AD9081
Recommended for New Designs
The AD9081 mixed signal front end (MxFE®) is a highly integrated device with four 16-bit, 12 GSPS maximum sample rate, RF digital-to-analog converter...
Datasheet
AD9081 on Analog.com
AD9209
The AD9209 is a quad, 12-bit, 4 GSPS analog-to-digital converter (ADC). The ADC input features an on-chip wideband buffer with overload protection. This...
Datasheet
AD9209 on Analog.com
HMC7044
The HMC7044 is a high performance, dual-loop, integer-N jitter attenuator capable of performing reference selection and generation of ultralow phase noise...
HMC7044 on Analog.com
Hi All,
Background:
We've been, for some time now, trying to integrate the ad9081 NO-OS reference design with a AD9209 custom ADC platform with the following target FPGA: Iwave ZU19 (xczu19eg-ffvc1760-1-i).
Our approach was to first use the ZCU102 development board with the ad9081 to ensure that we were able to use the design ok, which we were successful in doing.
The second step was to use the ad9081 with the ZU19 but we faced some hardware issues with our ad9081 and thus jumped directly to step3 to integrate the ZU19 with our custom ad9209.
Key difference between our custom board and the ad9081 MXFE board from ADI is that we are using a RENESAS 8V19N882 as a clock generator instead of the HMC7044.
The changes made to the design are as follows:
HDL:
SW:
Current problem:
The issue being faced right now is that we're able to see data coming out from the Transport Layer when probing the adc data lines with ILA but nothing is displaying on iio-oscilloscope despite the device being detected properly. Note that Im using iio-oscilloscope through windows, but the same thing happens when I decide to use through linux (via WSL). But with linux, everytime i try to cature, the message "Unable to create Buffer" is displayed on the terminal.
Terminal Printout
PMIC: LD01 (BANK 67,68) set to 1.800V PMIC: LD04 (BANK 88,89,90,91) set to 1.800V CLK: Clk synthesizer-1 configured CLK: Clk synthesizer-2 configured Xilinx Zynq MP First Stage Boot Loader Release 2022.2 Oct 5 2024 - 04:47:46 PMU-FW is not running, certain applications may not be supported. Hello Starting program: ) ADC GPIO control through GPIO We're in not tx_enable We're done with not tx_enable We're done clk_rate_set DEBUG: adxcvr_clk_set_rate: Rate 3000000 Hz Parent Rate 500000 Hz DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x0028, val 0x010a. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x002a, val 0x008c. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x0063, val 0x80c1. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x0028, val 0x010a. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x002a, val 0x008c. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x0063, val 0x80c1. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x0028, val 0x010a. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x002a, val 0x008c. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x0063, val 0x80c1. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x0028, val 0x010a. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x002a, val 0x008c. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x0063, val 0x80c1. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x006d, val 0x349b. We're done with clk rate set and ret is : 0 AD9081 Rev. 3 Grade 10 (API 1.5.0) probed tx_dac: Status errors main:347 rx_adc: Successfully initialized (243533325 Hz) DEBUG: ad9081_jesd204_link_init:1212 link_num 2 reason initialization DEBUG: ad9081_jesd204_link_init:1212 link_num 0 reason initialization DEBUG: hmc7044_jesd204_link_supported:1138 link_num 2 reason initialization DEBUG: hmc7044_lmfc_lemc_validate: dividend=3000000000 divisor=3906250 GCD=3906250 (hmc->pll2_freq=3000000000, min=732780)DEBUG: hmc7044_jesd204_link_supported:1163 link_num 2 LMFC/LEMC 3906250/3906250 gcd 3906250 DEBUG: hmc7044_jesd204_link_supported:1138 link_num 0 reason initialization ERR: ../noos/jesd204/jesd204-core.c:144:jesd204_link_validate_params(): link[0], number of lanes is zero DEBUG: hmc7044_jesd204_link_pre_setup:1367 link_num 2 DEBUG: hmc7044_jesd204_link_pre_setup:1384 Found SYSREF channel3 setting f=3906250 Hz DEBUG: hmc7044_jesd204_link_pre_setup:1384 Found SYSREF channel13 setting f=3906250 Hz WARNING: hmc7044_jesd204_link_pre_setup: Link2 forcing continuous SYSREF mode DEBUG: axi_jesd204_rx_jesd204_link_pre_setup:641 link_num 2 reason initialization DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 device clock rate 125000000 (0) DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 lane rate 5000000 (0) DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set device clock rate 125000000 Hz DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set link clock rate 125000000 Hz DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 5000000 kHz DEBUG: adxcvr_clk_set_rate: Rate 5000000 Hz Parent Rate 500000 Hz DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x0028, val 0x108a. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x002a, val 0x808c. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x0063, val 0x80c0. DEBUG: xilinx_xcvr_drp_write: drp_port: 256, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x0028, val 0x108a. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x002a, val 0x808c. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x0063, val 0x80c0. DEBUG: xilinx_xcvr_drp_write: drp_port: 257, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x0028, val 0x108a. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x002a, val 0x808c. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x0063, val 0x80c0. DEBUG: xilinx_xcvr_drp_write: drp_port: 258, reg 0x006d, val 0x349b. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x0028, val 0x108a. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x002a, val 0x808c. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x0063, val 0x80c0. DEBUG: xilinx_xcvr_drp_write: drp_port: 259, reg 0x006d, val 0x349b. DEBUG: axi_jesd204_rx_jesd204_link_pre_setup: Link2 set lane rate 5000000 kHz DEBUG: hmc7044_jesd204_link_pre_setup:1367 link_num 0 DEBUG: hmc7044_jesd204_link_pre_setup:1384 Found SYSREF channel3 setting f=3906250 Hz DEBUG: hmc7044_jesd204_link_pre_setup:1384 Found SYSREF channel13 setting f=3906250 Hz DEBUG: axi_jesd204_tx_jesd204_link_pre_setup:550 link_num 0 reason initialization ERR: ../noos/jesd204/jesd204-core.c:144:jesd204_link_validate_params(): link[0], number of lanes is zero DEBUG: axi_jesd204_tx_jesd204_link_pre_setup: Link0 device clock rate 3906250 (-22) ERR: ../noos/drivers/axi_core/jesd204/axi_jesd204_tx.c:557:axi_jesd204_tx_jesd204_link_pre_setup(): axi_jesd204_tx_jesd204_link_pre_setup: Link0 get device clock rate failed (-22) DEBUG: axi_jesd204_rx_jesd204_link_setup:697 link_num 2 reason initialization DEBUG: axi_jesd204_tx_jesd204_link_setup:611 link_num 0 reason initialization DEBUG: Possible instantiation for multiple chips; HDL lanes 4, Link[0] lanes 0 ERR: ../noos/drivers/axi_core/jesd204/axi_jesd204_tx.c:627:axi_jesd204_tx_jesd204_link_setup(): axi_jesd204_tx_jesd204_link_setup: Link0 enable lane clock failed (-22) DEBUG: ad9081_jesd204_setup_stage1:1273 reason initialization DEBUG: ad9081_jesd204_setup_stage2:1338 reason initialization DEBUG: hmc7044_jesd204_sysref:1078 DEBUG: ad9081_jesd204_setup_stage3:1360 reason initialization DEBUG: axi_jesd204_rx_jesd204_clks_enable:719 link_num 2 reason initialization DEBUG: ad9081_jesd204_clks_enable:1058 link_num 2 reason initialization DEBUG: axi_jesd204_tx_jesd204_clks_enable:642 link_num 0 reason initialization DEBUG: ad9081_jesd204_clks_enable:1058 link_num 0 reason initialization DEBUG: axi_jesd204_rx_jesd204_link_enable:741 link_num 2 reason initialization DEBUG: adxcvr_clk_enable: RX DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) DEBUG: adxcvr_reset: CPLL RX Reset rx_adxcvr: OK (5000000 kHz) ERR: ../noos/drivers/axi_core/jesd204/axi_adxcvr.c:513:adxcvr_clk_enable(): adxcvr_clk_enable: CPLL RX buffer underflow error, status: 0x61 ERR: ../noos/drivers/axi_core/jesd204/axi_adxcvr.c:520:adxcvr_clk_enable(): adxcvr_clk_enable: CPLL RX buffer overflow error, status: 0x61 DEBUG: ad9081_jesd204_link_enable:1124 link_num 2 reason initialization DEBUG: hmc7044_jesd204_sysref:1078 DEBUG: axi_jesd204_tx_jesd204_link_enable:663 link_num 0 reason initialization DEBUG: ad9081_jesd204_link_enable:1124 link_num 0 reason initialization DEBUG: hmc7044_jesd204_sysref:1078 DEBUG: axi_jesd204_rx_jesd204_link_running:789 link_num 2 reason initialization DEBUG: ad9081_jesd204_link_running:1147 link_num 2 reason initialization JESD RX (JTX) Link2 in DATA, SYNC deasserted, PLL locked, PHASE established, MODE valid DEBUG: axi_jesd204_tx_jesd204_link_running:686 link_num 0 reason initialization ERR: ../noos/drivers/axi_core/jesd204/axi_jesd204_tx.c:697:axi_jesd204_tx_jesd204_link_running(): axi_jesd204_tx_jesd204_link_running: Link0 status failed (CGS) DEBUG: ad9081_jesd204_link_running:1147 link_num 0 reason initialization tx_jesd status: Link is enabled Measured Link Clock: 243.530 MHz Reported Link Clock: 250.000 MHz Lane rate: 3000.000 MHz Lane rate / 40: 75.000 MHz LMFC rate: 1.171 MHz SYNC~: asserted Link status: CGS SYSREF captured: disabled SYSREF alignment error: disabled rx_jesd status: Link is enabled Measured Link Clock: 243.530 MHz Reported Link Clock: 250.000 MHz Lane rate: 3000.000 MHz Lane rate / 40: 75.000 MHz LMFC rate: 2.343 MHz Link status: DATA SYSREF captured: Yes SYSREF alignment error: No Running IIOD server... If successful, you may connect an IIO client application by: 1. Disconnecting the serial terminal you use to view this message. 2. Connecting the IIO client application using the serial backend configured as shown: Baudrate: 115200 Data size: 8 bits Parity: none Stop bits: 1 Flow control: none
travisfcollins - Moved from Linux Software Drivers to Microcontroller no-OS Drivers. Post date updated from Tuesday, October 8, 2024 1:04 PM UTC to Tuesday, October 8, 2024 2:58 PM UTC to reflect the move.
travisfcollins - Moved from Linux Software Drivers to Microcontroller no-OS Drivers. Post date updated from Tuesday, October 8, 2024 2:58 PM UTC to Tuesday, October 8, 2024 2:58 PM UTC to reflect the move.
Hi All,
Just wanted to follow up on this. Is there anyone that can assist?
I would like to follow up on this, I've been dealing with this problem for a while now and could not find anything that could explain this.
Thanks
Hi btoure ,
First of all, we cant possibly assist all the custom designs, this is why we provide reference designs so that you may you be able to compare your custom design to a working design.
That being said, some general remarks here:
1) Tx is in CGS, that doesn't seem right to me
2) before doing anything with the iio-oscilloscope, I'd try to put the Rx data somewhere in memory and dump it from there, plot it, analyze it. IIO buffers are an extra complexity for now, and until you know for sure you're getting data to memory, it's not worth adding the extra complexity.
Hello btoure ,
Inside the HDL it is not enough to remove the constraints related to the TX path, you need to remove the entire path from the project and also enable QPLL for the RX path (this tells the software that the RX is driving the transceivers).
Here's the HDL project for AD9209: ad9209_fmca_ebz. There isn't a zynq ultrascale support for it, but you can see the changes needed to transform the AD9081 into AD9209.
Andrei
I managed to figure it out. I needed to still configure the tx adxcvr since the design still had it connected to the QPLL. On some of my other builds, i also had the rx_dma accidently commented out which I eventually fixed.
