Do you have the following data about ADXL1001, ADXL1003, ADXL1005?
1. Offset voltage stability when the device is exposed to increasing acceleration.
2. Peak clipping level when the device is exposed to excessive acceleration.
plesase.
Best regards
plesase.
Best regards
Hi Mochi,
Thank you for your post!
To help you better, would you like to explain more about the first question?
I'll relay this to my colleague and would get back to you as soon as I have an update.
John
Thank you for your attention.
Our customer used to work with the ADXL150.
Customers are now interested in the ADXL100X series.
From the ADXL150 precedent, customers believe they need to know what happens when acceleration exceeds the operating range.
Best regards
Please refer to the Over-Range section of the datasheet. This is a snippet form the datasheet.
