I seem to be getting inconsistent results from our AD590. We have a simple setup with 5V on the positive pin, a set resistor, and an ADC. The problem is that I seem to be getting different temperatures when using different resistors, but I think they should be the same. We were using 10k at first, but then I read that the 4K min voltage was for between the positive and negative pins and not just at the positive pin, so I think those results are not necessarily valid. For a 10k resistor, we were getting 2.88V =15C for a board was measured at 26C. When I changed to a 1K resistor, I got @31C. When I changed to 5.35K resistor, I got the best result of about 28C. I wouldn't have expected the results to change with the resistor. Is this supposed to happen or are we doing something wrong?
Todd
