DEVICE CONFIGURATION REGISTER MAP AD9144: No correspondence between SDK and datasheet
Dear community,
I am checking the writing/reading operations into specific registers in the SDK and checking them in the datasheet. However, they look different. For instance, let's take the following example:
I write a specific value in the following register:
I check the address of this register:
I go to the datasheet to verify that this register is the SYNC CONTROL register:
As you can see, that register is NOT the SYNC CONTROL. The good one is the 0x03A and NOT the 0x44:
Why there is no correspondence between the registers in the SDK and the registers in the datasheet? What am I missing?
I am using the DAQ2 + ZC706 project. The DAQ2 has the AD9144 DAC, this is the datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/AD9144.pdf
You can find the Register mapping at the end (page 87)
Thank you so much!
Miguel Angel
Top Replies
Parents Reply Children
No Data
