Request for Bias Stability Data_ADXL357B
Category: Datasheet/Specs
Product Number: ADXL357B
Dear,
We are currently evaluating your ADXL357B for our project.
While reviewing the datasheet, we found that key parameters like Velocity Random Walk (VRW) and Noise Density are provided, but we are unable to derive the exact Bias Stability (or Bias Instability) from the current documentation.
Could you please provide the Bias Stability specifications for this part?
If available, sharing the Allan Variance plot or a detailed characterization report would be highly appreciated, as it will greatly assist our technical evaluation.
Thank you for your time and support.
I look forward to hearing from you
    Thanks for your question.
    Although bias stability is not provided as a separate specification in the datasheet, it has included Root Allan Variance (RAV) characterisation for all three axes in Figures 79 to 81 for X, Y, and Z axes respectively.
    The bias instability region can be assessed from the minimum/flat region of these curves. The published plots show minimum RAV values on the order of several μg, with the Z-axis higher than X and Y axes.
    These plots can therefore be used to estimate bias instability for evaluation purposes. These values should be considered estimates based on the typical-characterisation plots rather than guaranteed datasheet specifications, as there is some device-to-device variation visible in the RAV curves.
    Hope this helps. Please let me know if I can support further.
    Busra
  • Thank you for your answer. It is very helpful
