Cannot find the related document of ADIS16550
The user sought the ADIS16550 datasheet and encountered a 404 error. The support engineer provided the correct datasheet link. The user then asked about the Decimation Filter configuration, noting a discrepancy in the DIN value, and later identified a typo in the addresses of COEFF_C118 and COEFF_C119 registers. Both issues were confirmed as typos by the support engineer.
Category: Datasheet/Specs
Product Number: ADIS16550
Hello everyone,
I am working with ADIS16550 inertial sensor. I need to learn how to use and deal with ADIS16550.
But I cannot find any documents (Datasheet, Specs, Application Notes, ...) of this device on the Internet.
Although I found a link to Analog Devices' website: www.analog.com/.../adis16550.pdf, I got a 404 error.
 If you have any information about ADIS16550, please share it with me.
Thank you very much!
Best Regards,
Dat Phung
Parents
  • FormerMember
    +1 FormerMember
on Jul 25, 2023 1:17 PM
sorry for delayed response, but were you able to get the data sheet for ADIS16550
ADIS16550 (Rev. 0) (analog.com)
  • Thank you very much !! I got the datasheet document of ADIS16550.
    But I am confusing about configuring the Decimation Filter of ADIS16550. In the page 42 of datasheet : "The output sample rate is equal to 4000/(DECIMATE + 1). For example, set DECIMATE = 0x00000027 (DIN = 0x0027A90C) to reduce the output sample rate to 100 SPS (4000 ÷ 40)."
    Why the value of DIN is 0x0027A90C while the address of DECIMATION register is 0x54 ? I think the value of DIN should be 0x00275486 (D15:D0 = 0x0027; A6:A0 = 0x54; R/W = 1; and CRC = 0x6).
    Please help me to understand this situation.
    Thank you so much again !
    Best Regards,
    Dat Phung
  • FormerMember
    0 FormerMember on Aug 2, 2023 1:52 PM in reply to Datpt
    you are correct it should be 0x54 based on the data sheet table 91, 92 and table 15
  • Yup, Thank you very much !
    And in Table 21, page 32 of datasheet:
    Should the address of COEFF_C118 and COEFF_C119 registers be 0x7E, 0x7F respectively, instead of 0x7D, 0x7E ??
    Best Regards,
    Dat Phung
  • FormerMember
    0 FormerMember on Aug 3, 2023 11:24 AM in reply to Datpt
    HI Phung
    you are right again, this is yet again another typo.
    COEFF_C118 and COEFF_C119 registers are  0x7E, 0x7F
    thank you
  • Reply
    • FormerMember
      0 FormerMember
    HI Phung
    thank you
    Children
    No Data
