Adrv9008-1, problem with axi_dmac_transfer (infinite loop)
Hello!
There is ADRV9008-1, hdl (latest version, like NO-os) built on the basis of the AD9371 project on KCU105 in order to assemble the ADRV9009 project on MicroBlaze. NO-os is based on ADRV9009. Used by Vivado 2020.2.
The project is working, ADRV9008-1 is fully initialized with two warnings (TAL_DEFRAMER_A status 0x10, TAL_FRAMER_A status 0x21).
The line with DAC_DMA_EXAMPLE was uncommented in order to write any data from the ADC to RAM, but the program hangs on axi_dmac_transfer, inside which an endless loop is formed from lines 273 to 277, which means that the current transfer is not completed.
What could be the problem? I checked the base address rx_dma, ADC, everything matches the hdl project.
Just in case, I provide the project in hdl: drive.google.com/.../view
No-os: drive.google.com/.../view
Sincerely, Dendy.
Top Replies
  • Hello  ,
    We had a closer look on DMA projects and we might have found the cause of the hanging of the transfer. Before capturing samples (initiating DMA transfers), AXI DMA channels (at least one)…
Parents Reply Children
