Re: ADIS16209
Dear NevadaMark,
Thanks for your quick response!!
I need to construct a huge chimney using the Technic of slip form construction.Here we build the chimney part by part i.e 1st will construct a height of example 2 meter later the arms will be raised with some mechanism now again the concrete will be poured to all the nine arms.Now i need a MEMS sensor to check weather the poured concrete is in same level in all the nine arms.So i request you to suggest weather can we make all sensor communicate each other & If i buy ADIS16209 of 10 sensors along with that what all need to be buyed??
Satish
