September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADXL357
Recommended for New Designs
The analog output ADXL356 and the digital outputs ADXL357 and ADXL357B are low noise density, low 0 g offset drift, low power, 3-axis accelerometers with...
Datasheet
ADXL357 on Analog.com
Dear,
I am a developer and I am looking for 3 axis SPI output accelerometer.
our customer required operating temperature -50 to +80 degree
In the datasheet the operating temperature -40 to 125 degree.
so, I have questions.
if we this sensor at -50 degree, If the sensor is used at -50 degrees, how much does the performance change?
Also, is it possible to use it at -50 degrees by changing the coating or packing?
Or is there perhaps another way??
Hello Yunalee thanks for posting.
Generally speaking we do not do any characterization work under -40C or any other temp. out of DS specified range. Thus, I can not specify in a deterministic way how much the performance will be degraded. I would expect to exceed the typ/max values for at least bias, tempco, sensitivity or clock timing, on top of added issues physical issues as thermomechanical stress in the packaging or long-term degradation.
I must also remark that since you would we working out of DS specs ADI does not support or guarantee operation under those conditions.
On the other hand, I would check if this other part meets your requirements : ADXL345-EP (Rev. B) since its working temperature range actually goes down to -55C.
hope this helps,
Mario SM
Thank you for your reply.
By any chance, can the EP product be applied to other parts as well?
Where can I check this?Hello Yunalee sure, I would advice you to contact our local sales team in Korea in order to study this request with the right Marketing stakeholders.
Once you have reached our sales team you could privately share some more details of your application and needs so we can further help you use our products.
have a great one,
Mario SM
Hi, Mario
I was contacted by the Korean branch, but I am currently working in the Middle East.
Is there a branch I could consult with?
Thank you for your support.
BR,
Thank you for your interest. We need to ask for your specific location, as "middle east" triggers a number of considerations, with respect to US export regulations. Thank you, in advance.
Our company is a Saudi Arabian military industry firm currently based in Riyadh, the capital of Saudi Arabia.
