ADRV9008-2 ORX at 491.42MSPS whit noise and DC
The user encountered high noise and DC component issues when using ADRV9008-2 at 491.52 MSPS for ORX. The problem was resolved by using the main branch for both HDL and no-OS projects, setting the correct ORx FIR coefficients, and ensuring the ORx uses lanes 2 and 3 (FRAMER B settings). The final configuration file and stream binary provided by the support engineer resulted in the desired flat response over the 450 MHz band.
Product Number: ADRV9008-2
I want to use ADRV9008-2 at 491.52 MSPS for TX and ORX.
I'm working on EVAL-TPG-ZYNQ3 + ADRV9008-2 W/PCBZ boards, with no-OS firmware.
If I look at the data received from ORX input I see some noise and a DC component quite high.
I already looked at "ADRV9008-2: problem with 491.52 MSPS profile" thread, but I see something that is different.
Looking at the spectrum I get without input signal (see figure) I note that at central frequencies the noise is higher than reported in that thread, and above all I have a DC component very high.
This is the configuration file I used (is what comes with no-OS release):
 * \file adrv9009/profiles/tx_bw400_ir491p52_rx_bw200_or245p76_orx_bw400_or491p52_dc245p76/talise_config.c
 * \brief Contains Talise configuration settings for the Talise API
 * Copyright 2015-2017 Analog Devices Inc.
 * Released under the AD9378-AD9379 API license, for more information see the "LICENSE.txt" file in this zip file.
 * The top level structure taliseDevice_t talDevice uses keyword
 * extern to allow the application layer main() to have visibility
 * to these settings.
 * This file may not be fully complete for the end user application and
 * may need to updated for AGC, GPIO, and DAC full scale settings.
 * To create a full initialisation routine, the user should also refer to the
 * Iron Python initialisation routine generated by the GUI, and also the Talise User Guide.
#include "talise_types.h"
#include "talise_config.h"
#include "talise_error.h"
#include "talise_agc.h"
#ifdef ADI_ZYNQ_PLATFORM
#include "zynq_platform.h"
#endif
int16_t txFirCoefs[20] = {32, -76, 124, -160, 176, -121, -145, 1031, -3015, 20138, -3015, 1031, -145, -121, 176, -160, 124, -76, 32, 0};
int16_t rxFirCoefs[24] = {-194, -715, 777, 907, -1163, -1890, 2240, 3306, -4068, -7024, 9205, 31112, 31112, 9205, -7024, -4068, 3306, 2240, -1890, -1163, 907, 777, -715, -194};
int16_t obsrxFirCoefs[24] = {-44, 22,-18, -1, 32, -75, 83, -81, -15, 354, -1940, 19672, -1940, 354, -15, -81, 83, -75, 32, -1, -18, 22, -44, 0};
#ifdef ADI_ZYNQ_PLATFORM /** < Insert Customer Platform HAL State Container here>*/
 * Platform Layer SPI settings - this structure is specific to ADI's platform layer code.
 * User should replace with their own structure or settings for their hardware
zynqSpiSettings_t spiDev1 = {
	.chipSelectIndex = 1,
	.writeBitPolarity = 0,
	.longInstructionWord = 1,
	.CPHA = 0,
	.CPOL = 0,
	.mode = 0,
	.spiClkFreq_Hz = 25000000
 * Platform Layer settings - this structure is specific to ADI's platform layer code.
 * The structure is held in taliseDevice_t below as a void pointer, allowing
 * the customer to pass any information for their specific hardware down to the
 * hardware layer code.
zynqAdiDev_t talDevHalInfo = {
	.devIndex = 1,
	.spiSettings = &spiDev1,
	.spiErrCode = 0,
	.timerErrCode = 0,
	.gpioErrCode = 0,
	.logLevel = ADIHAL_LOG_ALL
#endif
 *  TalDevice a structure used by the Talise API to hold the platform hardware
 *  structure information, as well as an internal Talise API state container
 *  (devStateInfo) of runtime information used by the API.
taliseDevice_t talDevice = {
	/* Void pointer of users platform HAL settings to pass to HAL layer calls
	 * Talise API does not use the devHalInfo member */
	.devHalInfo = &talDevHalInfo,
#else
	.devHalInfo = NULL,     /* < Insert Customer Platform HAL State Container here>*/
#endif
	/* devStateInfo is maintained internal to the Talise API, just create the memory */
	.devStateInfo = {0}
taliseInit_t talInit = {
	/* SPI settings */
	.spiSettings =
		.MSBFirst            = 1,  /* 1 = MSBFirst, 0 = LSBFirst */
		.enSpiStreaming      = 0,  /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */
		.autoIncAddrUp       = 1,  /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */
		.fourWireMode        = 1,  /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */
		.cmosPadDrvStrength  = TAL_CMOSPAD_DRV_2X /* Drive strength of CMOS pads when used as outputs (SDIO, SDO, GP_INTERRUPT, GPIO 1, GPIO 0) */
	/* Rx settings */
	.rx =
		.rxProfile =
			.rxFir =
				.gain_dB = -6,                /* filter gain */
				.numFirCoefs = 24,            /* number of coefficients in the FIR filter */
				.coefs = &rxFirCoefs[0]
			.rxFirDecimation = 2,            /* Rx FIR decimation (1,2,4) */
			.rxDec5Decimation = 4,            /* Decimation of Dec5 or Dec4 filter (5,4) */
			.rhb1Decimation = 1,            /* RX Half band 1 decimation (1 or 2) */
			.rxOutputRate_kHz = 245760,            /* Rx IQ data rate in kHz */
			.rfBandwidth_Hz = 200000000,    /* The Rx RF passband bandwidth for the profile */
			.rxBbf3dBCorner_kHz = 200000,    /* Rx BBF 3dB corner in kHz */
			.rxAdcProfile = {185, 141, 172, 90, 1280, 942, 1332, 90, 1368, 46, 1016, 19, 48, 48, 37, 208, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},            /* pointer to custom ADC profile */
			.rxDdcMode = TAL_RXDDC_BYPASS,   /* Rx DDC mode */
			.rxNcoShifterCfg =
				.bandAInputBandWidth_kHz = 0,
				.bandAInputCenterFreq_kHz = 0,
				.bandANco1Freq_kHz = 0,
				.bandANco2Freq_kHz = 0,
				.bandBInputBandWidth_kHz = 0,
				.bandBInputCenterFreq_kHz = 0,
				.bandBNco1Freq_kHz = 0,
				.bandBNco2Freq_kHz = 0
		.framerSel = TAL_FRAMER_A,            /* Rx JESD204b framer configuration */
		.rxGainCtrl =
			.gainMode = TAL_MGC,            /* taliserxGainMode_t gainMode */
			.rx1GainIndex = 255,            /* uint8_t rx1GainIndex */
			.rx2GainIndex = 255,            /* uint8_t rx2GainIndex */
			.rx1MaxGainIndex = 255,            /* uint8_t rx1MaxGainIndex */
			.rx1MinGainIndex = 195,            /* uint8_t rx1MinGainIndex */
			.rx2MaxGainIndex = 255,            /* uint8_t rx2MaxGainIndex */
			.rx2MinGainIndex = 195            /* uint8_t rx2MinGainIndex */
		.rxChannels = TAL_RX1RX2,                /* The desired Rx Channels to enable during initialization */
	/* Tx settings */
	.tx =
		.txProfile =
			.dacDiv = 1,                        /* The divider used to generate the DAC clock */
			.txFir =
				.gain_dB = 0,                        /* filter gain */
				.numFirCoefs = 20,                    /* number of coefficients in the FIR filter */
				.coefs = &txFirCoefs[0]
			.txFirInterpolation = 1,                    /* The Tx digital FIR filter interpolation (1,2,4) */
			.thb1Interpolation = 2,                    /* Tx Halfband1 filter interpolation (1,2) */
			.thb2Interpolation = 2,                    /* Tx Halfband2 filter interpolation (1,2)*/
			.thb3Interpolation = 1,                    /* Tx Halfband3 filter interpolation (1,2)*/
			.txInt5Interpolation = 1,                    /* Tx Int5 filter interpolation (1,5) */
			.txInputRate_kHz = 491520,                    /* Primary Signal BW */
			.primarySigBandwidth_Hz = 150000000,    /* The Rx RF passband bandwidth for the profile */
			.rfBandwidth_Hz = 400000000,            /* The Tx RF passband bandwidth for the profile */
			.txDac3dBCorner_kHz = 400000,                /* The DAC filter 3dB corner in kHz */
			.txBbf3dBCorner_kHz = 200000,                /* The BBF 3dB corner in kHz */
			.loopBackAdcProfile = {186, 148, 176, 90, 1280, 901, 1479, 225, 1401, 85, 995, 21, 48, 48, 36, 207, 0, 0, 0, 0, 52, 0, 0, 6, 24, 0, 0, 6, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905}
		.deframerSel = TAL_DEFRAMER_A,                    /* Talise JESD204b deframer config for the Tx data path */
		.txChannels = TAL_TX1TX2,                            /* The desired Tx channels to enable during initialization */
		.txAttenStepSize = TAL_TXATTEN_0P05_DB,            /* Tx Attenuation step size */
		.tx1Atten_mdB = 10000,                            /* Initial Tx1 Attenuation */
		.tx2Atten_mdB = 10000,                            /* Initial Tx2 Attenuation */
		.disTxDataIfPllUnlock = TAL_TXDIS_TX_RAMP_DOWN_TO_ZERO    /* Options to disable the transmit data when the RFPLL unlocks. */
	/* ObsRx settings */
	.obsRx =
		.orxProfile =
			.rxFir =
				.gain_dB = 6,                /* filter gain */
				.coefs = &obsrxFirCoefs[0]
			.rxFirDecimation = 1,            /* Rx FIR decimation (1,2,4) */
			.orxOutputRate_kHz = 491520,            /* Rx IQ data rate in kHz */
			.rfBandwidth_Hz = 400000000,    /* The Rx RF passband bandwidth for the profile */
			.rxBbf3dBCorner_kHz = 225000,    /* Rx BBF 3dB corner in kHz */
			.orxLowPassAdcProfile = {113, 171, 181, 90, 1280, 1737, 1574, 839, 1305, 297, 846, 74, 30, 41, 32, 193, 0, 0, 0, 0, 48, 0, 0, 0, 24, 0, 0, 0, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
			.orxBandPassAdcProfile = {113, 171, 181, 90, 1280, 1737, 1574, 839, 1305, 297, 846, 74, 30, 41, 32, 193, 0, 0, 0, 0, 48, 0, 0, 0, 24, 0, 0, 0, 24, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
			.orxDdcMode = TAL_ORXDDC_DISABLED,   /* ORx DDC mode */
            .orxMergeFilter  = {-167, 419, -208, -498, 968, -320, -1273, 2154, -402, -4155, 9170, 21413}
		.orxGainCtrl =
			.orx1GainIndex = 255,
			.orx2GainIndex = 255,
			.orx1MaxGainIndex = 255,
			.orx1MinGainIndex = 195,
			.orx2MaxGainIndex = 255,
			.orx2MinGainIndex = 195
		.framerSel = TAL_FRAMER_B,                /* ObsRx JESD204b framer configuration */
		.obsRxChannelsEnable = TAL_ORX1,        /* The desired ObsRx Channels to enable during initialization */
		.obsRxLoSource = TAL_OBSLO_RF_PLL                /* The ORx mixers can use the TX_PLL */
	/* Digital Clock Settings */
	.clocks =
		.deviceClock_kHz = 245760,            /* CLKPLL and device reference clock frequency in kHz */
		.clkPllVcoFreq_kHz = 9830400,        /* CLKPLL VCO frequency in kHz */
		.clkPllHsDiv = TAL_HSDIV_2P5,            /* CLKPLL high speed clock divider */
		.rfPllUseExternalLo = 0,                /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
		.rfPllPhaseSyncMode = TAL_RFPLLMCS_NOSYNC                /* RFPLL MCS (Phase sync) mode */
	/* JESD204B settings */
	.jesd204Settings =
		/* Framer A settings */
		.framerA =
			.bankId = 1,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
			.deviceId = 0,                    /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
			.lane0Id = 0,                    /* JESD204B Configuration starting Lane ID.  If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
			.M = 2,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
			.K = 32,                        /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
			.F = 2,                            /* F (number of bytes per frame) */
			.Np = 16,                            /* Np (converter sample resolution) */
			.scramble = 1,                    /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
			.externalSysref = 1,            /* 0=use internal SYSREF, 1= use external SYSREF */
			.serializerLanesEnabled = 0x03,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
			.serializerLaneCrossbar = 0xE4,    /* serializerLaneCrossbar */
			.lmfcOffset = 31,                /* lmfcOffset - LMFC offset value for deterministic latency setting */
			.newSysrefOnRelink = 0,            /* newSysrefOnRelink */
			.syncbInSelect = 0,                /* syncbInSelect; */
			.overSample = 0,                    /* 1=overSample, 0=bitRepeat */
			.syncbInLvdsMode = 1,
			.syncbInLvdsPnInvert = 0,
			.enableManualLaneXbar = 0 /* 0=auto, 1=manual */
		/* Framer B settings */
		.framerB =
			.bankId = 0,                    /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
			.serializerLanesEnabled = 0x0C,    /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
			.syncbInSelect = 1,                /* syncbInSelect; */
		/* Deframer A settings */
		.deframerA =
			.bankId = 0,                    /* bankId extension to Device ID (Valid 0..15) */
			.deviceId = 0,                    /* deviceId  link identification number. (Valid 0..255) */
			.lane0Id = 0,                    /* lane0Id Lane0 ID. (Valid 0..31) */
			.M = 4,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
			.K = 32,                        /* K  #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes) */
			.scramble = 1,                    /* scramble  scrambling off if scramble= 0 */
			.externalSysref = 1,            /* externalSysref  0= use internal SYSREF, 1= external SYSREF */
			.deserializerLanesEnabled = 0x0F,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
			.deserializerLaneCrossbar = 0xE4,    /* deserializerLaneCrossbar */
			.lmfcOffset = 17,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
			.syncbOutSelect = 0,                /* SYNCBOUT0/1 select */
			.syncbOutLvdsMode = 1,
			.syncbOutLvdsPnInvert = 0,
			.syncbOutCmosSlewRate = 0,
			.syncbOutCmosDriveLevel = 0,
		/* Deframer B settings */
		.deframerB =
			.M = 0,                            /* M  number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
			.deserializerLanesEnabled = 0x00,    /* deserializerLanesEnabled  bit per lane, [0] = Lane0 enabled */
			.lmfcOffset = 0,                /* lmfcOffset	 LMFC offset value to adjust deterministic latency */
			.syncbOutSelect = 1,                /* SYNCBOUT0/1 select */
		.serAmplitude = 15,                    /* Serializer amplitude setting. Default = 15. Range is 0..15 */
		.serPreEmphasis = 1,                /* Serializer pre-emphasis setting. Default = 1 Range is 0..4 */
		.serInvertLanePolarity = 0,            /* Serializer Lane PN inversion select. Default = 0. Where, bit[0] = 1 will invert lane [0], bit[1] = 1 will invert lane 1, etc. */
		.desInvertLanePolarity = 0,            /* Deserializer Lane PN inversion select.  bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc */
		.desEqSetting = 1,                    /* Deserializer Equalizer setting. Applied to all deserializer lanes. Range is 0..4 */
		.sysrefLvdsMode = 1,                /* Use LVDS inputs on Talise for SYSREF */
		.sysrefLvdsPnInvert = 0              /*0= Do not PN invert SYSREF */
//Only needs to be called if user wants to setup AGC parameters
static taliseAgcCfg_t rxAgcCtrl = {
	4,
	255,
	195,
	255,
	195,
	30720,  /* AGC gain update time in us (125us-250us - based on IQ data rate - set for 125us @ 245.76 Mhz) */
	10,
	10,
	16,
	0,
	1,
	0,
	0,
	0,
	1,
	31,
	246,
	4,
	1,          /*!<1- bit field to enable the multiple time constants in AGC loop for fast attack and fast recovery to max gain. */
	/* agcPower */
		1,      /*!<1-bit field, enables the Rx power measurement block. */
		1,      /*!<1-bit field, allows using Rx PFIR for power measurement. */
		0,      /*!<1-bit field, allows to use the output of the second digital offset block in the Rx datapath for power measurement. */
		9,      /*!<AGC power measurement detect lower 0 threshold. Default = -12dBFS == 5, 7-bit register value where max = 0x7F, min = 0x00 */
		2,      /*!<AGC power measurement detect lower 1 threshold. Default = (offset) 4dB == 0, 4-bit register value where  max = 0xF, min = 0x00 */
		4,      /*!<AGC power measurement detect lower 0 recovery gain step. Default = 2dB - based on gain table step  size, 5-bit register value where max = 0x1F, min = 0x00 */
		4,      /*!<AGC power measurement detect lower 1 recovery gain step. Default = 4dB - based on gain table step size, 5-bit register value where max = 0x1F, min = 0x00 */
		5,      /*!< power measurement duration used by the decimated power block. Default = 0x05, 5-bit register value where max = 0x1F, min = 0x00 */
		5,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
		1,      /*!<Allows power detection of data for a specific slice of the gain update counter. 16-bit register value (currently not used) */
		2,      /*!<Default value should be 2*/
		0,
		0
	/* agcPeak */
		205,        /*!<1st update interval for the multiple time constant in AGC loop mode, Default:205. */
		2,          /*!<sets the 2nd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of  agcUnderRangeLowInterval  , Default: 4 */
		4,          /*!<sets the 3rd update interval for the multiple time constant in AGC loop mode. Calculated as a multiple of agcUnderRangeMidInterval and agcUnderRangeLowInterval, Default: 4 */
		39,         /*!<AGC APD high threshold. Default=0x1F, 6-bit register value where max=0x3F, min =0x00 */
		49,         /*!<AGC APD peak detect high threshold. default = 0x1F, 6-bit register value where max = 0x3F, min = 0x00.  Set to 3dB below apdHighThresh */
		23,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max =0x3F, min = 0x00 */
		19,         /*!<AGC APD peak detect low threshold. default = 3dB below high threshold, 6-bit register value where max = 0x3F, min = 0x00 . Set to 3dB below apdLowThresh  */
		6,          /*!<AGC APD peak detect upper threshold count. Default = 0x06 8-bit register value where max = 0xFF, min = 0x20  */
		3,          /*!<AGC APD peak detect lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00  */
		4,          /*!<AGC APD peak detect attack gain step. Default = 2dB step - based on gain table step size, 5-bit register  value, where max = 0x1F, min = 0x00  */
		2,          /*!<AGC APD gain index step size. Recommended to be same as hb2GainStepRecovery. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00  */
		1,          /*!<1-bit field, enables or disables the HB2 overload detector.  */
		1,          /*!<3-bit field. Sets the window of clock cycles (at the HB2 output rate) to meet the overload count. */
		1,          /*!<4-bit field. Sets the number of actual overloads required to trigger the overload signal.  */
		181,        /*!<AGC decimator output high threshold. Default = 0xB5, 8-bit register value where max = 0xFF, min = 0x00 */
		45,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
		90,         /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
		128,        /*!<AGC decimator output low threshold. Default = 0x80, 8-bit register value where max = 0xFF, min = 0x00 */
		6,          /*!<AGC HB2 output upper threshold count. Default = 0x06, 8-bit register value where max = 0xFF, min =  0x20 */
		3,          /*!<AGC HB2 output lower threshold count. Default = 0x03, 8-bit register value where max = 0xFF, min = 0x00 */
		2,          /*!<AGC decimator gain index step size. Default = 0x00, 5-bit register value where max = 0x1F, min = 0x00 */
		4,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 0 triggers a programmable number  of times. Default = 0x08, 5-bit register value where max = 0x1F, min = 0x00 */
		8,          /*!<AGC HB2 gain index step size, when the HB2 Low Overrange interval 1 triggers a programmable number of times. Default = 0x04, 5-bit register value where max = 0x1F, min = 0x00 */
		4,          /*!<AGC decimator output attack gain step. Default = 2dB step - based on gain table step size, 5-bit register value, where max = 0x1F, min = 0x00 */
		1,
		0,
		0
I've seen that also the ORX input chain has a DC correction block that may be bypassed, but I don't know how to activate it.
Thank you
Maurizio
Edit Notes
deleted replicated file
[edited by: maurizio.sonzogni@abe.it at 2:42 PM (GMT -5) on 21 Feb 2024]
Thread Notes
  • can you please share the setup connection that you are using, did you connect the feedback signal to ORx? Please share these details to understand more about the issue.
    Use the below API to enable the ORX DC offset.
  • Thank you RR4,
    I'm using this environment:
    - FPGA project is the adrv9009/zc706 project from hdl repository. I've made a little modification sending data to TX channels from a block memory ROM, and looking for ORX data with an ILA.
    - Software project is the adrv9009 project from no-OS repository, the DMA_EXAMPLE option.
    I generate a single side-band sine waveform on both TX1 and TX2, and the spectrum in the above image is calculated from the captured data in ILA when the ORX1 input is not connected to any signal (the input has a 50 ohm clamp).
    I see the same behavior if I put the TX1 signal on ORX1 (via a 20 dB attenuator): in this case I see the correct signal plus the noise and DC component as in the above figure.
    I've tried to make a call to the suggested API: I've made the call to this API after the call to the TALISE_enableTrackingCals API, and before the calls to the TALISE_radioOn and the TALISE_setRxTxEnable APIs in the talise_setup function, but the result is very strange, as you can see in this picture:
    The signal goes from -32768 to 32767 and sometimes around tho 0 value but with some noise and some DC component.
    Is there something else to do when calling the TALISE_setDigDcOffsetEn API?
    Thank you
    Maurizio
  • Please share the Tx output captured in the spectrum.
  • This is the waveform captured that has the above reported spectrum (no signal on the ORX input):
    while this is the waveform captured when at the ORX input there is the signal generated at the TX output (with 20 dB attenuation):
    In both cases you can see the noise and the DC component.
    Thank you
    Maurizio
  • Apologies for the delayed response. Can you please capture the TX output in Spectrum and see the DC leakage? Also what frequency offset are you transmitting?
  • The TX spectrum is in the following figure:
    The center frequency for both TX and ORX is 1 GHz, there is no frequency offset. As you see the DC component on the TX is very little.
    With this signal routed to the ORX1 input without any attenuation, the spectrum of the received signal is this:
    showing an high DC component.
    The spectrum on the whole band is:
    showing some noise all over the band.
    I've made these measures without the TALISE_setDigDcOffsetEn setting for ORX channel.
    Thank you
    Maurizio
  • This behavior looks due to the saturation of ORx, please add the 20 dB attenuator at the input of Orx and check.
  • With a 20 dB attenuator the behavior remains the same: a lot of noise, a lot of DC component with now a lower signal.
    The waveform I get is:
    The spectrum near the DC is:
    and the whole spectrum is:
    Anyway, if you look at the signal I got before adding the 20 dB attenuator, you can see that it is not saturated.
    By the way, obviously, if I do the TALISE_setDigDcOffsetEn setting for the ORX channel I get again the strange behavior I mentioned in a previous post.
    For this test I'm using the profile contained in the tx_bw400_ir491p52_rx_bw200_or245p76_orx_bw400_or491p52_dc245p76 directory of the no-OS project for ADTRV9009.
    If I use the profile contained in the tx_bw100_ir122p88_rx_bw100_or122p88_orx_bw100_or122p88_dc122p88 directory to test the behavior at 122.88 MSPS I obtain the following results (with a 20 dB attenuator, and hence comparable with the pictures i have posted for the 491.52 MSPS test):
    the waveform I get is:
    the spectrum near the DC is:
    and the overall spectrum is:
    As you can see, in this test the noise and the DC component are very low, as one can expect.
    I have changed only the profile files talise_config.c and talise_config.h.
    For the 122.88 MSPS test the talise_config.c file is:
     * \file adrv9009/profiles/tx_bw100_ir122p88_rx_bw100_or122p88_orx_bw100_or122p88_dc122p88/talise_config.c
    #endif
    int16_t txFirCoefs[80] = {0, 0, 0, 1, 0, -3, 1, 7, -3, -13, 7, 25, -14, -42, 27, 69, -46, -107, 74, 160, -115, -229, 184, 336, -264, -468, 382, 653, -538, -904, 754, 1269, -1056, -1842, 1486, 2879, -2031, -4846, 3816, 16221, 16221, 3816, -4846, -2031, 2879, 1486, -1842, -1056, 1269, 754, -904, -538, 653, 382, -468, -264, 336, 184, -229, -115, 160, 74, -107, -46, 69, 27, -42, -14, 25, 7, -13, -3, 7, 1, -3, 0, 1, 0, 0, 0};
    int16_t rxFirCoefs[48] = {-9, -18, 31, 42, -65, -89, 132, 168, -240, -298, 396, 486, -632, -770, 968, 1163, -1530, -1862, 2369, 3051, -4066, -5983, 9689, 29830, 29830, 9689, -5983, -4066, 3051, 2369, -1862, -1530, 1163, 968, -770, -632, 486, 396, -298, -240, 168, 132, -89, -65, 42, 31, -18, -9};
    int16_t obsrxFirCoefs[48] = {-9, -18, 31, 42, -65, -89, 132, 168, -240, -298, 396, 486, -632, -770, 968, 1163, -1530, -1862, 2369, 3051, -4066, -5983, 9689, 29830, 29830, 9689, -5983, -4066, 3051, 2369, -1862, -1530, 1163, 968, -770, -632, 486, 396, -298, -240, 168, 132, -89, -65, 42, 31, -18, -9};
    	.CPHA = 0,
    	.CPOL = 0,
    	.mode = 0,
    	.devIndex = 1,
    	.spiErrCode = 0,
    	.timerErrCode = 0,
    	.gpioErrCode = 0,
    #endif
    #else
    #endif
    	.devStateInfo = {0}
    	/* SPI settings */
    	.spiSettings =
    	/* Rx settings */
    	.rx =
    		.rxProfile =
    			.rxFir =
    				.numFirCoefs = 48,            /* number of coefficients in the FIR filter */
    			.rhb1Decimation = 2,            /* RX Half band 1 decimation (1 or 2) */
    			.rxOutputRate_kHz = 122880,            /* Rx IQ data rate in kHz */
    			.rfBandwidth_Hz = 100000000,    /* The Rx RF passband bandwidth for the profile */
    			.rxBbf3dBCorner_kHz = 100000,    /* Rx BBF 3dB corner in kHz */
    			.rxAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},            /* pointer to custom ADC profile */
    			.rxNcoShifterCfg =
    		.rxGainCtrl =
    	/* Tx settings */
    	.tx =
    		.txProfile =
    			.txFir =
    				.numFirCoefs = 80,                    /* number of coefficients in the FIR filter */
    			.txFirInterpolation = 2,                    /* The Tx digital FIR filter interpolation (1,2,4) */
    			.thb3Interpolation = 2,                    /* Tx Halfband3 filter interpolation (1,2)*/
    			.txInputRate_kHz = 122880,                    /* Primary Signal BW */
    			.primarySigBandwidth_Hz = 50000000,    /* The Rx RF passband bandwidth for the profile */
    			.rfBandwidth_Hz = 100000000,            /* The Tx RF passband bandwidth for the profile */
    			.txDac3dBCorner_kHz = 187000,                /* The DAC filter 3dB corner in kHz */
    			.txBbf3dBCorner_kHz = 56000,                /* The BBF 3dB corner in kHz */
    			.loopBackAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}
    	.obsRx =
    		.orxProfile =
    			.rxFir =
    			.orxOutputRate_kHz = 122880,            /* Rx IQ data rate in kHz */
    			.orxLowPassAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},
    			.orxBandPassAdcProfile = {265, 146, 181, 90, 1280, 366, 1257, 27, 1258, 17, 718, 39, 48, 46, 27, 161, 0, 0, 0, 0, 40, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},
    			.orxMergeFilter  = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
    		.orxGainCtrl =
    		.obsRxChannelsEnable = TAL_ORX1ORX2,        /* The desired ObsRx Channels to enable during initialization */
    	.clocks =
    	.jesd204Settings =
    		.framerA =
    			.M = 4,                            /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
    			.F = 4,                            /* F (number of bytes per frame) */
    		.framerB =
    		.deframerA =
    		.deframerB =
    	4,
    	255,
    	195,
    	255,
    	195,
    	10,
    	10,
    	16,
    	0,
    	1,
    	0,
    	0,
    	0,
    	1,
    	31,
    	246,
    	4,
    	/* agcPower */
    		0,
    		0
    	/* agcPeak */
    		1,
    		0,
    		0
    For the 491.52 MSPS test the talise_config.c file is:
    #endif
    	.CPHA = 0,
    	.CPOL = 0,
    	.mode = 0,
    	.devIndex = 1,
    	.spiErrCode = 0,
    	.timerErrCode = 0,
    	.gpioErrCode = 0,
    #endif
    #else
    #endif
    	.devStateInfo = {0}
    	/* SPI settings */
    	.spiSettings =
    	/* Rx settings */
    	.rx =
    		.rxProfile =
    			.rxFir =
    			.rxNcoShifterCfg =
    		.rxGainCtrl =
    	/* Tx settings */
    	.tx =
    		.txProfile =
    			.txFir =
    	.obsRx =
    		.orxProfile =
    			.rxFir =
    		.orxGainCtrl =
    	.clocks =
    	.jesd204Settings =
    		.framerA =
    		.framerB =
    		.deframerA =
    		.deframerB =
    	4,
    	255,
    	195,
    	255,
    	195,
    	10,
    	10,
    	16,
    	0,
    	1,
    	0,
    	0,
    	0,
    	1,
    	31,
    	246,
    	4,
    	/* agcPower */
    		0,
    		0
    	/* agcPeak */
    		1,
    		0,
    		0
    Why this different behavior?
    Thank you
    Maurizio
  • Can you please check the ORx spectrum by Adjusting the Tx attenuation or changing the ORx gain and see if it improves?
    Also please ensure you are using the stream files generated by enabling the ORx stitching. Refer to the below section of the ADRV9009 user guide.
  • Changing the ORx gain doesn't solve the problem: I still see large DC and noise.
    How to generate the stream files?
    I have used the "Talise_Configuration_wizard" program and the "ADRV9009 Transceiver Evaluation Software" to generate files but the resulting files don't give a result.
    The talise_config.c has syntax error in line 29 (int16_t rxFirCoefs[0] = {)
     * \file talise_config.c
    #endif
    int16_t txFirCoefs[20] = {1659, -379, -2018, 457, 2976, 483, -5166, -1777, 10494, 18198, 10494, -1777, -5166, 483, 2976, 457, -2018, -379, 1659, 0};
    int16_t obsrxFirCoefs[24] = {-118, -553, 395, 960, -868, -1855, 1717, 3340, -3525, -6850, 8901, 30982, 30982, 8901, -6850, -3525, 3340, 1717, -1855, -868, 960, 395, -553, -118};
    	.CPHA = 0,
    	.CPOL = 0,
    	.mode = 0,
    	.devIndex = 1,
    	.spiErrCode = 0,
    	.timerErrCode = 0,
    	.gpioErrCode = 0,
    #endif
    #else
    	.devHalInfo = NULL,     /*/** < Insert Customer Platform HAL State Container here>*/
    #endif
    	.devStateInfo = {0}
    	/* SPI settings */
        .spiSettings =
        /* Tx settings */
        .tx =
            .txProfile =
                .txFir =
                .primarySigBandwidth_Hz = 100000000,    /* The Rx RF passband bandwidth for the profile */
                .rfBandwidth_Hz = 200000000,            /* The Tx RF passband bandwidth for the profile */
                .txDac3dBCorner_kHz = 200000,                /* The DAC filter 3dB corner in kHz */
                .txBbf3dBCorner_kHz = 100000,                /* The BBF 3dB corner in kHz */
                .loopBackAdcProfile = {212, 140, 175, 90, 1280, 699, 1304, 59, 1343, 33, 913, 27, 48, 48, 34, 192, 0, 0, 0, 0, 48, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}
            .tx1Atten_mdB = 0,                            /* Initial Tx1 Attenuation */
            .tx2Atten_mdB = 0,                            /* Initial Tx2 Attenuation */
        .obsRx =
            .orxProfile =
                .rxFir =
                .orxLowPassAdcProfile = {229, 137, 174, 90, 1280, 456, 1340, 77, 1339, 21, 916, 36, 48, 48, 34, 192, 0, 0, 0, 0, 48, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
                .orxBandPassAdcProfile = {148, 146, 181, 90, 1280, 1433, 1238, 0, 1142, 171, 1333, 1, 48, 35, 36, 206, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 15, 905},
                .orxMergeFilter  = {0, -472, 576, 1301, 893, -591, -2029, -1900, 600, 4787, 8717, 10320}
            .orxGainCtrl =
        .clocks =
            .rfPllPhaseSyncMode = TAL_RFPLLMCS_INIT_AND_CONTTRACK                /* RFPLL MCS (Phase sync) mode */
        .jesd204Settings =
            .framerB =
            .framerA =
                .F = 0,                            /* F (number of bytes per frame) */
            .deframerA =
            .deframerB =
        4,
        255,
        195,
        255,
        195,
        10,
        10,
        16,
        0,
        1,
        0,
        0,
        0,
        1,
        31,
        246,
        4,
        /* agcPower */
            0,
            0
        /* agcPeak */
            1,
            0,
            0
    but also if I correct this line I cannot see any input in the ORx input, while the TX channel is OK.
    I've used the TaliseStream.bin file (converted to TaliseStream.h) that was generated by the "ADRV9009 Transceiver Evaluation Software" program and in the "Talise_Configuration_wizard" program I set the ORx stitching.
    In the "ADRV9009 Transceiver Evaluation Software" program, using the generated profile file the behavior is good.
    The TX is:
    and the ORx is:
    As you can see, the DC component and the noise are much lower than in my application.
    Can you please explain how to generate the profile files to use in my application or, better, generate the right files for my application?
    Thank you
    Maurizio
