Activity and in-activity detection of ADXL362
Hi
I am FAE in Japanese distributor.
Our customer uses activity and in-activity detection of ADXL362.
If the active timer is set to 10 seconds and X Data exceeds the threshold for only 5 seconds then Y Data exceeds the threshold for only 5 seconds,
could ADXL362 detect the activity?
When was the reference value measured in reference mode of activity detection?
How was the reference value measured in reference mode of activity detection?
Best regards
N.Kokubo
Top Replies
    on Dec 13, 2020 12:43 PM 3 months ago
    Hi ,
    Thank you for your post!
    Sorry for the delay in our reply.
    I'll confirm with a colleague if the X and Y - axes are independent for activity/inactivity.
    I'll reply again as soon as I have an update.
    John
  • +1
    on Dec 14, 2020 6:49 PM 3 months ago in reply to John.Tuazon
    Hi
    The axes are independent but a combination of the x-y axis above the limit would trigger the activity detection.
    For example,
    If this is what you're referring to, then yes, the timer would continue on running and at 10 seconds, then it would issue an activity interrupt.
    For the referenced configuration,
    This presentation may be useful for the explanation from the data sheet
    "In the referenced configuration, activity is detected when acceleration samples are at least a user set amount above an internally defined reference for the user defined amount of time, as described in Equation 1. ABS(Acceleration − Reference) > Threshold (1) "
    Hope this helps!
    John
  • Hi Jhon san
      Thank you for your polite answer.
      I understood you.
      I close this question.
    Best regards
    N.Kokubo
