AD9364 - Firmware crashes when using CMOS TDD mode
I want to operate the reference design in CMOS, TDD mode using the NO-OS firmware. However, when in CMOS mode (disable lvds_mode_en -- line 187 in the listing -- flag in init params) I can consistently get the firmware to fail on the next SPI transaction after the ad9361_init(); sequence.
AD9361_InitParam default_init_param = {
	/* Device selection */
	ID_AD9364,	// dev_sel
	/* Reference Clock */
	40000000UL,	//reference_clk_rate
	/* Base Configuration */
	0,		//two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
	1,		//one_rx_one_tx_mode_use_rx_num *** adi,1rx-1tx-mode-use-rx-num
	1,		//one_rx_one_tx_mode_use_tx_num *** adi,1rx-1tx-mode-use-tx-num
	0,		//frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
	0,		//frequency_division_duplex_independent_mode_enable *** adi,frequency-division-duplex-independent-mode-enable
	0,		//tdd_use_dual_synth_mode_enable *** adi,tdd-use-dual-synth-mode-enable
	0,		//tdd_skip_vco_cal_enable *** adi,tdd-skip-vco-cal-enable
	0,		//tx_fastlock_delay_ns *** adi,tx-fastlock-delay-ns
	0,		//rx_fastlock_delay_ns *** adi,rx-fastlock-delay-ns
	0,		//rx_fastlock_pincontrol_enable *** adi,rx-fastlock-pincontrol-enable
	0,		//tx_fastlock_pincontrol_enable *** adi,tx-fastlock-pincontrol-enable
	0,		//external_rx_lo_enable *** adi,external-rx-lo-enable
	0,		//external_tx_lo_enable *** adi,external-tx-lo-enable
	5,		//dc_offset_tracking_update_event_mask *** adi,dc-offset-tracking-update-event-mask
	6,		//dc_offset_attenuation_high_range *** adi,dc-offset-attenuation-high-range
	5,		//dc_offset_attenuation_low_range *** adi,dc-offset-attenuation-low-range
	0x28,	//dc_offset_count_high_range *** adi,dc-offset-count-high-range
	0x32,	//dc_offset_count_low_range *** adi,dc-offset-count-low-range
	0,		//split_gain_table_mode_enable *** adi,split-gain-table-mode-enable
	MAX_SYNTH_FREF,	//trx_synthesizer_target_fref_overwrite_hz *** adi,trx-synthesizer-target-fref-overwrite-hz
	0,		// qec_tracking_slow_mode_enable *** adi,qec-tracking-slow-mode-enable
	/* ENSM Control */
	0,		//ensm_enable_pin_pulse_mode_enable *** adi,ensm-enable-pin-pulse-mode-enable
	0,		//ensm_enable_txnrx_control_enable *** adi,ensm-enable-txnrx-control-enable
	/* LO Control */
	2400000000UL,	//rx_synthesizer_frequency_hz *** adi,rx-synthesizer-frequency-hz
	2200000000UL,	//tx_synthesizer_frequency_hz *** adi,tx-synthesizer-frequency-hz
	1,				//tx_lo_powerdown_managed_enable *** adi,tx-lo-powerdown-managed-enable
	/* Rate & BW Control */
	{983040000, 245760000, 122880000, 61440000, 30720000, 30720000},// rx_path_clock_frequencies[6] *** adi,rx-path-clock-frequencies
	{983040000, 122880000, 122880000, 61440000, 30720000, 30720000},// tx_path_clock_frequencies[6] *** adi,tx-path-clock-frequencies
	18000000,//rf_rx_bandwidth_hz *** adi,rf-rx-bandwidth-hz
	18000000,//rf_tx_bandwidth_hz *** adi,rf-tx-bandwidth-hz
	/* RF Port Control */
	0,		//rx_rf_port_input_select *** adi,rx-rf-port-input-select
	1,		//tx_rf_port_input_select *** adi,tx-rf-port-input-select
	/* TX Attenuation Control */
	0,	//tx_attenuation_mdB *** adi,tx-attenuation-mdB
	0,		//update_tx_gain_in_alert_enable *** adi,update-tx-gain-in-alert-enable
	/* Reference Clock Control */
	0,		//xo_disable_use_ext_refclk_enable *** adi,xo-disable-use-ext-refclk-enable
	{8, 5920},	//dcxo_coarse_and_fine_tune[2] *** adi,dcxo-coarse-and-fine-tune
	CLKOUT_DISABLE,	//clk_output_mode_select *** adi,clk-output-mode-select
	/* Gain Control */
	2,		//gc_rx1_mode *** adi,gc-rx1-mode
	2,		//gc_rx2_mode *** adi,gc-rx2-mode
	58,		//gc_adc_large_overload_thresh *** adi,gc-adc-large-overload-thresh
	4,		//gc_adc_ovr_sample_size *** adi,gc-adc-ovr-sample-size
	47,		//gc_adc_small_overload_thresh *** adi,gc-adc-small-overload-thresh
	8192,	//gc_dec_pow_measurement_duration *** adi,gc-dec-pow-measurement-duration
	0,		//gc_dig_gain_enable *** adi,gc-dig-gain-enable
	800,	//gc_lmt_overload_high_thresh *** adi,gc-lmt-overload-high-thresh
	704,	//gc_lmt_overload_low_thresh *** adi,gc-lmt-overload-low-thresh
	24,		//gc_low_power_thresh *** adi,gc-low-power-thresh
	15,		//gc_max_dig_gain *** adi,gc-max-dig-gain
	0,		//gc_use_rx_fir_out_for_dec_pwr_meas_enable *** adi,gc-use-rx-fir-out-for-dec-pwr-meas-enable
	/* Gain MGC Control */
	2,		//mgc_dec_gain_step *** adi,mgc-dec-gain-step
	2,		//mgc_inc_gain_step *** adi,mgc-inc-gain-step
	0,		//mgc_rx1_ctrl_inp_enable *** adi,mgc-rx1-ctrl-inp-enable
	0,		//mgc_rx2_ctrl_inp_enable *** adi,mgc-rx2-ctrl-inp-enable
	0,		//mgc_split_table_ctrl_inp_gain_mode *** adi,mgc-split-table-ctrl-inp-gain-mode
	/* Gain AGC Control */
	10,		//agc_adc_large_overload_exceed_counter *** adi,agc-adc-large-overload-exceed-counter
	2,		//agc_adc_large_overload_inc_steps *** adi,agc-adc-large-overload-inc-steps
	0,		//agc_adc_lmt_small_overload_prevent_gain_inc_enable *** adi,agc-adc-lmt-small-overload-prevent-gain-inc-enable
	10,		//agc_adc_small_overload_exceed_counter *** adi,agc-adc-small-overload-exceed-counter
	4,		//agc_dig_gain_step_size *** adi,agc-dig-gain-step-size
	3,		//agc_dig_saturation_exceed_counter *** adi,agc-dig-saturation-exceed-counter
	1000,	// agc_gain_update_interval_us *** adi,agc-gain-update-interval-us
	0,		//agc_immed_gain_change_if_large_adc_overload_enable *** adi,agc-immed-gain-change-if-large-adc-overload-enable
	0,		//agc_immed_gain_change_if_large_lmt_overload_enable *** adi,agc-immed-gain-change-if-large-lmt-overload-enable
	10,		//agc_inner_thresh_high *** adi,agc-inner-thresh-high
	1,		//agc_inner_thresh_high_dec_steps *** adi,agc-inner-thresh-high-dec-steps
	12,		//agc_inner_thresh_low *** adi,agc-inner-thresh-low
	1,		//agc_inner_thresh_low_inc_steps *** adi,agc-inner-thresh-low-inc-steps
	10,		//agc_lmt_overload_large_exceed_counter *** adi,agc-lmt-overload-large-exceed-counter
	2,		//agc_lmt_overload_large_inc_steps *** adi,agc-lmt-overload-large-inc-steps
	10,		//agc_lmt_overload_small_exceed_counter *** adi,agc-lmt-overload-small-exceed-counter
	5,		//agc_outer_thresh_high *** adi,agc-outer-thresh-high
	2,		//agc_outer_thresh_high_dec_steps *** adi,agc-outer-thresh-high-dec-steps
	18,		//agc_outer_thresh_low *** adi,agc-outer-thresh-low
	2,		//agc_outer_thresh_low_inc_steps *** adi,agc-outer-thresh-low-inc-steps
	1,		//agc_attack_delay_extra_margin_us; *** adi,agc-attack-delay-extra-margin-us
	0,		//agc_sync_for_gain_counter_enable *** adi,agc-sync-for-gain-counter-enable
	/* Fast AGC */
	64,		//fagc_dec_pow_measuremnt_duration ***  adi,fagc-dec-pow-measurement-duration
	260,	//fagc_state_wait_time_ns ***  adi,fagc-state-wait-time-ns
	/* Fast AGC - Low Power */
	0,		//fagc_allow_agc_gain_increase ***  adi,fagc-allow-agc-gain-increase-enable
	5,		//fagc_lp_thresh_increment_time ***  adi,fagc-lp-thresh-increment-time
	1,		//fagc_lp_thresh_increment_steps ***  adi,fagc-lp-thresh-increment-steps
	/* Fast AGC - Lock Level (Lock Level is set via slow AGC inner high threshold) */
	1,		//fagc_lock_level_lmt_gain_increase_en ***  adi,fagc-lock-level-lmt-gain-increase-enable
	5,		//fagc_lock_level_gain_increase_upper_limit ***  adi,fagc-lock-level-gain-increase-upper-limit
	/* Fast AGC - Peak Detectors and Final Settling */
	1,		//fagc_lpf_final_settling_steps ***  adi,fagc-lpf-final-settling-steps
	1,		//fagc_lmt_final_settling_steps ***  adi,fagc-lmt-final-settling-steps
	3,		//fagc_final_overrange_count ***  adi,fagc-final-overrange-count
	/* Fast AGC - Final Power Test */
	0,		//fagc_gain_increase_after_gain_lock_en ***  adi,fagc-gain-increase-after-gain-lock-enable
	/* Fast AGC - Unlocking the Gain */
	0,		//fagc_gain_index_type_after_exit_rx_mode ***  adi,fagc-gain-index-type-after-exit-rx-mode
	1,		//fagc_use_last_lock_level_for_set_gain_en ***  adi,fagc-use-last-lock-level-for-set-gain-enable
	1,		//fagc_rst_gla_stronger_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable
	5,		//fagc_optimized_gain_offset ***  adi,fagc-optimized-gain-offset
	10,		//fagc_rst_gla_stronger_sig_thresh_above_ll ***  adi,fagc-rst-gla-stronger-sig-thresh-above-ll
	1,		//fagc_rst_gla_engergy_lost_sig_thresh_exceeded_en ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable
	1,		//fagc_rst_gla_engergy_lost_goto_optim_gain_en ***  adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable
	10,		//fagc_rst_gla_engergy_lost_sig_thresh_below_ll ***  adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll
	8,		//fagc_energy_lost_stronger_sig_gain_lock_exit_cnt ***  adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt
	1,		//fagc_rst_gla_large_adc_overload_en ***  adi,fagc-rst-gla-large-adc-overload-enable
	1,		//fagc_rst_gla_large_lmt_overload_en ***  adi,fagc-rst-gla-large-lmt-overload-enable
	0,		//fagc_rst_gla_en_agc_pulled_high_en ***  adi,fagc-rst-gla-en-agc-pulled-high-enable
	0,		//fagc_rst_gla_if_en_agc_pulled_high_mode ***  adi,fagc-rst-gla-if-en-agc-pulled-high-mode
	64,		//fagc_power_measurement_duration_in_state5 ***  adi,fagc-power-measurement-duration-in-state5
	2,		//fagc_large_overload_inc_steps *** adi,fagc-adc-large-overload-inc-steps
	/* RSSI Control */
	1,		//rssi_delay *** adi,rssi-delay
	1000,	//rssi_duration *** adi,rssi-duration
	3,		//rssi_restart_mode *** adi,rssi-restart-mode
	0,		//rssi_unit_is_rx_samples_enable *** adi,rssi-unit-is-rx-samples-enable
	1,		//rssi_wait *** adi,rssi-wait
	/* Aux ADC Control */
	256,	//aux_adc_decimation *** adi,aux-adc-decimation
	40000000UL,	//aux_adc_rate *** adi,aux-adc-rate
	/* AuxDAC Control */
	1,		//aux_dac_manual_mode_enable ***  adi,aux-dac-manual-mode-enable
	0,		//aux_dac1_default_value_mV ***  adi,aux-dac1-default-value-mV
	0,		//aux_dac1_active_in_rx_enable ***  adi,aux-dac1-active-in-rx-enable
	0,		//aux_dac1_active_in_tx_enable ***  adi,aux-dac1-active-in-tx-enable
	0,		//aux_dac1_active_in_alert_enable ***  adi,aux-dac1-active-in-alert-enable
	0,		//aux_dac1_rx_delay_us ***  adi,aux-dac1-rx-delay-us
	0,		//aux_dac1_tx_delay_us ***  adi,aux-dac1-tx-delay-us
	0,		//aux_dac2_default_value_mV ***  adi,aux-dac2-default-value-mV
	0,		//aux_dac2_active_in_rx_enable ***  adi,aux-dac2-active-in-rx-enable
	0,		//aux_dac2_active_in_tx_enable ***  adi,aux-dac2-active-in-tx-enable
	0,		//aux_dac2_active_in_alert_enable ***  adi,aux-dac2-active-in-alert-enable
	0,		//aux_dac2_rx_delay_us ***  adi,aux-dac2-rx-delay-us
	0,		//aux_dac2_tx_delay_us ***  adi,aux-dac2-tx-delay-us
	/* Temperature Sensor Control */
	256,	//temp_sense_decimation *** adi,temp-sense-decimation
	1000,	//temp_sense_measurement_interval_ms *** adi,temp-sense-measurement-interval-ms
	0xCE,	//temp_sense_offset_signed *** adi,temp-sense-offset-signed
	1,		//temp_sense_periodic_measurement_enable *** adi,temp-sense-periodic-measurement-enable
	/* Control Out Setup */
	0xFF,	//ctrl_outs_enable_mask *** adi,ctrl-outs-enable-mask
	0,		//ctrl_outs_index *** adi,ctrl-outs-index
	/* External LNA Control */
	0,		//elna_settling_delay_ns *** adi,elna-settling-delay-ns
	0,		//elna_gain_mdB *** adi,elna-gain-mdB
	0,		//elna_bypass_loss_mdB *** adi,elna-bypass-loss-mdB
	0,		//elna_rx1_gpo0_control_enable *** adi,elna-rx1-gpo0-control-enable
	0,		//elna_rx2_gpo1_control_enable *** adi,elna-rx2-gpo1-control-enable
	0,		//elna_gaintable_all_index_enable *** adi,elna-gaintable-all-index-enable
	/* Digital Interface Control */
	0,		//digital_interface_tune_skip_mode *** adi,digital-interface-tune-skip-mode
	0,		//digital_interface_tune_fir_disable *** adi,digital-interface-tune-fir-disable
	1,		//pp_tx_swap_enable *** adi,pp-tx-swap-enable
	1,		//pp_rx_swap_enable *** adi,pp-rx-swap-enable
	0,		//tx_channel_swap_enable *** adi,tx-channel-swap-enable
	0,		//rx_channel_swap_enable *** adi,rx-channel-swap-enable
	1,		//rx_frame_pulse_mode_enable *** adi,rx-frame-pulse-mode-enable
	0,		//two_t_two_r_timing_enable *** adi,2t2r-timing-enable
	0,		//invert_data_bus_enable *** adi,invert-data-bus-enable
	0,		//invert_data_clk_enable *** adi,invert-data-clk-enable
	0,		//fdd_alt_word_order_enable *** adi,fdd-alt-word-order-enable
	0,		//invert_rx_frame_enable *** adi,invert-rx-frame-enable
	0,		//fdd_rx_rate_2tx_enable *** adi,fdd-rx-rate-2tx-enable
	0,		//swap_ports_enable *** adi,swap-ports-enable
	1,		//single_data_rate_enable *** adi,single-data-rate-enable
	0,		//lvds_mode_enable *** adi,lvds-mode-enable
	1,		//half_duplex_mode_enable *** adi,half-duplex-mode-enable
	0,		//single_port_mode_enable *** adi,single-port-mode-enable
	0,		//full_port_enable *** adi,full-port-enable
	0,		//full_duplex_swap_bits_enable *** adi,full-duplex-swap-bits-enable
	0,		//delay_rx_data *** adi,delay-rx-data
	0,		//rx_data_clock_delay *** adi,rx-data-clock-delay
	4,		//rx_data_delay *** adi,rx-data-delay
	7,		//tx_fb_clock_delay *** adi,tx-fb-clock-delay
	0,		//tx_data_delay *** adi,tx-data-delay
#ifdef ALTERA_PLATFORM
	300,	//lvds_bias_mV *** adi,lvds-bias-mV
#else
	150,	//lvds_bias_mV *** adi,lvds-bias-mV
#endif
	1,		//lvds_rx_onchip_termination_enable *** adi,lvds-rx-onchip-termination-enable
	0,		//rx1rx2_phase_inversion_en *** adi,rx1-rx2-phase-inversion-enable
	0xFF,	//lvds_invert1_control *** adi,lvds-invert1-control
	0x0F,	//lvds_invert2_control *** adi,lvds-invert2-control
	/* GPO Control */
	0,		//gpo_manual_mode_enable *** adi,gpo-manual-mode-enable
	0,		//gpo_manual_mode_enable_mask *** adi,gpo-manual-mode-enable-mask
	0,		//gpo0_inactive_state_high_enable *** adi,gpo0-inactive-state-high-enable
	0,		//gpo1_inactive_state_high_enable *** adi,gpo1-inactive-state-high-enable
	0,		//gpo2_inactive_state_high_enable *** adi,gpo2-inactive-state-high-enable
	0,		//gpo3_inactive_state_high_enable *** adi,gpo3-inactive-state-high-enable
	0,		//gpo0_slave_rx_enable *** adi,gpo0-slave-rx-enable
	0,		//gpo0_slave_tx_enable *** adi,gpo0-slave-tx-enable
	0,		//gpo1_slave_rx_enable *** adi,gpo1-slave-rx-enable
	0,		//gpo1_slave_tx_enable *** adi,gpo1-slave-tx-enable
	0,		//gpo2_slave_rx_enable *** adi,gpo2-slave-rx-enable
	0,		//gpo2_slave_tx_enable *** adi,gpo2-slave-tx-enable
	0,		//gpo3_slave_rx_enable *** adi,gpo3-slave-rx-enable
	0,		//gpo3_slave_tx_enable *** adi,gpo3-slave-tx-enable
	0,		//gpo0_rx_delay_us *** adi,gpo0-rx-delay-us
	0,		//gpo0_tx_delay_us *** adi,gpo0-tx-delay-us
	0,		//gpo1_rx_delay_us *** adi,gpo1-rx-delay-us
	0,		//gpo1_tx_delay_us *** adi,gpo1-tx-delay-us
	0,		//gpo2_rx_delay_us *** adi,gpo2-rx-delay-us
	0,		//gpo2_tx_delay_us *** adi,gpo2-tx-delay-us
	0,		//gpo3_rx_delay_us *** adi,gpo3-rx-delay-us
	0,		//gpo3_tx_delay_us *** adi,gpo3-tx-delay-us
	/* Tx Monitor Control */
	37000,	//low_high_gain_threshold_mdB *** adi,txmon-low-high-thresh
	0,		//low_gain_dB *** adi,txmon-low-gain
	24,		//high_gain_dB *** adi,txmon-high-gain
	0,		//tx_mon_track_en *** adi,txmon-dc-tracking-enable
	0,		//one_shot_mode_en *** adi,txmon-one-shot-mode-enable
	511,	//tx_mon_delay *** adi,txmon-delay
	8192,	//tx_mon_duration *** adi,txmon-duration
	2,		//tx1_mon_front_end_gain *** adi,txmon-1-front-end-gain
	2,		//tx2_mon_front_end_gain *** adi,txmon-2-front-end-gain
	48,		//tx1_mon_lo_cm *** adi,txmon-1-lo-cm
	48,		//tx2_mon_lo_cm *** adi,txmon-2-lo-cm
	/* GPIO definitions */
		.number = -1,
		.platform_ops = GPIO_OPS,
		.extra = GPIO_PARAM
	},		//gpio_resetb *** reset-gpios
	/* MCS Sync */
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_sync *** sync-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw1 *** cal-sw1-gpios
		.number = -1,
		.extra = GPIO_PARAM
	},		//gpio_cal_sw2 *** cal-sw2-gpios
		.device_id = SPI_DEVICE_ID,
		.mode = NO_OS_SPI_MODE_1,
		.chip_select = SPI_CS,
		.platform_ops = SPI_OPS,
		.extra = SPI_PARAM
	/* External LO clocks */
	NULL,	//(*ad9361_rfpll_ext_recalc_rate)()
	NULL,	//(*ad9361_rfpll_ext_round_rate)()
	NULL,	//(*ad9361_rfpll_ext_set_rate)()
#ifndef AXI_ADC_NOT_PRESENT
	&rx_adc_init,	// *rx_adc_init
	&tx_dac_init,   // *tx_dac_init
#endif
I am using the example project from the NO OS drivers, 2019_r2. Line 3 in this listing is where the firmware fails in CMOS mode.
	ad9361_init(&ad9361_phy, &default_init_param);
	ad9361_set_tx_fir_config(ad9361_phy, tx_fir_config);
	ad9361_set_rx_fir_config(ad9361_phy, rx_fir_config);
    ad9361_trx_load_enable_fir(ad9361_phy, rx_fir_config, tx_fir_config);
More specifically, the fail can be found in ad9361_set_tx_fir_config() -> ad9361_load_fir_filter_coef() -> ad9361_ensm_force_state() ->
dev_ensm_state = ad9361_spi_readf(spi, REG_STATE, ENSM_STATE(~0));
Line 16 in this listing below.
 * Force Enable State Machine (ENSM) to the desired state (internally used only).
 * @param phy The AD9361 state structure.
 * @param ensm_state The ENSM state [ENSM_STATE_SLEEP_WAIT, ENSM_STATE_ALERT,
 *                   ENSM_STATE_TX, ENSM_STATE_TX_FLUSH, ENSM_STATE_RX,
 *                   ENSM_STATE_RX_FLUSH, ENSM_STATE_FDD, ENSM_STATE_FDD_FLUSH].
 * @return None.
void ad9361_ensm_force_state(struct ad9361_rf_phy *phy, uint8_t ensm_state)
	struct no_os_spi_desc *spi = phy->spi;
	uint8_t dev_ensm_state;
	int32_t rc, timeout = 10;
	uint32_t val;
	phy->prev_ensm_state = dev_ensm_state;
	if (dev_ensm_state == ensm_state) {
		dev_dbg(dev, "Nothing to do, device is already in %d state",
			ensm_state);
		goto out;
	dev_dbg(dev, "Device is in %x state, forcing to %x", dev_ensm_state,
		ensm_state);
	val = ad9361_spi_read(spi, REG_ENSM_CONFIG_1);
	/* Enable control through SPI writes, and take out from
	* Alert
	if (val & ENABLE_ENSM_PIN_CTRL) {
		val &= ~ENABLE_ENSM_PIN_CTRL;
		phy->ensm_pin_ctl_en = true;
	} else {
		phy->ensm_pin_ctl_en = false;
	if (dev_ensm_state)
		val &= ~(TO_ALERT);
	switch (ensm_state) {
	case ENSM_STATE_TX:
	case ENSM_STATE_FDD:
		val |= FORCE_TX_ON;
		break;
	case ENSM_STATE_RX:
		val |= FORCE_RX_ON;
		break;
	case ENSM_STATE_ALERT:
		val &= ~(FORCE_TX_ON | FORCE_RX_ON);
		val |= TO_ALERT | FORCE_ALERT_STATE;
		break;
	default:
		dev_err(dev, "No handling for forcing %d ensm state",
			ensm_state);
		goto out;
	ad9361_spi_write(spi, REG_ENSM_CONFIG_1, TO_ALERT | FORCE_ALERT_STATE);
	rc = ad9361_spi_write(spi, REG_ENSM_CONFIG_1, val);
	if (rc) {
		dev_err(dev, "Failed to write ENSM_CONFIG_1\n");
		goto out;
	while (ad9361_ensm_get_state(phy) != ensm_state && --timeout) {
		no_os_mdelay(1);
	if (timeout == 0)
		dev_err(dev, "Failed to restore state");
out:
	return;
However, if I change this lvds_mode_en flag back to 1 (leaving everything else the same), the firmware runs as expected, and all SPI writes behave like normal.
I'm confused why the system would fail on a SPI read for the ENSM, as I'm not sure it has anything to do with CMOS/LVDS mode, is that correct? It also appears to run through all of the SPI read/writes in the ad9361_init() sequence with no problems.
Is there some change in the reference design that needs to be made to support CMOS mode? If so, what are those changes exactly? Or is there some firmware code that can be added to resolve this issue?
EDIT: I've found that when in CMOS mode the ad9361_dig_tune_delay() function in the ad9361_post_setup() routine fails, but I'm not sure what is causing it to fail. Is the reference design not set up for this, or is there some setting I can use to operate in CMOS mode?
Added progress on issue: fail on ad9361_dig_tune_delay()
[edited by: AbeSteez at 10:49 PM (GMT -4) on 5 May 2022]
Top Replies
