FMCOMMS5 & ZC702, strange RX-samples
Software Version: Vitis 2021.1
I am using FMCOMMS5 and ZC702 with the HDL reference design and NO-OS drivers. The DAC_DMA_EXAMPLE is working perfectly, with internal or external loopback. Printing to PC (MATLAB plotting) also works.
My problem is that whenever I try to receive radio waves (e.g. a 868MHz OOK signal), I get strange samples from all 4 RX-channels, see the pictures (the blocks represent the channels: I1, short pause, Q1, pause, I2, short pause, Q2 , 2x pause etc..):
     details:
sometimes I get this:
   details:
my appconfig.h:
#ifndef CONFIG_H_
#define CONFIG_H_
#define HAVE_SPLIT_GAIN_TABLE	1 /* only set to 0 in case split_gain_table_mode_enable = 0*/
#define HAVE_TDD_SYNTH_TABLE	1 /* only set to 0 in case split_gain_table_mode_enable = 0*/
#define AD9361_DEVICE			1 /* set it 1 if AD9361 device is used, 0 otherwise */
#define AD9364_DEVICE			0 /* set it 1 if AD9364 device is used, 0 otherwise */
#define AD9363A_DEVICE			0 /* set it 1 if AD9363A device is used, 0 otherwise */
#define XILINX_PLATFORM
//#define ALTERA_PLATFORM
//#define LINUX_PLATFORM
#define FMCOMMS5
//#define ADI_RF_SOM
//#define ADI_RF_SOM_CMOS
#define ADC_DMA_EXAMPLE
#define DMA_IRQ_ENABLE
//#define DAC_DMA_EXAMPLE
//#define AXI_ADC_NOT_PRESENT
//#define TDD_SWITCH_STATE_EXAMPLE
//#define IIO_SUPPORT
#ifndef IIO_SUPPORT
#define HAVE_VERBOSE_MESSAGES /* Recommended during development prints errors and warnings */
//#define HAVE_DEBUG_MESSAGES /* For Debug purposes only */
#endif // USE_LIBIIO
 * In case memory footprint is a concern these options allow
 * to disable unused functionality which may free up a few kb
#endif
Please see my attached main.c (I was not able to post it here).
 *   @file   ad9361/src/main.c
 *   @brief  Implementation of Main Function.
 *   @author DBogdan (dragos.bogdan@analog.com)
 * Copyright 2013(c) Analog Devices, Inc.
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 *  - Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *  - Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in
 *    the documentation and/or other materials provided with the
 *    distribution.
 *  - Neither the name of Analog Devices, Inc. nor the names of its
 *    contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  - The use of this software may or may not infringe the patent rights
 *    of one or more patent holders.  This license does not release you
 *    from the requirement that you obtain separate licenses from these
 *    patent holders to use this software.
 *  - Use of the software either in source or binary form, must be run
 *    on or directly connected to an Analog Devices Inc. component.
 * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
 * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
 * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***************************** Include Files **********************************/
#include <inttypes.h>
#include "app_config.h"
#include "ad9361_api.h"
#include "parameters.h"
#include "no_os_spi.h"
#include "no_os_gpio.h"
#include "no_os_delay.h"
#include "no_os_axi_io.h"
#ifdef XILINX_PLATFORM
#include <xparameters.h>
#include <xil_cache.h>
#include "xilinx_spi.h"
#include "xilinx_gpio.h"
#include "no_os_irq.h"
#ifdef ALTERA_PLATFORM
#include "altera_spi.h"
#include "altera_gpio.h"
#endif
#endif
#ifdef LINUX_PLATFORM
#include "linux_spi.h"
#include "linux_gpio.h"
#else
#include "xilinx_irq.h"
#endif //LINUX
#include "axi_adc_core.h"
#include "axi_dac_core.h"
#include "axi_dmac.h"
#include "no_os_error.h"
#ifdef IIO_SUPPORT
#include "iio_axi_adc.h"
#include "iio_axi_dac.h"
#include "iio_ad9361.h"
#include "no_os_uart.h"
#include "iio_app.h"
#include "xilinx_uart.h"
#include "xil_cache.h"
#include "xil_printf.h"
//#include <stdio.h>
#endif //XILINX
#if defined LINUX_PLATFORM || defined GENERIC_PLATFORM
static uint8_t in_buff[MAX_SIZE_BASE_ADDR];
static uint8_t out_buff[MAX_SIZE_BASE_ADDR];
#endif
#endif // IIO_SUPPORT
#ifdef DAC_DMA_EXAMPLE
#include <string.h>
#endif
/************************ Variables Definitions *******************************/
#if defined(DAC_DMA_EXAMPLE) || defined(IIO_SUPPORT)
uint32_t dac_buffer[DAC_BUFFER_SAMPLES] __attribute__ ((aligned));
#endif
uint16_t adc_buffer[ADC_BUFFER_SAMPLES * ADC_CHANNELS] __attribute__ ((
			aligned));
#define AD9361_ADC_DAC_BYTES_PER_SAMPLE 2
struct xil_spi_init_param xil_spi_param = {
#ifdef PLATFORM_MB
	.type = SPI_PL,
#else
	.type = SPI_PS,
#endif
	.flags = 0
struct xil_gpio_init_param xil_gpio_param = {
#ifdef PLATFORM_MB
	.type = GPIO_PL,
#else
	.type = GPIO_PS,
#endif
	.device_id = GPIO_DEVICE_ID
#define GPIO_OPS	&xil_gpio_ops
#define SPI_OPS		&xil_spi_ops
#define GPIO_PARAM	&xil_gpio_param
#define SPI_PARAM	&xil_spi_param
#endif
#ifdef GENERIC_PLATFORM
#define GPIO_OPS	&generic_gpio_ops
#define SPI_OPS		&generic_spi_ops
#define GPIO_PARAM	NULL
#define SPI_PARAM	NULL
#endif
#endif
#define GPIO_OPS	&linux_gpio_ops
#define SPI_OPS		&linux_spi_ops
#endif
struct axi_adc_init rx_adc_init = {
	.name = "cf-ad9361-lpc",
	.base = RX_CORE_BASEADDR,
#ifdef FMCOMMS5
	.slave_base = AD9361_RX_1_BASEADDR,
	.num_channels = 8,
#else
	.num_channels = 4,
#endif
	.num_slave_channels =  4
struct axi_dac_init tx_dac_init = {
	"cf-ad9361-dds-core-lpc",
	TX_CORE_BASEADDR,
	4,
	NULL
struct axi_dmac_init rx_dmac_init = {
	"rx_dmac",
	CF_AD9361_RX_DMA_BASEADDR,
#ifdef DMA_IRQ_ENABLE
	IRQ_ENABLED
#else
	IRQ_DISABLED
#endif
struct axi_dmac *rx_dmac;
struct axi_dmac_init tx_dmac_init = {
	"tx_dmac",
	CF_AD9361_TX_DMA_BASEADDR,
	IRQ_ENABLED
#else
	IRQ_DISABLED
#endif
struct axi_dmac *tx_dmac;
AD9361_InitParam default_init_param = {
	/* Device selection */
	ID_AD9361,	// dev_sel
	/* Reference Clock */
	40000000UL,	//reference_clk_rate
	/* Base Configuration */
	1,		//two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
	1,		//one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
	1,		//one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
	1,		//frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
	0,		//frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
	0,		//tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
	0,		//tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
	0,		//tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
	0,		//rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
	0,		//rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
	0,		//tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
	0,		//external_rx_lo_enable *** adi,external-rx-lo-enable
	0,		//external_tx_lo_enable *** adi,external-tx-lo-enable
	5,		//dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
	6,		//dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
	5,		//dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
	0x28,	//dc_offset_count_high_range *** adi,dc-offset-count-high-range
	0x32,	//dc_offset_count_low_range *** adi,dc-offset-count-low-range
	0,		//split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
	MAX_SYNTH_FREF,	//trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
	0,		// qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
	/* ENSM Control */
	0,		//ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
	0,		//ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
	/* LO Control */
	865000000UL,	//rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz    // default war 2400000000UL
	400000000UL,	//tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
	1,				//tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable
	/* Rate & BW Control */
	{983040000, 245760000, 122880000, 61440000, 30720000, 30720000},// rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
	{983040000, 122880000, 122880000, 61440000, 30720000, 30720000},// tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
	18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
	18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
	/* RF Port Control */
	0,		//rx_rf_port_input_select *** adi,rx-rf-port-input-select
	0,		//tx_rf_port_input_select *** adi,tx-rf-port-input-select
	/* TX Attenuation Control */
	10,	//tx_attenuation_mdB *** adi,tx-attenuation-mdB // default =10000
	0,		//update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
	/* Reference Clock Control */
	0,		//xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
	{8, 5920},	//dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
	CLKOUT_DISABLE,	//clk_output_mode_select *** adi,clk-output-mode-select
	/* Gain Control */
	2,		//gc_rx1_mode *** adi,gc-rx1-mode
	2,		//gc_rx2_mode *** adi,gc-rx2-mode
	58,		//gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
	4,		//gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
	47,		//gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
	8192,	//gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
	0,		//gc_dig_gain_enable *** adi,gc-dig-gain-enable
	800,	//gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
	704,	//gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
	24,		//gc_low_power_thresh *** adi,gc-low-power-thresh
	15,		//gc_max_dig_gain *** adi,gc-max-dig-gain
	0,		//gc_use_rx_fir_out_for_dec_pwr_meas_enable *** adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable
	/* Gain MGC Control */
	2,		//mgc_dec_gain_step *** adi,mgc-dec-gain-step
	2,		//mgc_inc_gain_step *** adi,mgc-inc-gain-step
	0,		//mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
	0,		//mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
	0,		//mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
	/* Gain AGC Control */
	10,		//agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
	2,		//agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
	0,		//agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
	10,		//agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
	4,		//agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
	3,		//agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
	1000,	// agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
	0,		//agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
	0,		//agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
	10,		//agc_inner_thresh_high *** adi,agc-inner-thresh-high
	1,		//agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
	12,		//agc_inner_thresh_low *** adi,agc-inner-thresh-low
	1,		//agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
	10,		//agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
	2,		//agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
	10,		//agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
	5,		//agc_outer_thresh_high *** adi,agc-outer-thresh-high
	2,		//agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
	18,		//agc_outer_thresh_low *** adi,agc-outer-thresh-low
	2,		//agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
	1,		//agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
	0,		//agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
	/* Fast AGC */
	64,		//fagc_dec_pow_measuremnt_duration ***  adi,fagc-dec-pow-measurement-duration
	260,	//fagc_state_wait_time_ns ***  adi,fagc-state-wait-time-ns
	/* Fast AGC - Low Power */
	0,		//fagc_allow_agc_gain_increase ***  adi,fagc-allow-agc-gain-increase-enable
	5,		//fagc_lp_thresh_increment_time ***  adi,fagc-lp-thresh-increment-time
	1,		//fagc_lp_thresh_increment_steps ***  adi,fagc-lp-thresh-increment-steps
	/* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */
	1,		//fagc_lock_level_lmt_gain_increase_en ***  adi,fagc-lock-level-lmt-gain-increase-enable
	5,		//fagc_lock_level_gain_increase_upper_limit ***  adi,fagc-lock-level-gain-increase-upper-limit
	/* Fast AGC - Peak Detectors and Final Settling */
	1,		//fagc_lpf_final_settling_steps ***  adi,fagc-lpf-final-settling-steps
	1,		//fagc_lmt_final_settling_steps ***  adi,fagc-lmt-final-settling-steps
	3,		//fagc_final_overrange_count ***  adi,fagc-final-overrange-count
	/* Fast AGC - Final Power Test */
	0,		//fagc_gain_increase_after_gain_lock_en ***  adi,fagc-gain-increase-after-gain-lock-enable
	/* Fast AGC - Unlocking the Gain */
	0,		//fagc_gain_index_type_after_exit_rx_mode ***  adi,fagc-gain-index-type-after-exit-rx-mode
	1,		//fagc_use_last_lock_level_for_set_gain_en ***  adi,fagc-use-last-lock-level-for-set-gain-enable
	1,		//fagc_rst_gla_stronger_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
	5,		//fagc_optimized_gain_offset ***  adi,fagc-optimized-gain-offset
	10,		//fagc_rst_gla_stronger_sig_thresh_above_ll ***  adi,fagc-rst-gla-stronger-sig-thresh-above-ll
	1,		//fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
	1,		//fagc_rst_gla_engergy_lost_goto_optim_gain_en ***  adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
	10,		//fagc_rst_gla_engergy_lost_sig_thresh_below_ll ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
	8,		//fagc_energy_lost_stronger_sig_gain_lock_exit_cnt ***  adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
	1,		//fagc_rst_gla_large_adc_overload_en ***  adi,fagc-rst-gla-large-adc-overload-enable
	1,		//fagc_rst_gla_large_lmt_overload_en ***  adi,fagc-rst-gla-large-lmt-overload-enable
	0,		//fagc_rst_gla_en_agc_pulled_high_en ***  adi,fagc-rst-gla-en-agc-pulled-high-enable
	0,		//fagc_rst_gla_if_en_agc_pulled_high_mode ***  adi,fagc-rst-gla-if-en-agc-pulled-high-mode
	64,		//fagc_power_measurement_duration_in_state5 ***  adi,fagc-power-measurement-duration-in-state5
	2,		//fagc_large_overload_inc_steps *** adi,fagc-adc-large-overload-inc-steps
	/* RSSI Control */
	1,		//rssi_delay *** adi,rssi-delay
	1000,	//rssi_duration *** adi,rssi-duration
	3,		//rssi_restart_mode *** adi,rssi-restart-mode
	0,		//rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
	1,		//rssi_wait *** adi,rssi-wait
	/* Aux ADC Control */
	256,	//aux_adc_decimation *** adi,aux-adc-decimation
	40000000UL,	//aux_adc_rate *** adi,aux-adc-rate
	/* AuxDAC Control */
	1,		//aux_dac_manual_mode_enable ***  adi,aux-dac-manual-mode-enable
	0,		//aux_dac1_default_value_mV ***  adi,aux-dac1-default-value-mV
	0,		//aux_dac1_active_in_rx_enable ***  adi,aux-dac1-active-in-rx-enable
	0,		//aux_dac1_active_in_tx_enable ***  adi,aux-dac1-active-in-tx-enable
	0,		//aux_dac1_active_in_alert_enable ***  adi,aux-dac1-active-in-alert-enable
	0,		//aux_dac1_rx_delay_us ***  adi,aux-dac1-rx-delay-us
	0,		//aux_dac1_tx_delay_us ***  adi,aux-dac1-tx-delay-us
	0,		//aux_dac2_default_value_mV ***  adi,aux-dac2-default-value-mV
	0,		//aux_dac2_active_in_rx_enable ***  adi,aux-dac2-active-in-rx-enable
	0,		//aux_dac2_active_in_tx_enable ***  adi,aux-dac2-active-in-tx-enable
	0,		//aux_dac2_active_in_alert_enable ***  adi,aux-dac2-active-in-alert-enable
	0,		//aux_dac2_rx_delay_us ***  adi,aux-dac2-rx-delay-us
	0,		//aux_dac2_tx_delay_us ***  adi,aux-dac2-tx-delay-us
	/* Temperature Sensor Control */
	256,	//temp_sense_decimation *** adi,temp-sense-decimation
	1000,	//temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
	0xCE,	//temp_sense_offset_signed *** adi,temp-sense-offset-signed
	1,		//temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
	/* Control Out Setup */
	0xFF,	//ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
	0,		//ctrl_outs_index *** adi,ctrl-outs-index
	/* External LNA Control */
	0,		//elna_settling_delay_ns *** adi,elna-settling-delay-ns
	0,		//elna_gain_mdB *** adi,elna-gain-mdB
	0,		//elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
	0,		//elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
	0,		//elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
	0,		//elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
	/* Digital Interface Control */
	0,		//digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode
	0,		//digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable
	1,		//pp_tx_swap_enable *** adi,pp-tx-swap-enable
	1,		//pp_rx_swap_enable *** adi,pp-rx-swap-enable
	0,		//tx_channel_swap_enable *** adi,tx-channel-swap-enable
	0,		//rx_channel_swap_enable *** adi,rx-channel-swap-enable
	1,		//rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
	0,		//two_t_two_r_timing_enable *** adi,2t2r-timing-enable
	0,		//invert_data_bus_enable *** adi,invert-data-bus-enable
	0,		//invert_data_clk_enable *** adi,invert-data-clk-enable
	0,		//fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
	0,		//invert_rx_frame_enable *** adi,invert-rx-frame-enable
	0,		//fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
	0,		//swap_ports_enable *** adi,swap-ports-enable
	0,		//single_data_rate_enable *** adi,single-data-rate-enable
	1,		//lvds_mode_enable *** adi,lvds-mode-enable
	0,		//half_duplex_mode_enable *** adi,half-duplex-mode-enable
	0,		//single_port_mode_enable *** adi,single-port-mode-enable
	0,		//full_port_enable *** adi,full-port-enable
	0,		//full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
	0,		//delay_rx_data *** adi,delay-rx-data
	0,		//rx_data_clock_delay *** adi,rx-data-clock-delay
	4,		//rx_data_delay *** adi,rx-data-delay
	7,		//tx_fb_clock_delay *** adi,tx-fb-clock-delay
	0,		//tx_data_delay *** adi,tx-data-delay
	300,	//lvds_bias_mV *** adi,lvds-bias-mV
#else
	150,	//lvds_bias_mV *** adi,lvds-bias-mV
#endif
	1,		//lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
	0,		//rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
	0xFF,	//lvds_invert1_control *** adi,lvds-invert1-control
	0x0F,	//lvds_invert2_control *** adi,lvds-invert2-control
	/* GPO Control */
	0,		//gpo_manual_mode_enable *** adi,gpo-manual-mode-enable
	0,		//gpo_manual_mode_enable_mask *** adi,gpo-manual-mode-enable-mask
	0,		//gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
	0,		//gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
	0,		//gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
	0,		//gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
	0,		//gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
	0,		//gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
	0,		//gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
	0,		//gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
	0,		//gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
	0,		//gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
	0,		//gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
	0,		//gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
	0,		//gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
	0,		//gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
	0,		//gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
	0,		//gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
	0,		//gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
	0,		//gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
	0,		//gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
	0,		//gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
	/* Tx Monitor Control */
	37000,	//low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
	0,		//low_gain_dB *** adi,txmon-low-gain
	24,		//high_gain_dB *** adi,txmon-high-gain
	0,		//tx_mon_track_en *** adi,txmon-dc-tracking-enable
	0,		//one_shot_mode_en *** adi,txmon-one-shot-mode-enable
	511,	//tx_mon_delay *** adi,txmon-delay
	8192,	//tx_mon_duration *** adi,txmon-duration
	2,		//tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
	2,		//tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
	48,		//tx1_mon_lo_cm *** adi,txmon-1-lo-cm
	48,		//tx2_mon_lo_cm *** adi,txmon-2-lo-cm
	/* GPIO definitions */
		.number = -1,
		.platform_ops = GPIO_OPS,
		.extra = GPIO_PARAM
	},		//gpio_resetb *** reset-gpios
	/* MCS Sync */
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_sync *** sync-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw1 *** cal-sw1-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw2 *** cal-sw2-gpios
		.device_id = SPI_DEVICE_ID,
		.mode = NO_OS_SPI_MODE_1,
		.chip_select = SPI_CS,
		.platform_ops = SPI_OPS,
		.extra = SPI_PARAM
	/* External LO clocks */
	NULL,	//(*ad9361_rfpll_ext_recalc_rate)()
	NULL,	//(*ad9361_rfpll_ext_round_rate)()
	NULL,	//(*ad9361_rfpll_ext_set_rate)()
#ifndef AXI_ADC_NOT_PRESENT
	&rx_adc_init,	// *rx_adc_init
	&tx_dac_init,   // *tx_dac_init
#endif
AD9361_RXFIRConfig rx_fir_config = {	// BPF PASSBAND 3/20 fs to 1/4 fs
	3, // rx
	0, // rx_gain
	1, // rx_dec
		-4, -6, -37, 35, 186, 86, -284, -315,
			107, 219, -4, 271, 558, -307, -1182, -356,
			658, 157, 207, 1648, 790, -2525, -2553, 748,
			865, -476, 3737, 6560, -3583, -14731, -5278, 14819,
			14819, -5278, -14731, -3583, 6560, 3737, -476, 865,
			748, -2553, -2525, 790, 1648, 207, 157, 658,
			-356, -1182, -307, 558, 271, -4, 219, 107,
			-315, -284, 86, 186, 35, -37, -6, -4,
			0, 0, 0, 0, 0, 0, 0, 0,
		}, // rx_coef[128]
	64, // rx_coef_size
	{0, 0, 0, 0, 0, 0}, //rx_path_clks[6]
	0 // rx_bandwidth
AD9361_TXFIRConfig tx_fir_config = {	// BPF PASSBAND 3/20 fs to 1/4 fs
	3, // tx
	-6, // tx_gain
	1, // tx_int
		}, // tx_coef[128]
	64, // tx_coef_size
	{0, 0, 0, 0, 0, 0}, // tx_path_clks[6]
	0 // tx_bandwidth
struct ad9361_rf_phy *ad9361_phy;
#ifdef FMCOMMS5
struct ad9361_rf_phy *ad9361_phy_b;
#endif
 * @brief main
int main(void)
	int32_t status;
	Xil_ICacheEnable();
	Xil_DCacheEnable();
	default_init_param.spi_param.extra = &xil_spi_param;
	default_init_param.spi_param.platform_ops = &xil_spi_ops;
#endif
	// NOTE: The user has to choose the GPIO numbers according to desired
	// carrier board.
	default_init_param.gpio_resetb.number = GPIO_RESET_PIN;
#ifdef FMCOMMS5
	default_init_param.gpio_sync.number = GPIO_SYNC_PIN;
	default_init_param.gpio_cal_sw1.number = GPIO_CAL_SW1_PIN;
	default_init_param.gpio_cal_sw2.number = GPIO_CAL_SW2_PIN;
	default_init_param.rx1rx2_phase_inversion_en = 1;
#else
	default_init_param.gpio_sync.number = -1;
	default_init_param.gpio_cal_sw1.number = -1;
	default_init_param.gpio_cal_sw2.number = -1;
#endif
	if (AD9364_DEVICE)
		default_init_param.dev_sel = ID_AD9364;
	if (AD9363A_DEVICE)
		default_init_param.dev_sel = ID_AD9363A;
#if defined FMCOMMS5 || defined ADI_RF_SOM || defined ADI_RF_SOM_CMOS
	default_init_param.xo_disable_use_ext_refclk_enable = 1;
#endif
#ifdef ADI_RF_SOM_CMOS
	if (AD9361_DEVICE)
		default_init_param.swap_ports_enable = 1;
	default_init_param.lvds_mode_enable = 0;
	default_init_param.lvds_rx_onchip_termination_enable = 0;
	default_init_param.full_port_enable = 1;
	default_init_param.digital_interface_tune_fir_disable = 1;
#endif
	ad9361_init(&ad9361_phy, &default_init_param);
	ad9361_set_tx_fir_config(ad9361_phy, tx_fir_config);
	ad9361_set_rx_fir_config(ad9361_phy, rx_fir_config);
#ifdef FMCOMMS5
	gpio_init(default_init_param.gpio_sync);
#endif
	default_init_param.spi_param.chip_select = SPI_CS_2;
	default_init_param.gpio_resetb.number = GPIO_RESET_PIN_2;
	gpio_init(default_init_param.gpio_resetb);
#endif
	default_init_param.rx_synthesizer_frequency_hz = 865000000UL; //2300000000UL
	default_init_param.tx_synthesizer_frequency_hz = 400000000UL;//2300000000UL
	rx_adc_init.base = AD9361_RX_1_BASEADDR;
	rx_adc_init.num_slave_channels = 0;
	tx_dac_init.base = AD9361_TX_1_BASEADDR;
	ad9361_init(&ad9361_phy_b, &default_init_param);
	ad9361_set_tx_fir_config(ad9361_phy_b, tx_fir_config);
	ad9361_set_rx_fir_config(ad9361_phy_b, rx_fir_config);
#endif
	status = axi_dmac_init(&tx_dmac, &tx_dmac_init);
	if (status < 0) {
		printf("axi_dmac_init tx init error: %"PRIi32"\n", status);
		return status;
	status = axi_dmac_init(&rx_dmac, &rx_dmac_init);
	if (status < 0) {
		printf("axi_dmac_init rx init error: %"PRIi32"\n", status);
		return status;
#if defined XILINX_PLATFORM || defined LINUX_PLATFORM || defined ALTERA_PLATFORM
#ifdef FMCOMMS5
	axi_dac_init(&ad9361_phy_b->tx_dac, &tx_dac_init);
	axi_dac_set_datasel(ad9361_phy_b->tx_dac, -1, AXI_DAC_DATA_SEL_DMA);
	rx_adc_init.base = AD9361_RX_0_BASEADDR;
	rx_adc_init.num_slave_channels = 4;
	tx_dac_init.base = AD9361_TX_0_BASEADDR;
#endif
	axi_dac_init(&ad9361_phy->tx_dac, &tx_dac_init);
	extern const uint32_t sine_lut_iq[1024];
	axi_dac_set_datasel(ad9361_phy->tx_dac, -1, AXI_DAC_DATA_SEL_DMA);
	axi_dac_load_custom_data(ad9361_phy->tx_dac, sine_lut_iq,
				 NO_OS_ARRAY_SIZE(sine_lut_iq),
				 (uintptr_t)dac_buffer);
	Xil_DCacheFlush();
#endif
#else
#ifdef FMCOMMS5
	axi_dac_set_datasel(ad9361_phy_b->tx_dac, -1, AXI_DAC_DATA_SEL_DDS);
#endif
	axi_dac_set_datasel(ad9361_phy->tx_dac, -1, AXI_DAC_DATA_SEL_DDS);
#endif
#endif
#endif
#ifdef FMCOMMS5
	ad9361_do_mcs(ad9361_phy, ad9361_phy_b);
#endif
#ifndef AXI_ADC_NOT_PRESENT  // usually true
#if (defined XILINX_PLATFORM || defined ALTERA_PLATFORM) && \
	(defined ADC_DMA_EXAMPLE)
	uint32_t samples = 4096;//default was 16384;
#if (defined DMA_IRQ_ENABLE)
	 * Xilinx platform dependent initialization for IRQ.
	struct xil_irq_init_param xil_irq_init_par = {
		.type = IRQ_PS,
	 * IRQ initial configuration.
	struct no_os_irq_init_param irq_init_param = {
		.irq_ctrl_id = INTC_DEVICE_ID,
		.platform_ops = &xil_irq_ops,
		.extra = &xil_irq_init_par,
	 * IRQ instance.
	struct no_os_irq_ctrl_desc *irq_desc;
	status = no_os_irq_ctrl_init(&irq_desc, &irq_init_param);
	if(status < 0)
		return status;
	status = no_os_irq_global_enable(irq_desc);
	if (status < 0)
		return status;
	struct no_os_callback_desc rx_dmac_callback = {
		.ctx = rx_dmac,
		.callback = axi_dmac_dev_to_mem_isr,
	status = no_os_irq_register_callback(irq_desc,
					     AD9361_ADC_DMA_IRQ_INTR, &rx_dmac_callback);
	if(status < 0)
		return status;
	status = no_os_irq_trigger_level_set(irq_desc,
					     AD9361_ADC_DMA_IRQ_INTR, NO_OS_IRQ_LEVEL_HIGH);
	if(status < 0)
		return status;
	status = no_os_irq_enable(irq_desc, AD9361_ADC_DMA_IRQ_INTR);
	if(status < 0)
		return status;
	samples = 2048; //4096;
#endif
	// NOTE: To prevent unwanted data loss, it's recommended to invalidate
	// cache after each axi_dmac_transfer_start() call, keeping in mind that the
	// size of the capture and the start address must be aligned to the size
	// of the cache line.
	struct no_os_callback_desc tx_dmac_callback = {
		.ctx = tx_dmac,
		.callback = axi_dmac_mem_to_dev_isr,
					     AD9361_DAC_DMA_IRQ_INTR, &tx_dmac_callback);
	if(status < 0)
		return status;
	status = no_os_irq_enable(irq_desc, AD9361_DAC_DMA_IRQ_INTR);
	if(status < 0)
		return status;
#endif
	struct axi_dma_transfer transfer = {
		// Number of bytes to write/read
		.size = sizeof(sine_lut_iq),
		// Transfer done flag
		.transfer_done = 0,
		// Signal transfer mode
		.cyclic = CYCLIC,
		// Address of data source
		.src_addr = (uintptr_t)dac_buffer,
		// Address of data destination
		.dest_addr = 0
	/* Transfer the data. */
	axi_dmac_transfer_start(tx_dmac, &transfer);
	/* Flush cache data. */
	Xil_DCacheInvalidateRange((uintptr_t)dac_buffer, sizeof(sine_lut_iq));
	no_os_mdelay(1000);
#endif
#ifdef FMCOMMS5
	struct axi_dma_transfer read_transfer = {
		.size = samples * AD9361_ADC_DAC_BYTES_PER_SAMPLE * ad9361_phy->rx_adc->num_channels, // default
		// from https://ez.analog.com/microcontroller-no-os-drivers/f/q-a/564908/fmcomms5-zc706-no-os
		//.size = samples * AD9361_ADC_DAC_BYTES_PER_SAMPLE *
		//		(ad9361_phy_b->tx_dac->num_channels + ad9361_phy->tx_dac->num_channels),
		.transfer_done = 0,
		.cyclic = NO,
		.src_addr = 0,
		.dest_addr =  (uintptr_t)ADC_DDR_BASEADDR
	//LOOPBACK enable: 0,1 or 2
	ad9361_bist_loopback(ad9361_phy, 0);
	ad9361_bist_loopback(ad9361_phy_b, 0);
	no_os_mdelay(1000);
	/* Read the data from the ADC DMA. */
	axi_dmac_transfer_start(rx_dmac, &read_transfer); // read_transfer ist var wo reingespeichert wird
	/* Wait until transfer finishes */
	status = axi_dmac_transfer_wait_completion(rx_dmac, 500);
	if(status < 0)
		return status;
#else  // NOT FMCOMMS5!!
		.size = sizeof(adc_buffer),
		.transfer_done = 0,
		.cyclic = NO,
		.src_addr = 0,
		.dest_addr = (uintptr_t)adc_buffer
	// Read the data from the ADC DMA.
	// Wait until transfer finishes
	if(status < 0)
		return status;
#endif
#ifdef FMCOMMS5
	Xil_DCacheInvalidateRange((uintptr_t)ADC_DDR_BASEADDR,
				  ad9361_phy->rx_adc->num_channels);
	// from forum https://ez.analog.com/microcontroller-no-os-drivers/f/q-a/564908/fmcomms5-zc706-no-os/479483
	//Xil_DCacheInvalidateRange((uintptr_t)ADC_DDR_BASEADDR, samples * AD9361_ADC_DAC_BYTES_PER_SAMPLE *
		//	(ad9361_phy_b->rx_adc->num_channels + ad9361_phy->rx_adc->num_channels));
	printf("DAC_DMA_EXAMPLE: address=%#x samples=%lu channels=%u bits=%u\n",
	       read_transfer.size / AD9361_ADC_DAC_BYTES_PER_SAMPLE,
	       rx_adc_init.num_channels,
	       8 * sizeof(adc_buffer[0]));
//////////////////    EIGENER CODE HIER     /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
	// Hinweis siehe oben: uint16_t adc_buffer[ADC_BUFFER_SAMPLES * ADC_CHANNELS] __attribute__ ((aligned));
    uint16_t sampleI[4][samples];
    uint16_t sampleQ[4][samples];
    uint32_t data;
    uint32_t lookupaddr[samples];
	for (uint32_t ii=0; ii<samples; ii++){
	    	lookupaddr[ii] = ii * 4;
    while(1){
        for (int k = 0; k < 7; k++) { // alle 3 Arten gehen
        	xil_printf("%u\n", output[k]);
        	xil_printf("%d\n", output[k]);
        	xil_printf("%i\n", output[k]);
 //https://ez.analog.com/microcontroller-no-os-drivers/f/q-a/565171/ad9361-received-iq-samples-missing?pifragment-59109=2
 /*   for (uint32_t k=0;k<8;k++) { // diese Variante sollte richtig sein, I1, Q1, ...
		for (uint32_t index_mem = k; index_mem < samples*8; index_mem += 8) {
			//printf("%d\n", adc_buffer[index_mem]);
			xil_printf("%d\n",adc_buffer[index_mem]);
			xil_printf("%d\n", ADC_DDR_BASEADDR + index_mem);
// from https://ez.analog.com/fpga/f/q-a/86581/printing-data-from-adc_capture/254406
    	// HINWEIS: Memory-DDR is addressed bytewise daher 4 bit increment!
   for (uint32_t k=0;k<4;k++) { // diese Variante sollte richtig sein, I1, Q1 [je 2 in einem 32 bit block] ... // kanalweise durchiterieren
    	// iteriere f�r Kanal k alle samples einmal durch:
	   for (uint32_t index = 0; index < samples; index++) {
    		   no_os_axi_io_read(ADC_DDR_BASEADDR+(lookupaddr[index]+(k*4)),0,&data);
     		  // data = Xil_In32(ADC_DDR_BASEADDR + index);
     		        sampleQ[k][index] = (data & 0xFFFF);
     		        sampleI[k][index] = (data >> 16) & 0xFFFF;
    		  for (uint32_t index = k; index < samples; index++) {
    		  xil_printf("%d\n", sampleI[k][index]);
   		   // print IQ sep
    		  for (uint32_t i=0; i < 50; i++) {
   		    	xil_printf("%d\n",0);
    			xil_printf("%d\n", sampleQ[k][index]);
    		   // print separators between channels
    		    for (uint32_t i=0; i < (k+1)*200; i++) {
    } // inf-while END
	//////////////////    EIGENER CODE ENDE     /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
	#else
	Xil_DCacheInvalidateRange((uintptr_t)adc_buffer, sizeof(adc_buffer));
	printf("DAC_DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n",
	       (uintptr_t)adc_buffer, NO_OS_ARRAY_SIZE(adc_buffer), rx_adc_init.num_channels,
#endif
#endif
#endif
#endif
#ifdef IIO_SUPPORT
	 * iio application configurations.
	struct xil_uart_init_param platform_uart_init_par = {
#ifdef XPAR_XUARTLITE_NUM_INSTANCES
		.type = UART_PL,
#else
		.type = UART_PS,
		.irq_id = UART_IRQ_ID
#endif
	struct no_os_uart_init_param iio_uart_ip = {
		.device_id = UART_DEVICE_ID,
		.irq_id = UART_IRQ_ID,
		.baud_rate = UART_BAUDRATE,
		.size = NO_OS_UART_CS_8,
		.parity = NO_OS_UART_PAR_NO,
		.stop = NO_OS_UART_STOP_1_BIT,
		.extra = &platform_uart_init_par,
		.platform_ops = &xil_uart_ops
	struct iio_app_desc *app;
	struct iio_app_init_param app_init_param = { 0 };
	 * iio axi adc configurations.
	struct iio_axi_adc_init_param iio_axi_adc_init_par;
#ifdef FMCOMMS5
	struct iio_axi_adc_init_param iio_axi_adc_b_init_par;
#endif
	 * iio axi dac configurations.
	struct iio_axi_dac_init_param iio_axi_dac_init_par;
#ifdef FMCOMMS5
	struct iio_axi_dac_init_param iio_axi_dac_b_init_par;
#endif
	 * iio ad9361 configurations.
	struct iio_ad9361_init_param iio_ad9361_init_param;
#ifdef FMCOMMS5
	struct iio_ad9361_init_param iio_ad9361_b_init_param;
#endif
	 * iio instance descriptor.
	struct iio_axi_adc_desc *iio_axi_adc_desc;
#ifdef FMCOMMS5
	struct iio_axi_adc_desc *iio_axi_adc_b_desc;
#endif
	struct iio_axi_dac_desc *iio_axi_dac_desc;
#ifdef FMCOMMS5
	struct iio_axi_dac_desc *iio_axi_dac_b_desc;
#endif
	 * iio ad9361 instance descriptor.
	struct iio_ad9361_desc *iio_ad9361_desc;
#ifdef FMCOMMS5
	struct iio_ad9361_desc *iio_ad9361_b_desc;
#endif
	 * iio devices corresponding to every device.
	struct iio_device *adc_dev_desc, *dac_dev_desc, *ad9361_dev_desc;
#ifdef FMCOMMS5
	struct iio_device *adc_b_dev_desc, *dac_b_dev_desc, *ad9361_b_dev_desc;
#endif
	if(status < 0)
		return status;
	iio_axi_adc_init_par = (struct iio_axi_adc_init_param) {
		.rx_adc = ad9361_phy->rx_adc,
		.rx_dmac = rx_dmac,
#ifndef PLATFORM_MB
		.dcache_invalidate_range = (void (*)(uint32_t,
						     uint32_t))Xil_DCacheInvalidateRange
#endif
	status = iio_axi_adc_init(&iio_axi_adc_desc, &iio_axi_adc_init_par);
	if(status < 0)
		return status;
	iio_axi_adc_get_dev_descriptor(iio_axi_adc_desc, &adc_dev_desc);
	struct iio_data_buffer read_buff = {
		.buff = (void *)ADC_DDR_BASEADDR,
		.size = 0xFFFFFFFF,
#ifdef FMCOMMS5
	iio_axi_adc_b_init_par = (struct iio_axi_adc_init_param) {
		.rx_adc = ad9361_phy_b->rx_adc,
	status = iio_axi_adc_init(&iio_axi_adc_b_desc, &iio_axi_adc_b_init_par);
	if(status < 0)
		return status;
	iio_axi_adc_get_dev_descriptor(iio_axi_adc_b_desc, &adc_b_dev_desc);
#endif
	iio_axi_dac_init_par = (struct iio_axi_dac_init_param) {
		.tx_dac = ad9361_phy->tx_dac,
		.tx_dmac = tx_dmac,
#ifndef PLATFORM_MB
		.dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange,
#endif
	status = iio_axi_dac_init(&iio_axi_dac_desc, &iio_axi_dac_init_par);
	if (status < 0)
		return status;
	iio_axi_dac_get_dev_descriptor(iio_axi_dac_desc, &dac_dev_desc);
	struct iio_data_buffer write_buff = {
		.buff = (void *)DAC_DDR_BASEADDR,
		.size = 0xFFFFFFFF,
#ifdef FMCOMMS5
	iio_axi_dac_b_init_par = (struct iio_axi_dac_init_param) {
		.tx_dac = ad9361_phy_b->tx_dac,
	status = iio_axi_dac_init(&iio_axi_dac_b_desc, &iio_axi_dac_b_init_par);
	if (status < 0)
		return status;
	iio_axi_dac_get_dev_descriptor(iio_axi_dac_b_desc, &dac_b_dev_desc);
#endif
	iio_ad9361_init_param = (struct iio_ad9361_init_param) {
		.ad9361_phy = ad9361_phy,
	status = iio_ad9361_init(&iio_ad9361_desc, &iio_ad9361_init_param);
	if (status < 0)
		return status;
	iio_ad9361_get_dev_descriptor(iio_ad9361_desc, &ad9361_dev_desc);
#ifdef FMCOMMS5
	iio_ad9361_b_init_param = (struct iio_ad9361_init_param) {
		.ad9361_phy = ad9361_phy_b,
	status = iio_ad9361_init(&iio_ad9361_b_desc, &iio_ad9361_b_init_param);
	if (status < 0)
		return status;
	iio_ad9361_get_dev_descriptor(iio_ad9361_b_desc, &ad9361_b_dev_desc);
#endif
	struct iio_app_device devices[] = {
		IIO_APP_DEVICE("cf-ad9361-lpc", iio_axi_adc_desc, adc_dev_desc, &read_buff, NULL),
		IIO_APP_DEVICE("cf-ad9361-dds-core-lpc", iio_axi_dac_desc, dac_dev_desc, NULL, &write_buff),
		IIO_APP_DEVICE("ad9361-phy", ad9361_phy, ad9361_dev_desc, NULL, NULL),
#ifdef FMCOMMS5
		IIO_APP_DEVICE("cf-ad9361-B", iio_axi_adc_b_desc, adc_b_dev_desc, &read_buff, NULL),
		IIO_APP_DEVICE("cf-ad9361-dds-core-B", iio_axi_dac_b_desc, dac_b_dev_desc, NULL, &write_buff),
		IIO_APP_DEVICE("ad9361-phy-B", ad9361_phy_b, ad9361_b_dev_desc, NULL, NULL)
#endif
	app_init_param.devices = devices;
	app_init_param.nb_devices = NO_OS_ARRAY_SIZE(devices);
	app_init_param.uart_init_params = iio_uart_ip;
	status = iio_app_init(&app, app_init_param);
	if (status)
		return status;
	iio_app_run(app);
	printf("Done.\n");
#ifdef TDD_SWITCH_STATE_EXAMPLE
	uint32_t ensm_mode;
	struct no_os_gpio_init_param  gpio_init = {
		.extra = GPIO_PARAM
	struct no_os_gpio_desc 	*gpio_enable_pin;
	struct no_os_gpio_desc 	*gpio_txnrx_pin;
	if (!ad9361_phy->pdata->fdd) {
		if (ad9361_phy->pdata->ensm_pin_ctrl) {
			gpio_init.number = GPIO_ENABLE_PIN;
			status = no_os_gpio_get(&gpio_enable_pin, &gpio_init);
			if (status != 0) {
				printf("no_os_gpio_get() error: %"PRIi32"\n", status);
				return status;
			no_os_gpio_direction_output(gpio_enable_pin, 1);
			gpio_init.number = GPIO_TXNRX_PIN;
			status = no_os_gpio_get(&gpio_txnrx_pin, &gpio_init);
			if (status != 0) {
				return status;
			no_os_gpio_direction_output(gpio_txnrx_pin, 0);
			no_os_udelay(10);
			ad9361_get_en_state_machine_mode(ad9361_phy, &ensm_mode);
			printf("TXNRX control - Alert: %s\n",
			       ensm_mode == ENSM_MODE_ALERT ? "OK" : "Error");
			no_os_mdelay(1000);
			if (ad9361_phy->pdata->ensm_pin_pulse_mode) {
				while(1) {
					no_os_gpio_set_value(gpio_txnrx_pin, 0);
					no_os_udelay(10);
					no_os_gpio_set_value(gpio_enable_pin, 1);
					no_os_udelay(10);
					no_os_gpio_set_value(gpio_enable_pin, 0);
					printf("TXNRX Pulse control - RX: %s\n",
					       ensm_mode == ENSM_MODE_RX ? "OK" : "Error");
					no_os_mdelay(1000);
					no_os_udelay(10);
					printf("TXNRX Pulse control - Alert: %s\n",
					no_os_mdelay(1000);
					no_os_gpio_set_value(gpio_txnrx_pin, 1);
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX Pulse control - TX: %s\n",
					       ensm_mode == ENSM_MODE_TX ? "OK" : "Error");
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
			} else {
				while(1) {
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX control - RX: %s\n",
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_udelay(10);
					printf("TXNRX control - TX: %s\n",
					no_os_mdelay(1000);
					no_os_udelay(10);
					no_os_mdelay(1000);
		} else {
			while(1) {
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_RX);
				printf("SPI control - RX: %s\n",
				no_os_mdelay(1000);
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_ALERT);
				printf("SPI control - Alert: %s\n",
				no_os_mdelay(1000);
				ad9361_set_en_state_machine_mode(ad9361_phy, ENSM_MODE_TX);
				printf("SPI control - TX: %s\n",
				no_os_mdelay(1000);
				no_os_mdelay(1000);
#endif
	ad9361_remove(ad9361_phy);
#ifdef FMCOMMS5
	ad9361_remove(ad9361_phy_b);
#endif
	Xil_DCacheDisable();
	Xil_ICacheDisable();
#endif
	if (altera_bridge_uninit()) {
		printf("Altera Bridge Uninit Error!\n");
		return -1;
#endif
	return 0;
 I changed the LO-frequencies and set down the TX power. I think I did not touch any other ad9361 parameters or the filter-settings. I tried various RX-LO settings, but there is no improvement. I make one snapshot and then everything Is printed to the PC for plotting (inside the while loop).
I also have a few more questions:
1) What exactly is DMA_IRQ_ENABLE doing? Interestingly, I get very different results, depending on whether I disable or enable this statement.
2) How can I switch the TX-channels off, I do not need them. Is there a way to switch off the TX-LO for lower interference?
3) "ADC_DMA_IRQ_EXAMPLE" and "axi_dmac_transfer_nonblocking" disappeared in the driver-libs, what is their replacement?
The preconfigured Linux system on the SD-card provided also shows perfect reception of radio waves with FMCOMMS5 + Zc702, so the hardware has no problem.
Please help me, thank you very much.
I just forgot to add "any other" ad9361 parameters to clarify
[edited by: DIODORO at 2:49 PM (GMT -4) on 14 Mar 2023]
Top Replies
  • I think there is a mistake in line 857 it should jump 16 values and not 4, I have to evaluate that and will report.
  • Sorry, it now works, it was the said mistake. Please skip the code part and answer the questions.
  • Hi  ,
    1) DMA_IRQ_ENABLE enables interrupt operation for the DMA. This changes the way in which DMA transfers are handled (the way in which transfer completion is detected).
    https://github.com/analogdevicesinc/no-OS/blob/3937e4d555ede44c08af08b6ee4f3b8f5fc58a95/drivers/axi_core/axi_dmac/axi_dmac.c#L513
    2) You can have a look at the following thread for this matter:
     RE: Turn AD9361 Tx off via NO-OS?
    3) In the current version, the replacements are DAC_DMA_EXAMPLE and axi_dmac_transfer_start function, respectively.
    https://github.com/analogdevicesinc/no-OS/blob/3937e4d555ede44c08af08b6ee4f3b8f5fc58a95/projects/ad9361/src/main.c#L711
    https://github.com/analogdevicesinc/no-OS/blob/3937e4d555ede44c08af08b6ee4f3b8f5fc58a95/projects/ad9361/src/main.c#L765
    Please let us know if you need further information.
    George
  • Thank you very much George, if I may ask one more question please:
    where can I change the baudrate for the UART-print command? I tried searching for "115200" in the workspace in Vitis and changed every single entry the system could find to e.g. "406800" but still it uses the default baudrate of 115200.
  • Hi ,
    Try adding the following piece of code before your first print command:
    		.type = UART_PS,
    		.baud_rate  = 406800,
    	struct no_os_uart_desc *uart_desc;
    	ret = no_os_uart_init(&uart_desc, &iio_uart_ip);
    	if (ret)
    		return ret;
    	printf("Hello\n");
    George
  • Hi, thanks, unfortunately I'm getting many errors with this code while building, even though I now included no_os_uart.h and no_os_lf256fifo.h.
    ../ad9361/src/main.c:847:9: error: variable 'iio_uart_ip' has initializer but incomplete type
      847 |  struct no_os_uart_init_param iio_uart_ip = {
    ../ad9361/src/main.c:848:4: error: 'struct no_os_uart_init_param' has no member named 'device_id'
      848 |   .device_id = UART_DEVICE_ID,
    In file included from ../ad9361/src/parameters.h:46,
                     from ../ad9361/src/main.c:46:
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters.h:596:35: warning: excess elements in struct initializer
      596 | #define XPAR_PS7_UART_1_DEVICE_ID 0
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters.h:606:34: note: in expansion of macro 'XPAR_PS7_UART_1_DEVICE_ID'
      606 | #define XPAR_XUARTPS_0_DEVICE_ID XPAR_PS7_UART_1_DEVICE_ID
    ../ad9361/src/parameters.h:89:26: note: in expansion of macro 'XPAR_XUARTPS_0_DEVICE_ID'
       89 | #define UART_DEVICE_ID   XPAR_XUARTPS_0_DEVICE_ID
    ../ad9361/src/main.c:848:16: note: in expansion of macro 'UART_DEVICE_ID'
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters.h:596:35: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:849:4: error: 'struct no_os_uart_init_param' has no member named 'irq_id'
      849 |   .irq_id = UART_IRQ_ID,
    In file included from C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters.h:19,
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters_ps.h:236:27: warning: excess elements in struct initializer
      236 | #define XPS_UART1_INT_ID  82U
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters_ps.h:59:30: note: in expansion of macro 'XPS_UART1_INT_ID'
       59 | #define XPAR_XUARTPS_1_INTR  XPS_UART1_INT_ID
    ../ad9361/src/parameters.h:107:24: note: in expansion of macro 'XPAR_XUARTPS_1_INTR'
      107 | #define UART_IRQ_ID    XPAR_XUARTPS_1_INTR
    ../ad9361/src/main.c:849:13: note: in expansion of macro 'UART_IRQ_ID'
    C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/system_top/export/system_top/sw/system_top/standalone_domain/bspinclude/include/xparameters_ps.h:236:27: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:850:4: error: 'struct no_os_uart_init_param' has no member named 'baud_rate'
      850 |   .baud_rate  = 406800,
    ../ad9361/src/main.c:850:17: warning: excess elements in struct initializer
    ../ad9361/src/main.c:850:17: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:851:4: error: 'struct no_os_uart_init_param' has no member named 'size'
      851 |   .size = NO_OS_UART_CS_8,
    ../ad9361/src/main.c:851:11: error: 'NO_OS_UART_CS_8' undeclared (first use in this function); did you mean 'NO_OS_UART_IRQ'?
          |           NO_OS_UART_IRQ
    ../ad9361/src/main.c:851:11: note: each undeclared identifier is reported only once for each function it appears in
    ../ad9361/src/main.c:851:11: warning: excess elements in struct initializer
    ../ad9361/src/main.c:851:11: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:852:4: error: 'struct no_os_uart_init_param' has no member named 'parity'
      852 |   .parity = NO_OS_UART_PAR_NO,
    ../ad9361/src/main.c:852:13: error: 'NO_OS_UART_PAR_NO' undeclared (first use in this function); did you mean 'NO_OS_UART_IRQ'?
          |             NO_OS_UART_IRQ
    ../ad9361/src/main.c:852:13: warning: excess elements in struct initializer
    ../ad9361/src/main.c:852:13: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:853:4: error: 'struct no_os_uart_init_param' has no member named 'stop'
      853 |   .stop = NO_OS_UART_STOP_1_BIT,
    ../ad9361/src/main.c:853:11: error: 'NO_OS_UART_STOP_1_BIT' undeclared (first use in this function)
    ../ad9361/src/main.c:853:11: warning: excess elements in struct initializer
    ../ad9361/src/main.c:853:11: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:854:4: error: 'struct no_os_uart_init_param' has no member named 'extra'
      854 |   .extra = &platform_uart_init_par,
    ../ad9361/src/main.c:854:12: warning: excess elements in struct initializer
    ../ad9361/src/main.c:854:12: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:855:4: error: 'struct no_os_uart_init_param' has no member named 'platform_ops'
      855 |   .platform_ops = &xil_uart_ops
    ../ad9361/src/main.c:855:19: warning: excess elements in struct initializer
    ../ad9361/src/main.c:855:19: note: (near initialization for 'iio_uart_ip')
    ../ad9361/src/main.c:847:31: error: storage size of 'iio_uart_ip' isn't known
    ../ad9361/src/main.c:859:2: error: 'ret' undeclared (first use in this function)
      859 |  ret = no_os_uart_init(&uart_desc, &iio_uart_ip);
    ../ad9361/src/main.c:859:8: warning: implicit declaration of function 'no_os_uart_init'; did you mean 'no_os_spi_init'? [-Wimplicit-function-declaration]
          |        no_os_spi_init
    ../ad9361/src/main.c:847:31: warning: unused variable 'iio_uart_ip' [-Wunused-variable]
    ../ad9361/src/main.c:837:14: warning: variable 'lookupaddr' set but not used [-Wunused-but-set-variable]
      837 |     uint32_t lookupaddr[samples]; // Sinn: Adresse soll um 16 springen dann landet man wieder auf dem nächsten sample des kanals k
    ../ad9361/src/main.c:835:14: warning: unused variable 'data' [-Wunused-variable]
      835 |     uint32_t data;
    ../ad9361/src/main.c:833:14: warning: unused variable 'sampleQ' [-Wunused-variable]
      833 |     uint16_t sampleQ[4][samples];
    ../ad9361/src/main.c:832:14: warning: unused variable 'sampleI' [-Wunused-variable]
      832 |     uint16_t sampleI[4][samples];
    make[2]: *** [ad9361/src/subdir.mk:20: ad9361/src/main.o] Error 1
    make[1]: *** [makefile:41: all] Error 2
    make[1]: Leaving directory 'C:/cygwin64/home/Admin/no-OS/projects/ad9361/build/app/Debug'
  • Hi  ,
    The problem is that some sources are not added to the project. You can easily solve this by using the TINYIIOD flag (make TINYIIOD=y).
    This will enable IIO_SUPPORT (look for the flag in main.c), and then the errors will be concerned with redefining no_os_uart_init_param and platform_uart_init_par. If you use other names for those and declare ret, then build will pass. Other possibility other that renaming the structures is to comment the core corresponding to IIO, if you are not planning to use that.
    From here:
    https://github.com/analogdevicesinc/no-OS/blob/34ebcabd48ed6693d535d6e952e551052427e1dc/projects/ad9361/src/main.c#L813
    to
    https://github.com/analogdevicesinc/no-OS/blob/34ebcabd48ed6693d535d6e952e551052427e1dc/projects/ad9361/src/main.c#L1001
    George
  • Thanks again, so I made a fresh project exactly as you said with make TINYIIOD=y and pasted your code snippet in line 605 in main.c of the NO-OS ad9361 project, no errors but still it is operating at 115200 baud.
    By the way: Do I always have to clean and build the whole project in Vitis if I am only changing main.c? It takes quite long, is there a faster way of doing this?
  • Hi  ,
    Will get back on the UART problem.
    Cleanig the project is not required if you change the code in main.c. However, it is required (make clean command) when adding  the TINYIIOD=y flag.
    George
  • Hi  ,
    Below are the serial messages received for a ZC706. The parameters can be seen below. I have added the code at line 533 in main.c
    picocom -b 230400 -r -l /dev/ttyUSB0 --imap=lfcrlf
    picocom v3.1
    port is        : /dev/ttyUSB0
    flowcontrol    : none
    baudrate is    : 230400
    parity is      : none
    databits are   : 8
    stopbits are   : 1
    escape is      : C-a
    local echo is  : no
    noinit is      : no
    noreset is     : yes
    hangup is      : no
    nolock is      : yes
    send_cmd is    : sz -vv
    receive_cmd is : rz -vv -E
    imap is        : lfcrlf,
    omap is        :
    emap is        : crcrlf,delbs,
    logfile is     : none
    initstring     : none
    exit_after is  : not set
    exit is        : no
    Type [C-a] [C-h] to see available commands
    Terminal ready
    Hello! baudrate: 230400
    ad9361_init : Unsupported PRODUCT_ID 0xFFad9361_init : AD936x initialization error
    cf-ad9361-dds-core-lpc: Status errors
    Please let me know if placing the code earlier in main.c solved the problem.
    George
