Sporadic wrong readings using ADXL345
We are getting sporadic wrong accelerometer readings ('spikes') from ADXL345. Depending on the configuration, the wrong reading can show up after a few minutes, although sometimes it has taken up to 10 hours. Fortunately, we have found that increasing the value of the output data rate (BW_RATE register) reduces the time between 'spikes', making it easier to reproduce.
The company I work for has been using ADXL345 in several products, and we have sold thousands of units with it since 2012. In spite of that, we have never noticed this anomaly because we have always filtered the output before using the acceleration values. It was just after a recent change in the software, in which we included a more strict "out of range" detection algorithm, that we started to notice these spikes. More information about our tests and SPI configuration can be found below, but at this point I will just clarify that we have not changed the way in which we collect the data from the SPI bus, we have just added a monitor to detect "strange" raw values from the DATAX, DATAY and DATAZ registers.
We have found in the Q&A database a possible relationship with these two other unresolved cases:
ez.analog.com/.../adxl345-gives-erratic-output-data-intermittently
ez.analog.com/.../issue-at-adxl345
In all our tests, the wrong reading is always isolated (i.e. just one sample is wrong, previous and following samples seem to be OK). Additionally, we have managed to observe some "pattern" in the errors, they all show up in one of these two forms:
1. One or more axes report 0 (raw value)
2. The value of Z axis is extremely high
In order for all tests to be consistent, the ADXL345 was always placed on a desk so that we would normally read values of around -1G for the Z axis, and values very close to 0 in the X and Y axes. Knocking on the desk where the ADXL345 was placed would cause a momentary increase in the acceleration values. Such knock was noticeable in the sensor output values across several samples, whereas the spikes are completely isolated and do not respond to any external stimulus.
We first thought that maybe the unit we were testing could be damaged, so we tested also other PCBs and we managed to observe the same problem. For that, we then purchased an evaluation board "EVAL-ADXL345Z" from an authorized distributor. We got the same problem with the evaluation board, so we tried connecting different CPUs to make sure there was not a problem in the SPI controller that we were using. So far we have managed to detect the isolated spikes using 4 different SoCs from 3 different manufacturers, particularly:
- Atmel AT91SAM7X512
- Atmel SAMA5D2
- NXP LPC1768 (mbed)
- Freescale MK20DX256VLH7 (Teensy 3.2)
We have checked that the values which we are decoding from the DATAX, DATAY and DATAZ registers match the data observed in the SPI bus with an oscilloscope. Also, we have carefully checked in all cases that SPI timing constraints are compliant (with some extra margin) with the figures in the datasheet, pages 16-17. We are not having any problems to read the content of other registers (e.g. DEVID, etc), that works fine. In our product boards there are other sensors by Analog Devices attached to the same SPI bus (but of course, different chip select) and we do not get any spikes from those other sensors; this is just to say that all SPI transactions seem to be working flawlessly.
When it comes to configuration, we have carefully read the datasheet and also these two application notes to make sure we are initializing the device correctly and that we are not missing any important steps:
www.analog.com/.../AN-1025.pdf
www.analog.com/.../AN-1077.pdf
We are using SPI @4MHz and our initialization sequence is as follows:
DATA_FORMAT: 0x0E ==> 4 wire SPI, full resolution, left justify, 8G
INT_ENABLE:  0x00 ==> We don't use the interrupt pin at all.
BW_RATE:     0x0F ==> 3200 Hz sampling. We normally use 400 but 3200 is the most error-prone config.
FIFO_CTL:    0x00 ==> FIFO bypass. Also tested with FIFO and Stream modes.
PWR_CTL:     0x00 ==> Set standby mode. Suggested by datasheet when clearing Link bit (even though it has never been raised). Tests also performed without this step, no differences.
PWR_CTL:     0x08 ==> Set measuring mode.
Our test applications schedule 1 read operation every 1ms, using the multi-byte read mode, i.e. DATAX, DATAY and DATAZ registers are read in the same SPI transaction every millisecond.
Even though all the tests were done with different CPUs, they were all using the SPI bus so we decided to do a final test with the Teensy 3.2 board using I2C. This was to make sure that the spikes were not related to the communication protocol. In fact we also got spikes using I2C @400kHz with the same configuration above, except for the output data rate (BW_RATE register), which we set to 800Hz rather than 3200Hz, as this is the maximum recommended value for I2C (datasheet page 15).
We would like to understand what can be causing the observed spikes, and if there is a way to avoid getting them -thanks.
  • Thank you for your extended use of the ADXL345 and for posting your question, in this forum.  Unfortunately, our primary expert on this product is out of the office for another 1.5 weeks, so we might be delayed in our response. I will see what I can find, but we might need to wait for my colleague, for this one.
  • Thank you very much . Looking forward to Pablo's answer.
  • Hi
    using the DATA_RDY bit, from the STATUS register, to synchronize the data reads should solve this issue. I think those spikes happen when new acceleration data is being stored in the DATAX, DATAY and DATAZ registers while an SPI read is requested.
    What I would do is something like:
    while(DATA_RDY == False):
        do nothing
    read DATAX, DATAY and DATAZ registers
    wait 1ms
    I hope this helps, looking forward for your feedback.
    Pablo.
  • Hi ,
    We have thoroughly seached across the datasheet, especially in the Register Map section, and could not find such 'STATUS' register or anything similar. The DATA_READY flag does not seem to be available for the user in any (documented) register and is rather intended for interrupt programming. Your explanation does not apply to this device (ADXL345), so there must be something wrong...
    Even if your suggestion were possible, I see the following problems:
    • In the "bypass" mode "a double-buffered output allows the read to finish first and then places the new data into the output filter" (quoted from the datasheet). That means that it should not be necessary to poll any flag to check when the new data is valid; otherwise, what would be the purpose of the double-buffered mechanism?
    • Assuming that the DATA_READY flag can be consulted in some of the "reserved" registers (?), trying to poll a flag using SPI or I2C can be challenging, since it would be impossible to synchronize the "readiness" of the data with the timing of the SPI/I2C transaction itself at any given clock frequency. In addition, for our real-time application, polling status flags via SPI adds unaffordable time cost.
    Looking forward to your feedback -thanks.
  • Hi
    My mistake, meant INT_SOURCE register (0x30) instead of STATUS register (it is name that way in another product. I mixed them in my head, sorry.)
    I was not able to find the quote you mentioned on the ADXL345 datasheet:
    "a double-buffered output allows the read to finish first and then places the new data into the output filter".
     Can you please share the document where you found this quote? I have requested our design team to confirm if the part does have a double buffer and I am waiting for their reply. I will circle back when I hear from them.
    The DATA_READY bit in the INT_SOURCE register is set when new data is available and cleared when acceleration data is read (registers 0x32 to 0x37). The DATA_READY bit can be mapped to one of the ADXL345 interrupt pins, which can be use to signal the MCU to start the SPI read. This is the way that we recommend for "synchronizing" with DATA_READY interrupt. Would you be able to implement this in your application?
    Pablo.
  • Hello ,
    Apologies from the wrong reference, the quote is not from the datasheet but from the Application Note AN-1025, which you can find linked in my first post.
    I understand your suggestion of setting the DATA_READY bit in the INT_SOURCE register and getting notified by an interrupt when the data is ready; unfortunately in our design the interrupt pins are not routed so this would not solve the problem in our case.
    I find that the interrupt option can be useful for knowing when there is new data available. However, even using the interrupt I could still have the same problem if the DATAX, DATAY and DATAZ values are about to change when I start the SPI transaction (race condition), hence the importance of the double buffer.
    Kind regards.
  • Hi
    sorry to hear that you cannot use the interrupt pins in your application. I know this might not me ideal, but you can also try a software approach by "synchronizing" to the DATA_READY bit by reading the INT_SOURCE register continuously.
    3200 Hz is the fastest sample rate for the ADXL345, this is one sample every 312.5us. From your original post, I see that your SPI speed is 4MHz, 1 burst read of all 3 axis requires 56 clocks, which is equivalent to 14us. So if you read the DATA_READY flag right after is set, you will not have superposition between SPI read and registers update.
    I hope this helps,
    Pablo.
  • Hello ,
    You are right, the continuous read operations in the SPI bus is far from ideal and we cannot afford it in our final application because we need to collect data from other sensors attached to the same SPI bus (with different chip select lines), i.e. we should therefore not overload the SPI bus for polling the INT_SOURCE register.
    Since our application needs to be very deterministic timewise, all we would need is just to perform a periodical read operation (without interrupts or polling) and collect the "freshest" acceleration sample from the ADXL345 sensor. As I stated in my first post, we do have a workaround, since we are able to detect and discard a sample which is "way" out of the expected range.
    Since we spotted this problem, our senior embedded engineer has invested more than two week's time in trying to solve it and collect the evidence that we have been sharing here... So to be honest, we are kindly asking someone at Analog Devices to either let us know what might have we missed in the configuration process or confirm that this is indeed a 'bug' (e.g in the ADXL345 double buffer mechanism). The problem seems to be consistent across several boards so it is relatively easy to replicate.
    You mentioned you had requested your design team about the double buffer -did you already hear back from them?
    Thank you very much for your help.
  • Hi
    One of our design engineers just confirmed that seems to be a bug in the buffer that causes this issue.
    Sorry for the inconvenience,
    Pablo.
  • Hello ,
    Thank you very much for your answer. Was this a known bug in the ADXL345 then or did you learn about it after my report? I haven't been able to find an 'Errata' document explaining this (as I have seen for other bugs affecting other sensors by Analog Devices, for instance).
    As I mentioned earlier, the ADXL345 accelerometer is included in one of our products, of which we have sold thousands of units already. We are testing a new firmware version that discards accelerometer samples that are "way" out of range, as a workaround, using a random threshold value that we have set. However, in our industry sector a formal justification (such as the Errata document) is required before such a change can be delivered to a customer. In addition, the Errata document typically provides some more details about the bug that could (maybe) help us improve the "out of range" detection algorithm.
    Can you please advice when the Errata was or will be published so that we can consult it? Alternatively, could you please get us in touch with your design engineer to collect some more details about this bug?
    Just one final note: our device has been working apparently fine with the ADXL345 for years, however we found that this bug was the reason behind a recent incident reported by one of our customers, hence our need to release a reliable firmware upgrade.
    Thanks for your cooperation.
