)dac_buffers[0],
      		// Address of data destination
      		.dest_addr = 0
      	axi_dmac_transfer_start(phy.tx1_dmac, &transfer1);
      	struct axi_dma_transfer transfer2 = {
      		.transfer_done = 0,
      		.cyclic = CYCLIC,
      		.src_addr = (uintptr_t)dac_buffers[1],
      		.dest_addr = 0
      	axi_dmac_transfer_start(phy.tx2_dmac, &transfer2);
      #endif
      	Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[0], sizeof(sine_lut_iq));
      	Xil_DCacheInvalidateRange((uintptr_t)adc_buffers[1], sizeof(sine_lut_iq));
      #endif
      	no_os_mdelay(1000);
      	struct axi_dma_transfer read_transfer1 = {
      		.size = ADC_BUFFER_SAMPLES * ADRV9001_I_Q_CHANNELS * 2, /* nr of samples * rx1 i/q, rx2 i/q * bytes per sample */
      		.transfer_done = 0,
      		.cyclic = NO,
      		.src_addr = 0,
      		.dest_addr = (uintptr_t)adc_buffers[0]
      	/* Transfer ADC_BUFFER_SAMPLES samples from ADC to MEM */
      #ifdef ADRV9002_RX2TX2
      	axi_adc_update_active_channels(phy.rx1_adc, 0xf);
      #else
      	axi_adc_update_active_channels(phy.rx1_adc, 0x3);
      #endif
      	axi_dmac_transfer_start(phy.rx1_dmac, &read_transfer1);
      	ret = axi_dmac_transfer_wait_completion(phy.rx1_dmac, 500);
      	if(ret)
      		return ret;
      				  ADC_BUFFER_SAMPLES * /* nr of samples */
      				  ADRV9001_I_Q_CHANNELS * /* rx1 i/q, rx2 i/q*/
      	struct axi_dma_transfer read_transfer2 = {
      		.transfer_done = 0,
      		.cyclic = NO,
      		.src_addr = 0,
      		.dest_addr = (uintptr_t)adc_buffers[1]
      	axi_adc_update_active_channels(phy.rx2_adc, 0x3);
      	axi_dmac_transfer_start(phy.rx2_dmac,&read_transfer2);
      	ret = axi_dmac_transfer_wait_completion(phy.rx2_dmac, 500);
      	if(ret)
      		return ret;
      				  ADRV9001_I_Q_CHANNELS * /* nr of channels */
      	printf("DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n",
      	       (uintptr_t)adc_buffers[1], ADC_BUFFER_SAMPLES * rx2_adc_init.num_channels,
      	       rx2_adc_init.num_channels, 8 * sizeof(adc_buffers[1][0]));
      #endif
      	       (uintptr_t)adc_buffers[0], ADC_BUFFER_SAMPLES * rx1_adc_init.num_channels,
      	       rx1_adc_init.num_channels, 8 * sizeof(adc_buffers[0][0]));
      #endif
      #ifdef IIO_SUPPORT
      	struct iio_axi_adc_init_param iio_axi_adcs_init_par[] = {{
      #endif
      	struct iio_axi_dac_init_param iio_axi_dacs_init_par[] = {{
      #endif
      	ret = iio_run(iio_axi_adcs_init_par, iio_axi_dacs_init_par);
      	if (ret < 0) {
      		printf("iio_run() failed with status %d\n", ret);
      		goto error;
      #endif
      	printf("Bye\n");
      error:
      	return ret;
      Vitis/SDK prints:
  • Hello,
    Could you please open a new EZ thread regarding this topic? This seems to be a different issue not related to the initial no-Os driver not building. Therefore, we can consider this thread closed.
