Testing of Gyroscope
Thank you for your interest in the ADXRS645. I suspect that using this breakout board would enable simple connection to an A/D device that NI offers.
EVAL-ADXRS645 Evaluation Board | Analog Devices
In making this connection, I would encourage you to make the connection as short and clean as practical, as the 100 deg/hour in-run bias stability will have an equivalent signal level of ~25uV.
That does not set the expectation for the ADC resolution, but it does provide a guideline for the level of external noise (from the connection or setup) which can influence the most key behaviors.
I hope that this helps.
