i was confused about the jesd204c data structure?
when i use the ad9081 with JESD204B mode i refer the ad9173 datasheet that is contain the 204b data structure but i think the 204c and 204b was different
AD9081
Recommended for New Designs
The AD9081 mixed signal front end (MxFE®) is a highly integrated device with four 16-bit, 12 GSPS maximum sample rate, RF digital-to-analog converter...
Datasheet
AD9081 on Analog.com
AD9173
The AD9173 is a high performance, dual, 16-bit digital-to-analog converter (DAC) that supports DAC sample rates to 12.6 GSPS. The device features an 8...
Datasheet
AD9173 on Analog.com
can you please rephrase clearly what exactly do you need help with ?
