KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
| SLA Status | Assignee | Support Status |
| SLA Closed. Met after -7 hours |
Open | |
ADXL001
Obsolete
The ADXL001 is a major advance over previous generations of accelerometers providing high performance and wide bandwidth. This part is ideal for industrial...
ADXL001 on Analog.com
How is it better to mount adxl001 500g on my mechanical structure?!
ambugua - Moved from StudentZone (Analog Dialogue) to Other Products (EN). Post date updated from Friday, November 3, 2017 7:46 PM UTC to Tuesday, June 24, 2025 11:35 PM UTC to reflect the move.
stephenv - Moved from Other Products (EN) to MEMS Inertial Sensors. Post date updated from Tuesday, June 24, 2025 11:35 PM UTC to Tuesday, February 3, 2026 8:42 PM UTC to reflect the move.
Based on your picture, you want side-to-side acceleration measurement? Or do you want up-and-down acceleration measurement? The mounting screw holes imply the later.
In any case, to get good data over, maybe, 5g, you will have to put the chip in direct contact with the case. At 500g, case strain can give you significant errors too. I'd suggest you mount the device's lid to a short (0.1") post that is machined into the case, in the direction of sensitivity. That means notching the post so that the chip's (opposite pin 8) side is resting on the post, and the labeled area of the lid is cemented to the post. This will be difficult with the Eval Board, but not impossible.
