This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Accelerometer alternative for KX family
The user inquires about alternatives to the KX122 accelerometer for use with the MAXM86146, and whether firmware updates will support new motion sensors. The support engineer recommends the ADXL380 as a compatible alternative, noting that the MAXM86146 is I2C compatible. No mention of firmware updates or hex file modifications.
Product Number: MAXM86146
Software Version: 33.13.31
Since the KX122 and its family are now NRND, could you please advise on recommended alternative accelerometers that are compatible with the MAXM86146, and clarify whether we should expect any firmware updates to support different motion sensor hardware?
Alternatively, is there a way to tweak the pre-compiled hex .msbl file to make it work with other accelerometers?
Thank you.
Edit Notes
[locked by: MarioSM at 1:39 PM (GMT -4) on 11 Jun 2026]
