This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Running ad9467_fmc_ebz.c test cases and most of tests are failing
Product Number: AD9467_EVAL_BOARD
Software Version: NO_OS (2018_R2)
We are using the following hardware:
  1. ADC9467 Eval board:
  2. Software: Xilinx SDK 2018.2
  3. Version: NO_OS (2018_R2)
We take input from discovery 2 waveforms software setup shown below
SDK Terminal shows below response
ADI AD9467-FMC-EBZ Reference Design
AD9467 CHIP ID: 0x50
AD9467 CHIP GRADE: 0x20
AD9517 CHIP ID: 0x4d3d3d3
adc_setup adc core initialized (1 MHz).
AD9467[0x016]: 00
adc_delay: setting zero error delay (5)
Error field (0=success, 1=fail):
00000000000011111111111111111111
ADC Test: mode - MIDSCALE
format - OFFSET BINARY
Test passed
format - TWOS_COMPLEMENT
ERROR[ 0]: rcv(80008000), exp(00000000)
ERROR[ 1]: rcv(80008000), exp(00000000)
ERROR[ 2]: rcv(80008000), exp(00000000)
ERROR[ 3]: rcv(80008000), exp(00000000)
ERROR[ 4]: rcv(80008000), exp(00000000)
ERROR[ 5]: rcv(80008000), exp(00000000)
ERROR[ 6]: rcv(80008000), exp(00000000)
ERROR[ 7]: rcv(80008000), exp(00000000)
ERROR[ 8]: rcv(80008000), exp(00000000)
ERROR[ 9]: rcv(80008000), exp(00000000)
ERROR[10]: rcv(80008000), exp(00000000)
ERROR[11]: rcv(80008000), exp(00000000)
ERROR[12]: rcv(80008000), exp(00000000)
ERROR[13]: rcv(80008000), exp(00000000)
ERROR[14]: rcv(80008000), exp(00000000)
ERROR[15]: rcv(80008000), exp(00000000)
ERROR[16]: rcv(80008000), exp(00000000)
ERROR[17]: rcv(80008000), exp(00000000)
ERROR[18]: rcv(80008000), exp(00000000)
ERROR[19]: rcv(80008000), exp(00000000)
ERROR[20]: rcv(80008000), exp(00000000)
ERROR[21]: rcv(80008000), exp(00000000)
ERROR[22]: rcv(80008000), exp(00000000)
ERROR[23]: rcv(80008000), exp(00000000)
ERROR[24]: rcv(80008000), exp(00000000)
ERROR[25]: rcv(80008000), exp(00000000)
ERROR[26]: rcv(80008000), exp(00000000)
ERROR[27]: rcv(80008000), exp(00000000)
ERROR[28]: rcv(80008000), exp(00000000)
ERROR[29]: rcv(80008000), exp(00000000)
ERROR[30]: rcv(80008000), exp(00000000)
ERROR[31]: rcv(80008000), exp(00000000)
Testing done.
Start capturing data...
Done.
We successfully generated bitstream from the hdl_2018_R2 from https://github.com/analogdevicesinc/hdl/tree/hdl_2018_r2.
Kindly inform tell us about the Error shown in the SDK terminal.
Plz help ASAP
[locked by: buha at 1:24 PM (GMT -5) on 24 Feb 2023]
Parents Reply Children
No Data
