Pin22 of ADXL312, reserved , must be connected to GND which specified in datasheet.
The user encountered issues with the ADXL312 sensor, suspecting a problem with Pin22, which the datasheet states should be connected to GND. The EVAL-ADXL312 board leaves Pin22 open, causing confusion. The user later switched to the ADXL314, where Pin22 can be left open or connected to GND, suggesting that ADXL312 Pin22 could also be left open.
Product Number: ADXL312
There are three reserved pins on ADXL312, pin2, pin7 and pin 22. In rev.C datasheet, description on them listed below.
Pin2, reserved, This pin must be connected to VS or left open.
Pin7, reserved, This pin must be left open.
Pin22, reserved, This pin must be connected to GND.
In my schematic, Pin2 and Pin7 are left to open, Pin22 is connected to GND. But I found that pin22 is left open in the schematic of ADXL312 EVAL BOARD, 301-626.
Now I had a problem to get stable and correct data from my ADXL312 sensor assembly, and suspect that pin22 connected to GND is not correct.
Dawei Ma
