MSL Level
The user inquired about the moisture sensitivity level (MSL) for the ADIS16460AMLZ, which is not rated for solder reflow processes due to its connector-based attachment. The final answer clarifies that the device does not have an MSL rating as it is not applicable.
Category: Datasheet/Specs
Product Number: ADIS16460AMLZ, ADIS16460
What is the MSL level for ADIS16460AMLZ?  I don't  see it listed in the data sheet.
  • Thank you for the interest in the ADIS16460.
    By "ML," are you referring to the moisture level, per JEDEC J-STDD-033?
    If so, my understanding is this only applies to devices that are attached via solder reflow processes, such as those in J-STD-020.
    The ADIS16460 attaches via connector and is NOT rated for such exposure.
    This is why there is no moisture level rating.
    Does that help?
