ADIS16477-3/PCBZ - will this part supports 32- bit data?
What is firmware revision used in this board.
please respond as early as possible.
Thank You
Prathibha Shree D R
ADIS16477
Recommended for New Designs
The ADIS16477 is a precision, miniature MEMS inertial measurement unit (IMU) that includes a triaxial gyroscope and a triaxial accelerometer. Each inertial...
Datasheet
ADIS16477 on Analog.com
Thank You
Prathibha Shree D R
Hi Prathiba:
The ADIS16477 datasheet shows that the sensor provides 32-bit registers, indicating that the hardware and software interface with the PCB support this data width. The electrical schematic on the ADIS1647x/PCBZ BREAKOUT BOARD WIKI GUIDE confirms that the PCB routes the SPI pins to an external interface, enabling access to the ADIS16477's 32-bit registers.
You can refer to the ADIS1647x/PCBZ breakout board guide for detailed schematic information.
For the FW rev part, you can check the ADIS16477 datasheet:
if you have any other questions, please let me know.
