Suitable acceleration sensor for vibration measurements (EVAL-ADXL1003Z)
The user seeks a suitable accelerometer for measuring bicycle axle acceleration, including impacts, with a range of ±200g and a bandwidth up to 2.5 kHz. The EVAL-ADXL-1003Z is recommended, with a 15 kHz LP filter, and the Arduino Uno R4 WiFi's 14-bit ADC is sufficient for 5 kHz sampling. Digital alternatives like the ADXL371 and ADXL382 are also suggested, with ready-to-use evaluation boards and software support.
Category: Datasheet/Specs
Product Number: EVAL-ADXL1003Z, ADXL1003
I'm planning on the methods of my Thesis and I search the right sensor for it. The plan is to measure acceleration at the axle of a bicycle during several outdoor scenarios and some indoor at a fixed test bench. I assume I need a range of +- 200g because want to investigate in impacts as well. I want to record the data with an Arduino and use the ADC on it. Furthermore, I will record the data at max. 5 kHz. Can I use the EVAL-ADXL-1003Z for that? I was looking for a sensor where the bandwidth is above my frequencies of interests, from 0 to 2.5 kHz. As far as I understand, the "Bandwidth" is the max. possibly detected acceleration frequency. Is that correct?  I would really appreciate your help. Because originally I was looking for an analog 3-axis accelerometer with +- 200g range and a bandwidth that doesn't cut my frequency range I'm interested in, but I could find an evaluation board with the right sensor and specs for that. And because I don't have the possibilities to build my own PCBs, I'm limited to the Evaluation boards I can buy ready to go.
Kind Regards Josh
  • Hi Josh ( ) let's go by parts;
    " As far as I understand, the "Bandwidth" is the max. possibly detected acceleration frequency. Is that correct?"  - yes! In fact once you cross the cutoff frequency the sensor will keep working (the scale factor would remain the same by example) but will pull out an attenuated version of the signal.
    Expecting that the arduino's sampling rate is around 9.8 KHz (
    Arduino ADC: Everything you Must Know about the Built-In ADC), it should be able to hold your 2.5 KHz BW. However, if you want to squeeze the maximum performance out of the sensor, you may need an external ADC with a higher BW to further mitigate aliasing without using a filter from higher order. -An application example for 5KHz BW can be found in the interfacing analog output below 10khz section, page 11 from the ADXL1003 datasheet.
    That being said, you should be fine if you want to detect shocks. The 10 bits and the bandwidth is just enough.
    On the eval board side be you can find all the documentation
    here. Remember that the 1003 evalboard already presents a 15 KHz LP filter.
    As for sensor alternatives, it all depends on your specific application. Why do you need an analog sensor? Does the budget limit us to the arduino's ADC? Digital output parts like ADXL382 and ADXL371 may fit your context just by looking at the measurement range and BW.
    ADXL371/2 is a digital output part that fits your needs in terms of measurement range and BW, it also can be used with this plug and play Arduino shield.
    (ADXL382 could be a nice option with a complete ready to use evaluation board alongisde with custom software with all you could need for testing in case you end not needing the 200g range)
    Hope this helps.
    Mario SM
  • Hi Mario SM,
    Thank you very much for your Help! I'm Using and Arduino Uno R4 wifi with a 14bit ADC. Regarding to this post it should be 1MHz for the RA4M1 chip. So that would be suitable for me right? The data sheet of the RA4M1 is a little bit too much for me to understand how to get to such a value. On page 88 and 89 is something about the Conversion time of the adc.
    On the eval board side be you can find all the documentation here. Remember that the 1003 evalboard already presents a 15 KHz LP filter.
    I saw that, that would be totally fine!
    To be honest i wanted to stick to a analog sensor because there I could easaly could keep track of my filtering and the recording frequency of the data. Because according to some of my lectureres that can be a bit difficult sometime with digital ones and I thought it was simpler :D. But maybe they also just said that because we were only using arduinos in our class. And as I have to pay for most of my  material for my thesis by myself I thought to stick to something cheap that I have and already know a bit.
    I' not 100% sure if i need the +- 200g. But as I also want to investigate in impact on the wheel I want to be on the safe side. And my resolution is still good enough with that range.
    Again Than you very much!
    Kind Regards Josh
  • Hello again Josh, glad I could help.
    That Arduino will make the work just fine in this case. I totally feel you, I had the same experience on my thesis work not long time ago. In any case before ordering anything try to research about the available libraries and modules in our wiki and main page for the previouslhy mentioned parts. It may happen that the ADXL37x has enough documentation/software released to make your work even easier besides your previous experience.
    In any case do not doubt to reach us again in the future if you need any kind of help!
    Mario SM
