Hi.
I'm using adxrs623 for stabillaizing application (Quadrotor).
But as i detected the null voltage which should be 2.5V, as mentioned in Datasheet, is not exact ! It's around 2.5v+- 0.005v. which it cause the Scale Factor changes around 7.5mv to 17.5mv!!!!!
My question is, is it usual? if it is, what can be the solution?
Looking forward to hearing from you. Thanks
