Can you summarize the options you have for vibration sensing?
All accelerometers are capable of measuring vibration. According to Webster's Dictionary, "to vibrate" means "to move or to cause to move back and forth rapidly." Selection criteria for a paricular application will normally fall into two separate categories: function and performance. Starting with function, here are some simple examples.
ADXL001: 1-Axis, +/-70/250/500g range, 22kHz, Analog output
ADIS16220: 1-Axis, +/-70g range, 22kHz, Digital output, capture buffer, 100kSPS
ADIS16223: 3-Axis, +/-70g range, 22kHz, Digital output, capture buffer, 72.9kSPS
ADIS16227: 3-Axis, +/-70g range, 22kHz, Digital output, capture buffer, FFT processing, 100kSPS
ADIS16228: 3-Axis, +/-18g range, 5kHz, Digital output, capture buffer, FFT processing, 20kSPS, Low-noise
