How to calculate the measurement accuracy of ADXRS290 and ADXRS450?
In datesheet,only Sensitivity of LSB/°/sec is given.(200 for 290 and 80 for 450)
Can you give an example of calculating the measurement error by measuring a certain value, such as 10°/sec?
Thanks a lot.
    The datasheet also specifies the offset error, sensitivity tolerance and change with temperature, noise, non-linearity and cross axis sensitivity as sources of error.
    All these parameters add to the angle rate estimation error:
    Non-linearity and cross axis sensitivity in most applications can be ignored because their contribution to error are small. In this case:
    angle rate = sensor output[LSB]/(sensitivity[LSB/deg/s]+/- sensitivity tolerance) + offset[deg/s] * integration time[s] + noise
    sensitivity offset, cross axis sensitivity and sensitivity temperature dependency can be compensated by calibration.
    noise and nonlinearity cannot be compensated.
    I hope this helps,
    Pablo.
