ADXL372
Recommended for New Designs
The ADXL372 is an ultralow power, 3-axis, ±200 g MEMS accelerometer that consumes 22 µA at a 3200 Hz output data rate (ODR). The ADXL372 does not power...
Datasheet
ADXL372 on Analog.com
I am dealing with ADXL372, I am struggling with non-linearity.
Into datasheet it is specified to be +/-0.5% of full scale (FS: 400g, then it is +/-2g), but depending on where maximum non-linearity occurs (near 0g or toward full range) expected precision is a lot different.
Is there a graph showing how non-linearity evolves Vs. applied acceleration magnitude?
Seb
Hello ARP2600
here you can find one example from a real part, so you can have a rough idea of how the graph would look:
I also encourage you to take a look on the following article (fig. 5) so you can have somo more info about nonlinearity in our parts.
Hope this helps,
Mario SM
Hello Mario,
Thank your for your answer. It helps to better understand how non-linearity is behaving versus range.
I feel better to see that non-linearity remains contained for lowest part of measurement range.
Seb
