Status of 2 bugs - changing default filter settings, writing into registers over SPI interface
Product Number: CN0549
Has Analog devices fixed the following 2 issues with the CN0549 platform?
  • ability to change default filter selection settings;
  • ability to write into the registers over the SPI interface using the DE10-Nano.
I am planning on using the CN0549 to develop a prototype sensor to monitor bearing vibrations. I had tried to use this in 2021 and found a couple of bugs and ended up using a Teensy processor with the ADXL1002 (not the ideal scenario).
I want to try this platform again if the issues have been fixed. Are there any other major issues that are still open on the CN0549 development board?
This is a follow up to a couple of bugs I had found on this platform in late 2021 and was forced to abandon using this platform
Link to my postings from 2021 are here
ez.analog.com/.../unable-to-change-write-filter-settings-in-the-cn0540-setup-using-the-iio-oscilloscope-software
  • I retested the CN0549/CN0540 filter-selection issue using my original hardware and Kuiper image 18 on a separate SD card.
    On the original 2021 image, acquisition worked with the default filter setting. Writing 0x40 to digital-filter register 0x19 read back correctly, but acquisition stopped. Returning the register to 0x00 did not restore acquisition; a reboot was required.
    With image 18 and the updated Windows IIO Oscilloscope application, acquisition continued after selecting 0x40. The waveform responded to taps on the accelerometer, and the register still read 0x40.
    This indicates that the earlier acquisition failure following wideband-filter selection is no longer reproducible in this updated setup. I have not yet measured the filter’s frequency response, so I cannot confirm its actual response matches the selected setting. Because both Kuiper and IIO Oscilloscope were updated, I also cannot attribute the improvement to a particular change.
    The updated system reports Linux 6.12.77-g4b2e305bc496 and Kuiper v2.0.0-102-gfb2a11b-dirty, build date 2026-09-21.
  • I have not had the time to verify if the continuous read mode works properly. I can use the system in the standard SPI read mode for my application; so will not be retesting continuous read mode with the latest image.
