I am using ADXL313 Device for a sizable quantity.
In a quantity of 5nos, 3 are working ok and 2 are not working as expected.
problem with sensor 1:- The calculated output in Degrees and the X-Axis output reading gets stuck [at actual 0Degree] with a random offset value when ever it is powered on. There after if i tap on the Device PCB, The X-Axis output reading and the calculated output show normal/expected readings.
Problem with sensor 2:- The sensor does not give any output at all for any of the axis.
Now the same software runs on all the 5-devices, so i am sure that the software is correct and that all the devices are configured correctly.
Now with this scenario i am unable to conclude what is going wrong.
please expedite.
Regards
