ADXRS290
Recommended for New Designs
The ADXRS290 is a high performance pitch and roll (dual-axis in-plane) angular rate sensor (gyroscope) designed for use in stabilization applications....
Datasheet
ADXRS290 on Analog.com
Hello I have this gyro and want to read values with rpi pico. I am completely desperate because it doesn't work. May be I am missing some point. Help please:)
Thank you very much. I already find out how to communicate with this device:-) Just to give you some background. I am a member of a group of technicians who debunk conspiracy theories. In this case, the nonsense that the Earth doesn’t rotate. And I’m trying to prove, using a relatively inexpensive gyroscope, that it’s possible to measure the Earth’s rotation even under amateur conditions. Although I’m still in the testing phase, it looks like it might work. Of course, I’d love to use a much better gyroscope, but we have a limited budget:-)
Glad it worked out, good luck.
Mario SM
