ADXL345 Evaluation Board provided Datalogger doesn't work
The user encountered issues with the EVAL-ADXL345Z-DB Datalogger after flashing a new hex file, resulting in only the red LED lighting up and no data being written to the SD card. The problem is likely due to SD card compatibility, as the original firmware was designed for 2GB cards. The final answer suggests checking the SD card size and formatting, and provides links to a thread with similar issues and a zip file with updated firmware and programming instructions.
I bought an ADXL345 Evaluation Board with the ADuC7024
It came with a running Datalogger, limited at 2g.
I downloaded the Zip with different Versions, flashed another Version to the Board, but only the Red Led lid up, no data written to the card.
Had somebody a similar issue and can help?
Thanks a lot
