Instead of a DS1922T when it was working.
Has it lost it register or has the battery become depleted? Is there any other reason why this would occur? is there any way to correct this?
Your help would be appreciated
DS1922T
Production
The iButton® temperature loggers (DS1922L/T) are rugged, self-sufficient systems that measure temperature and record the result in a protected memory...
DS1922T on Analog.com
Can you read other registers?
1)Using first the addresses of DS1922T.
2) If you cant reach them with those, try to use the addresses of DS2422 registers.
If both are not functioning, I would not exclude the battery is weak and giving comm errors.
