Is the ADXRS645 roll gyro affected by centripetal acceleration?
Thank you for posting this question. There are a couple of responses to consider. What is the peak level of acceleration that you are considering?
Hi NM
About 4m/s^2
Roger
OK, you can use the Linear Acceleration Effect specification to estimate the response on the output of the ADXRS645.
Does that help?
Here is quick view pf the specification from the ADXRS645 datasheet (click on image for higher resolution):
Hello! I hope that you are doing well. Was this information sufficient? If so, could you mark the most appropriate response with CORRECT ANSWER, if a post deserves it. If not, we look forward to any clarifying information that you can provide.
