My customer seals the resin enclosure with ultrasonic welding equipment.
The inside of the case is PCB and ADXL 343 is mounted.
Do you have any knowledge about the effects of ultrasound on the device?
Best regards
ADXL343
Recommended for New Designs
The ADXL343 is a versatile 3-axis, digital-output, low g MEMS accelerometer. Selectable measurement range and bandwidth, and configurable, built-in motion...
Datasheet
ADXL343 on Analog.com
ADXL323
Not Recommended for New Designs
The ADXL323 is a small, thin, low power, complete 2-axis accelerometer with signal-conditioned voltage outputs, all on a single, monolithic IC. The product...
Datasheet
ADXL323 on Analog.com
Best regards
I told the customer that Unpowered absolute maximum rating is 10,000 g.
Thank you very much.
Primary area of consideration will be in managing the vibration and shock that the MEMS components will experience.
