ADXL355 temperature sensor output at 25C: 1852 or 1885 LSB?
Product Number: ADXL355
ADXL355 data sheet Rev A states "TEMPERATURE SENSOR Output at 25°C 1852 LSB"
www.analog.com/.../adxl354_355.pdf
and data sheet Rev B states "TEMPERATURE SENSOR Output at 25°C 1885 LSB"
www.analog.com/.../adxl354_adxl355.pdf
Which one is correct?
Does it depend on what revision of ADXL355 part I have?
Thanks, Ari
Added links to data sheets.
[edited by: ari1000 at 2:03 PM (GMT -5) on 29 Nov 2023]
Top Replies
    in reply to ari1000 +1 verified
    Hi
    After consulting with our engineering team, we determined that the standard deviation for the temperature sensor's typical output at 25°C is 27LSB. So, it seems that your temperature reading…
