ADIS16467 Clock Error in Scaled Sync mode
Having an issue using the scaled sync functionality of the ADIS16567 MEMS IMU.
The problem is very similar to what is described in a couple related posts which don't have answers:
https://ez.analog.com/mems/f/q-a/142639/adis16465-reading-buffer-data-is-abnormal-in-scaled-sync-mode
https://ez.analog.com/wide-band-rf-transceivers/design-support-ad9371/f/q-a/79425/ad9528-clock-sync-error/195228
I'm just trying to verify the functionality of scaled_sync mode (not particular about rates or other settings yet) and not having any success. I'm applying a square wave ranging from 1Hz to 120Hz to the SYNC pin on the IMU, and in direct sync mode everything works fine, but when I switch to scaled sync the device reports a clock error in DIAG_STAT, regardless of the value in UP_SCALE or the frequency of the square wave.
I probed the square wave I'm applying to the sync pin at the IMU and it looks very clean, and the SYNC_POL setting in MSC_CTRL doesn't seem to have any effect. I've got FILT_CTRL= 0 and DEC_RATE=0 as well.
Is there some nuance to using scaled_sync that I'm missing? Does the first edge of the SYNC signal need to show up within a certain amount of time of updating MSC_CTRL, for example?
Any help is greatly appreciated of course.
