help a rookie out
The user is using an ADXL001 accelerometer and a USB-1608GX-2AO DAQ to measure g-forces during a drop test. To convert voltage readings to g-forces, subtract the resting bias voltage (2.34V) from the impact voltage, then divide by the sensitivity (0.0242V/g). Orientation changes during impact can introduce up to 1g of error, so ensure correct sensor orientation.
Hey guys,
I recently purchased an accelerometer and data acquisition module to do some shock testing. I am looking to find the largest g force an object sees when I drop it. Links to my accelerometer and DAQ are below.
When I hook everything up (operating at 5V supply), my accelerometer reads an average voltage of about 2.34 V. After a drop I can save all my data points into a .csv file and then find the maximum and minimum values, but they are still voltages. According to the data sheet of the accelerometer, it has a sensitivity of 24.2 mV/g. To convert this into g's do we need to just divide the voltage by .0242 or is there more to it than this?
I also noticed that our average voltage reading when the accelerometer is resting is around 2.34V. Would this mean that to get the g's of our impact we would first want to take the difference of the reading at that point and the average, and then divide by the sensitivity?
accelerometer data sheet: http://www.analog.com/static/imported-files/data_sheets/ADXL001.pdf
DAQ: http://www.mccdaq.com/usb-data-acquisition/USB-1608GX-2AO.aspx
Thanks in advance,
Rob
  • Hi Rob,
    Yes, I think that you are on the right track. In your approach, 2.34V would be the "zero-stimulus" bias, which you will want to remove before apply the (1g/0.0242V) scale factor. Keep in mind that the difference in orientation of the sensor on the table and when it makes the impact on the ground, can add up to 1g of error in the response.  I hope that helps!
    Best,
    NevadaMark
  • thanks a lot! I'm new to this so its definitely good to know that I'm on the right track. I'll check the data sheet for the accelerometer to make sure we have it oriented correctly
  • That will be a good step, but it always good to keep that in the back of your mind because you might not always be able to control the orientation of the instrument, at the point of impact.  Or, it might be hard to track its "twisting" as it responds (recoil) to the impact.  Look forward to hearing how this works for you.
    Best,
    NevadaMark
